1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: oconv.c,v 2.18 2003/10/22 02:06:34 greg Exp $"; |
3 |
#endif |
4 |
5 |
* oconv.c - main program for object to octree conversion. |
6 |
7 |
* 7/29/85 |
8 |
9 |
10 |
#include "platform.h" |
11 |
#include "standard.h" |
12 |
#include "octree.h" |
13 |
#include "object.h" |
14 |
#include "otypes.h" |
15 |
#include "paths.h" |
16 |
#include "resolu.h" |
17 |
#include "oconv.h" |
18 |
19 |
#define OMARGIN (10*FTINY) /* margin around global cube */ |
20 |
21 |
#define MAXOBJFIL 127 /* maximum number of scene files */ |
22 |
23 |
char *progname; /* argv[0] */ |
24 |
25 |
int nowarn = 0; /* supress warnings? */ |
26 |
27 |
int objlim = 6; /* # of objects before split */ |
28 |
29 |
int resolu = 16384; /* octree resolution limit */ |
30 |
31 |
CUBE thescene = {EMPTY, {0.0, 0.0, 0.0}, 0.0}; /* our scene */ |
32 |
33 |
char *ofname[MAXOBJFIL+1]; /* object file names */ |
34 |
int nfiles = 0; /* number of object files */ |
35 |
36 |
double mincusize; /* minimum cube size from resolu */ |
37 |
38 |
void (*addobjnotify[])() = {NULL}; /* new object notifier functions */ |
39 |
40 |
static void addobject(CUBE *cu, OBJECT obj); |
41 |
static void add2full(CUBE *cu, OBJECT obj, int inc); |
42 |
43 |
44 |
int |
45 |
main( /* convert object files to an octree */ |
46 |
int argc, |
47 |
char *argv[] |
48 |
49 |
50 |
FVECT bbmin, bbmax; |
51 |
char *infile = NULL; |
52 |
int inpfrozen = 0; |
53 |
int outflags = IO_ALL; |
54 |
OBJECT startobj; |
55 |
int i; |
56 |
57 |
progname = argv[0] = fixargv0(argv[0]); |
58 |
59 |
ot_initotypes(); |
60 |
61 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
62 |
switch (argv[i][1]) { |
63 |
case '\0': /* scene from stdin */ |
64 |
goto breakopt; |
65 |
case 'i': /* input octree */ |
66 |
infile = argv[++i]; |
67 |
break; |
68 |
case 'b': /* bounding cube */ |
69 |
thescene.cuorg[0] = atof(argv[++i]) - OMARGIN; |
70 |
thescene.cuorg[1] = atof(argv[++i]) - OMARGIN; |
71 |
thescene.cuorg[2] = atof(argv[++i]) - OMARGIN; |
72 |
thescene.cusize = atof(argv[++i]) + 2*OMARGIN; |
73 |
break; |
74 |
case 'n': /* set limit */ |
75 |
objlim = atoi(argv[++i]); |
76 |
break; |
77 |
case 'r': /* resolution limit */ |
78 |
resolu = atoi(argv[++i]); |
79 |
break; |
80 |
case 'f': /* freeze octree */ |
81 |
outflags &= ~IO_FILES; |
82 |
break; |
83 |
case 'w': /* supress warnings */ |
84 |
nowarn = 1; |
85 |
break; |
86 |
default: |
87 |
sprintf(errmsg, "unknown option: '%s'", argv[i]); |
88 |
error(USER, errmsg); |
89 |
break; |
90 |
91 |
breakopt: |
92 |
SET_FILE_BINARY(stdout); |
93 |
if (infile != NULL) { /* get old octree & objects */ |
94 |
if (thescene.cusize > FTINY) |
95 |
error(USER, "only one of '-b' or '-i'"); |
96 |
nfiles = readoct(infile, IO_ALL, &thescene, ofname); |
97 |
if (nfiles == 0) |
98 |
inpfrozen++; |
