root/radiance/ray/src/ot/oconv.c
Revision: 1.2
Committed: Wed Mar 29 11:25:02 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.1: +8 -6 lines
extended margin around bounding cube
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * oconv.c - main program for object to octree conversion.
9 *
10 * 7/29/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 #define OMARGIN (10*FTINY) /* margin around global cube */
22
23 #define MAXOBJFIL 63 /* maximum number of scene files */
24
25 char *progname; /* argv[0] */
26
27 char *libpath; /* library search path */
28
29 int nowarn = 0; /* supress warnings? */
30
31 int objlim = 5; /* # of objects before split */
32
33 int resolu = 1024; /* octree resolution limit */
34
35 CUBE thescene = {EMPTY, {0.0, 0.0, 0.0}, 0.0}; /* our scene */
36
37 char *ofname[MAXOBJFIL+1]; /* object file names */
38 int nfiles = 0; /* number of object files */
39
40 double mincusize; /* minimum cube size from resolu */
41
42
43 main(argc, argv) /* convert object files to an octree */
44 int argc;
45 char **argv;
46 {
47 char *getenv();
48 double atof();
49 FVECT bbmin, bbmax;
50 char *infile = NULL;
51 int outflags = IO_ALL;
52 OBJECT startobj;
53 int i;
54
55 progname = argv[0];
56
57 if ((libpath = getenv("RAYPATH")) == NULL)
58 libpath = ":/usr/local/lib/ray";
59
60 for (i = 1; i < argc && argv[i][0] == '-'; i++)
61 switch (argv[i][1]) {
62 case 'i': /* input octree */
63 infile = argv[++i];
64 break;
65 case 'b': /* bounding cube */
66 thescene.cuorg[0] = atof(argv[++i]) - OMARGIN;
67 thescene.cuorg[1] = atof(argv[++i]) - OMARGIN;
68 thescene.cuorg[2] = atof(argv[++i]) - OMARGIN;
69 thescene.cusize = atof(argv[++i]) + 2*OMARGIN;
70 break;
71 case 'n': /* set limit */
72 objlim = atoi(argv[++i]);
73 break;
74 case 'r': /* resolution limit */
75 resolu = atoi(argv[++i]);
76 break;
77 case 'f': /* freeze octree */
78 outflags &= ~IO_FILES;
79 break;
80 case 'w': /* supress warnings */
81 nowarn = 1;
82 break;
83 default:
84 sprintf(errmsg, "unknown option: '%s'", argv[i]);
85 error(USER, errmsg);
86 break;
87 }
88
89 if (infile != NULL) { /* get old octree & objects */
90 if (thescene.cusize > FTINY)
91 error(USER, "only one of '-b' or '-i'");
92 nfiles = readoct(infile, IO_ALL, &thescene, ofname);
93 if (nfiles == 0 && outflags & IO_FILES) {
94 error(WARNING, "frozen octree");
95 outflags &= ~IO_FILES;
96 }
97 }
98
99 printargs(argc, argv, stdout); /* info. header */
100 printf("\n");
101
102 startobj = nobjects; /* previous objects already converted */
103
104 for ( ; i < argc; i++) { /* read new files */
105 if (nfiles >= MAXOBJFIL)
106 error(INTERNAL, "too many scene files");
107 readobj(ofname[nfiles++] = argv[i]);
108 }
109 ofname[nfiles] = NULL;
110 /* find bounding box */
111 bbmin[0] = bbmin[1] = bbmin[2] = FHUGE;
112 bbmax[0] = bbmax[1] = bbmax[2] = -FHUGE;
113 for (i = startobj; i < nobjects; i++)
114 add2bbox(objptr(i), bbmin, bbmax);
115 /* set/check cube */
116 if (thescene.cusize == 0.0) {
117 if (bbmin[0] <= bbmax[0]) {
