root/radiance/ray/src/ot/oconv.c
Mon Feb 6 22:40:21 2023 UTC (2 years, 2 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.22: +6 -6 lines
Diff to previous 2.22 , to selected 2.4
Tue Jun 17 18:18:50 2014 UTC (10 years, 10 months ago) by greg
Diff to previous 2.21 , to selected 2.4
Increased maximum number of scene files from 127 to 255
Fri Sep 23 19:04:52 2005 UTC (19 years, 7 months ago) by greg
Diff to previous 2.20 , to selected 2.4
Mon Apr 12 17:31:27 2004 UTC (21 years ago) by greg
Diff to previous 2.19 , to selected 2.4
Sat Mar 27 12:41:45 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.18: +34 -19 lines
Diff to previous 2.18 , to selected 2.4
Wed Oct 22 02:06:34 2003 UTC (21 years, 6 months ago) by greg
Diff to previous 2.17 , to selected 2.4
Sat Jun 21 15:05:01 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.16: +6 -1 lines
Diff to previous 2.16 , to selected 2.4
Fixed some conflicting definitions
Sun Jun 8 12:03:10 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.15: +2 -5 lines
Diff to previous 2.15 , to selected 2.4
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.14 , to selected 2.4
Wed Mar 12 17:26:58 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 2.13 , to selected 2.4
Wed Mar 12 04:59:04 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.12: +23 -12 lines
Sat Feb 22 02:07:26 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.11: +7 -6 lines
Fri Jun 2 17:47:04 1995 UTC (29 years, 11 months ago) by greg
increased maximum number of files from 63 to 127
Fri Jan 6 10:13:04 1995 UTC (30 years, 4 months ago) by greg
Changes since 2.9: +1 -3 lines
minor changes
Thu Apr 14 05:02:06 1994 UTC (31 years ago) by greg
Changes since 2.8: +0 -5 lines
Mon Mar 28 11:13:58 1994 UTC (31 years, 1 month ago) by greg
fixed duplicate header ID for -i option
Sun Feb 27 10:16:42 1994 UTC (31 years, 2 months ago) by greg
Fri Feb 12 18:43:24 1993 UTC (32 years, 2 months ago) by greg
Changes since 2.5: +9 -4 lines
made it so reading from stdin avoids "frozen octree" warning
Fri Oct 9 10:26:28 1992 UTC (32 years, 7 months ago) by greg
Changes for 32-bit PC port
Mon Sep 21 12:11:39 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.3: +19 -18 lines
Changes for PC port
Mon Aug 24 15:19:12 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.2: +5 -6 lines
fixed bug in array size for volflg and inflg
Thu Dec 19 15:06:31 1991 UTC (33 years, 4 months ago) by greg
Changes since 2.1: +1 -2 lines
Tue Nov 12 17:00:55 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.14 , to selected 2.4
Wed May 29 16:22:36 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.13 , to selected 2.4
added define for DEFPATH
Thu Apr 18 12:57:40 1991 UTC (34 years ago) by greg
Diff to previous 1.12 , to selected 2.4
added format to output header
Thu Dec 13 10:52:51 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.11: +2 -0 lines
Diff to previous 1.11 , to selected 2.4
Wed Aug 29 21:56:17 1990 UTC (34 years, 8 months ago) by greg
Changes since 1.10: +69 -52 lines
Diff to previous 1.10 , to selected 2.4
the final solution (hopefully) to volumes
Wed Aug 29 13:01:16 1990 UTC (34 years, 8 months ago) by greg
Changes since 1.9: +10 -2 lines
Diff to previous 1.9 , to selected 2.4
improved conversion speed for instances
Tue Jun 26 09:02:03 1990 UTC (34 years, 10 months ago) by greg
Diff to previous 1.8 , to selected 2.4
inline will be reserved word
Mon Apr 2 15:19:46 1990 UTC (35 years, 1 month ago) by greg
Changes since 1.7: +8 -1 lines
Diff to previous 1.7 , to selected 2.4
Improved performance for overlapping instances
Fri Jan 12 10:50:59 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.6: +2 -0 lines
Diff to previous 1.6 , to selected 2.4
added notifier capability to insertobject()
Sat Oct 14 11:19:34 1989 UTC (35 years, 6 months ago) by greg
Changes since 1.5: +3 -3 lines
Diff to previous 1.5 , to selected 2.4
Wed Jun 21 08:56:35 1989 UTC (35 years, 10 months ago) by greg
Diff to previous 1.4 , to selected 2.4
changed option processing switch slightly
Thu Jun 1 19:23:13 1989 UTC (35 years, 11 months ago) by greg
Changes since 1.3: +12 -7 lines
Diff to previous 1.3 , to selected 2.4
Added ability to read scene from stdin
Mon Apr 10 17:00:27 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.2: +3 -1 lines
Diff to previous 1.2 , to selected 2.4
Centered cube on bounding box
Wed Mar 29 11:25:02 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.1: +8 -6 lines
Diff to previous 1.1 , to selected 2.4
extended margin around bounding cube
Thu Feb 2 10:33:04 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 2.4