99 |
} else |
100 |
newheader("RADIANCE", stdout); /* new binary file header */ |
101 |
printargs(argc, argv, stdout); |
102 |
fputformat(OCTFMT, stdout); |
103 |
printf("\n"); |
104 |
105 |
startobj = nobjects; /* previous objects already converted */ |
106 |
107 |
for ( ; i < argc; i++) /* read new scene descriptions */ |
108 |
if (!strcmp(argv[i], "-")) { /* from stdin */ |
109 |
readobj(NULL); |
110 |
111 |
} else { /* from file */ |
112 |
if (nfiles >= MAXOBJFIL) |
113 |
error(INTERNAL, "too many scene files"); |
114 |
readobj(ofname[nfiles++] = argv[i]); |
115 |
116 |
117 |
ofname[nfiles] = NULL; |
118 |
119 |
if (inpfrozen && outflags & IO_FILES) { |
120 |
error(WARNING, "frozen octree"); |
121 |
122 |
123 |
/* find bounding box */ |
124 |
bbmin[0] = bbmin[1] = bbmin[2] = FHUGE; |
125 |
bbmax[0] = bbmax[1] = bbmax[2] = -FHUGE; |
126 |
for (i = startobj; i < nobjects; i++) |
127 |
add2bbox(objptr(i), bbmin, bbmax); |
128 |
/* set/check cube */ |
129 |
if (thescene.cusize == 0.0) { |
130 |
if (bbmin[0] <= bbmax[0]) { |
131 |
for (i = 0; i < 3; i++) { |
132 |
bbmin[i] -= OMARGIN; |
133 |
bbmax[i] += OMARGIN; |
134 |
135 |
for (i = 0; i < 3; i++) |
136 |
if (bbmax[i] - bbmin[i] > thescene.cusize) |
137 |
thescene.cusize = bbmax[i] - bbmin[i]; |
138 |
139 |
thescene.cuorg[i] = |
140 |
(bbmax[i]+bbmin[i]-thescene.cusize)*.5; |
141 |
142 |
} else { |
143 |
144 |
if (bbmin[i] < thescene.cuorg[i] || |
145 |
bbmax[i] > thescene.cuorg[i] + thescene.cusize) |
146 |
error(USER, "boundary does not encompass scene"); |
147 |
148 |
149 |
mincusize = thescene.cusize / resolu - FTINY; |
150 |
151 |
for (i = startobj; i < nobjects; i++) /* add new objects */ |
152 |
addobject(&thescene, i); |
153 |
154 |
thescene.cutree = combine(thescene.cutree); /* optimize */ |
155 |
156 |
writeoct(outflags, &thescene, ofname); /* write structures to stdout */ |
157 |
158 |
quit(0); |
159 |
return 0; /* pro forma return */ |
160 |
161 |
162 |
163 |
void |
164 |
quit( /* exit program */ |
165 |
int code |
166 |
167 |
168 |
exit(code); |
169 |
170 |
171 |
172 |
void |
173 |
cputs(void) /* interactive error */ |
174 |
175 |
/* referenced, but not used */ |
176 |
177 |
178 |
179 |
void |
180 |
wputs( /* warning message */ |
181 |
char *s |
182 |
183 |
184 |
if (!nowarn) |
185 |
eputs(s); |
186 |
187 |
188 |
189 |
void |
190 |
eputs( /* put string to stderr */ |
191 |
register char *s |
192 |
193 |
194 |
static int inln = 0; |
195 |
196 |
if (!inln++) { |
197 |
fputs(progname, stderr); |
198 |
fputs(": ", stderr); |
199 |
200 |
fputs(s, stderr); |
201 |
if (*s && s[strlen(s)-1] == '\n') |
202 |
inln = 0; |
203 |
204 |
205 |
/* conflicting def's in param.h */ |
206 |
#undef tstbit |
207 |
#undef setbit |
208 |
#undef clrbit |
209 |
#undef tglbit |
210 |
211 |
#define bitop(f,i,op) (f[((i)>>3)] op (1<<((i)&7))) |
212 |