118 for (i = 0; i < 3; i++) {
119 bbmin[i] -= OMARGIN;
120 bbmax[i] += OMARGIN;
121 }
122 VCOPY(thescene.cuorg, bbmin);
123 for (i = 0; i < 3; i++)
124 if (bbmax[i] - bbmin[i] > thescene.cusize)
125 thescene.cusize = bbmax[i] - bbmin[i];
126 }
127 } else {
128 for (i = 0; i < 3; i++)
129 if (bbmin[i] < thescene.cuorg[i] ||
130 bbmax[i] > thescene.cuorg[i] + thescene.cusize)
131 error(USER, "boundary does not encompass scene");
132 }
133
134 mincusize = thescene.cusize / resolu - FTINY;
135
136 for (i = startobj; i < nobjects; i++) /* add new objects */
137 addobject(&thescene, i);
138
139 thescene.cutree = combine(thescene.cutree); /* optimize */
140
141 writeoct(outflags, &thescene, ofname); /* write structures to stdout */
142
143 quit(0);
144 }
145
146
147 quit(code) /* exit program */
148 int code;
149 {
150 exit(code);
151 }
152
153
154 cputs() /* interactive error */
155 {
156 /* referenced, but not used */
157 }
158
159
160 wputs(s) /* warning message */
161 char *s;
162 {
163 if (!nowarn)
164 eputs(s);
165 }
166
167
168 eputs(s) /* put string to stderr */
169 register char *s;
170 {
171 static int inline = 0;
172
173 if (!inline++) {
174 fputs(progname, stderr);
175 fputs(": ", stderr);
176 }
177 fputs(s, stderr);
178 if (*s && s[strlen(s)-1] == '\n')
179 inline = 0;
180 }
181
182
183 addobject(cu, obj) /* add an object to a cube */
184 register CUBE *cu;
185 OBJECT obj;
186 {
187 CUBE cukid;
188 OCTREE ot;
189 OBJECT oset[MAXSET+1];
190 int in;
191 register int i, j;
192
193 in = (*ofun[objptr(obj)->otype].funp)(objptr(obj), cu);
194
195 if (!in)
196 return; /* no intersection */
197
198 if (istree(cu->cutree)) {
199 /* do children */
200 cukid.cusize = cu->cusize * 0.5;
201 for (i = 0; i < 8; i++) {
202 cukid.cutree = octkid(cu->cutree, i);
203 for (j = 0; j < 3; j++) {
204 cukid.cuorg[j] = cu->cuorg[j];
205 if ((1<<j) & i)
206 cukid.cuorg[j] += cukid.cusize;
207 }
208 addobject(&cukid, obj);
209 octkid(cu->cutree, i) = cukid.cutree;
210 }
211
212 } else if (isempty(cu->cutree)) {
213 /* singular set */
214 oset[0] = 1; oset[1] = obj;
215 cu->cutree = fullnode(oset);
216
217 } else {
218 /* add to full node */
219 objset(oset, cu->cutree);
220 cukid.cusize = cu->cusize * 0.5;
221
222 if (in == 2 || oset[0] < objlim || cukid.cusize < mincusize) {
223 /* add to set */
224 if (oset[0] >= MAXSET) {
225 sprintf(errmsg,
226 "set overflow in addobject (%s)",
227 objptr(obj)->oname);
228 error(INTERNAL, errmsg);
229 }
230 insertelem(oset, obj);
231 cu->cutree = fullnode(oset);
232
233 } else {
234 /* subdivide cube */
235 if ((ot = octalloc()) == EMPTY)
236 error(SYSTEM, "out of octree space");
237 for (i = 0; i < 8; i++) {
238 cukid.cutree = EMPTY;
239 for (j = 0; j < 3; j++) {
240 cukid.cuorg[j] = cu->cuorg[j];
241 if ((1<<j) & i)
242 cukid.cuorg[j] += cukid.cusize;
243 }
244 for (j = 1; j <= oset[0]; j++)
245 addobject(&cukid, oset[j]);
246 addobject(&cukid, obj);
247 octkid(ot, i) = cukid.cutree;
248 }
249 cu->cutree = ot;
250 }
251 }
252 }