#define tstbit(f,i) bitop(f,i,&) |
213 |
#define setbit(f,i) bitop(f,i,|=) |
214 |
#define clrbit(f,i) bitop(f,i,&=~) |
215 |
#define tglbit(f,i) bitop(f,i,^=) |
216 |
217 |
218 |
static void |
219 |
addobject( /* add an object to a cube */ |
220 |
register CUBE *cu, |
221 |
OBJECT obj |
222 |
223 |
224 |
int inc; |
225 |
226 |
inc = (*ofun[objptr(obj)->otype].funp)(objptr(obj), cu); |
227 |
228 |
if (inc == O_MISS) |
229 |
return; /* no intersection */ |
230 |
231 |
if (istree(cu->cutree)) { |
232 |
CUBE cukid; /* do children */ |
233 |
int i, j; |
234 |
cukid.cusize = cu->cusize * 0.5; |
235 |
for (i = 0; i < 8; i++) { |
236 |
cukid.cutree = octkid(cu->cutree, i); |
237 |
for (j = 0; j < 3; j++) { |
238 |
cukid.cuorg[j] = cu->cuorg[j]; |
239 |
if ((1<<j) & i) |
240 |
cukid.cuorg[j] += cukid.cusize; |
241 |
242 |
addobject(&cukid, obj); |
243 |
octkid(cu->cutree, i) = cukid.cutree; |
244 |
245 |
return; |
246 |
247 |
if (isempty(cu->cutree)) { |
248 |
OBJECT oset[2]; /* singular set */ |
249 |
oset[0] = 1; oset[1] = obj; |
250 |
cu->cutree = fullnode(oset); |
251 |
return; |
252 |
253 |
/* add to full node */ |
254 |
add2full(cu, obj, inc); |
255 |
256 |
257 |
258 |
static void |
259 |
add2full( /* add object to full node */ |
260 |
261 |
OBJECT obj, |
262 |
int inc |
263 |
264 |
265 |
OCTREE ot; |
266 |
OBJECT oset[MAXSET+1]; |
267 |
CUBE cukid; |
268 |
unsigned char inflg[(MAXSET+7)/8], volflg[(MAXSET+7)/8]; |
269 |
register int i, j; |
270 |
271 |
objset(oset, cu->cutree); |
272 |
273 |
274 |
if (inc==O_IN || oset[0] < objlim || cukid.cusize < mincusize) { |
275 |
/* add to set */ |
276 |
if (oset[0] >= MAXSET) { |
277 |
sprintf(errmsg, "set overflow in addobject (%s)", |
278 |
objptr(obj)->oname); |
279 |
error(INTERNAL, errmsg); |
280 |
281 |
insertelem(oset, obj); |
282 |
283 |
return; |
284 |
285 |
/* subdivide cube */ |
286 |
if ((ot = octalloc()) == EMPTY) |
287 |
error(SYSTEM, "out of octree space"); |
288 |
/* mark volumes */ |
289 |
j = (oset[0]+7)>>3; |
290 |
while (j--) |
291 |
volflg[j] = inflg[j] = 0; |
292 |
for (j = 1; j <= oset[0]; j++) |
293 |
if (isvolume(objptr(oset[j])->otype)) { |
294 |
setbit(volflg,j-1); |
295 |
if ((*ofun[objptr(oset[j])->otype].funp) |
296 |
(objptr(oset[j]), cu) == O_IN) |
297 |
setbit(inflg,j-1); |
298 |
299 |
/* assign subcubes */ |
300 |
301 |
cukid.cutree = EMPTY; |
302 |
303 |
304 |
if ((1<<j) & i) |
305 |
306 |
307 |
/* surfaces first */ |
308 |
309 |
if (!tstbit(volflg,j-1)) |
310 |
addobject(&cukid, oset[j]); |
311 |
/* then this object */ |
312 |
313 |
/* then partial volumes */ |
314 |
315 |
if (tstbit(volflg,j-1) && |
316 |
!tstbit(inflg,j-1)) |
317 |
318 |
/* full volumes last */ |
319 |
320 |
if (tstbit(inflg,j-1)) |
321 |
322 |
/* returned node */ |
323 |
octkid(ot, i) = cukid.cutree; |
324 |
325 |
cu->cutree = ot; |
326 |
