1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: obj2mesh.c,v 2.6 2003/06/08 12:03:10 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Main program to compile a Wavefront .OBJ file into a Radiance mesh |
6 |
7 |
8 |
#include "copyright.h" |
9 |
#include "platform.h" |
10 |
#include "standard.h" |
11 |
#include "cvmesh.h" |
12 |
#include "otypes.h" |
13 |
14 |
extern int o_face(); |
15 |
16 |
int o_default() { return(O_MISS); } |
17 |
18 |
FUN ofun[NUMOTYPE] = INIT_OTYPE; /* needed for link resolution */ |
19 |
20 |
char *progname; /* argv[0] */ |
21 |
22 |
int nowarn = 0; /* supress warnings? */ |
23 |
24 |
int objlim = 15; /* # of objects before split */ |
25 |
26 |
int resolu = 16384; /* octree resolution limit */ |
27 |
28 |
double mincusize; /* minimum cube size from resolu */ |
29 |
30 |
31 |
main(argc, argv) /* compile a .OBJ file into a mesh */ |
32 |
int argc; |
33 |
char *argv[]; |
34 |
35 |
int nmatf = 0; |
36 |
char *matinp[32]; |
37 |
int i, j; |
38 |
39 |
progname = argv[0]; |
40 |
ofun[OBJ_FACE].funp = o_face; |
41 |
42 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
43 |
switch (argv[i][1]) { |
44 |
case 'n': /* set limit */ |
45 |
objlim = atoi(argv[++i]); |
46 |
break; |
47 |
case 'r': /* resolution limit */ |
48 |
resolu = atoi(argv[++i]); |
49 |
break; |
50 |
case 'a': /* material file */ |
51 |
matinp[nmatf++] = argv[++i]; |
52 |
break; |
53 |
case 'w': /* supress warnings */ |
54 |
nowarn = 1; |
55 |
break; |
56 |
default: |
57 |
sprintf(errmsg, "unknown option: '%s'", argv[i]); |
58 |
error(USER, errmsg); |
59 |
break; |
60 |
61 |
62 |
if (i < argc-2) |
63 |
error(USER, "too many file arguments"); |
64 |
/* initialize mesh */ |
65 |
cvinit(i==argc-2 ? argv[i+1] : "<stdout>"); |
66 |
/* load material input */ |
67 |
for (j = 0; j < nmatf; j++) |
68 |
readobj(matinp[j]); |
69 |
/* read .OBJ file into triangles */ |
70 |
if (i == argc) |
71 |
wfreadobj(NULL); |
72 |
else |
73 |
wfreadobj(argv[i]); |
74 |
75 |
cvmeshbounds(); /* set octree boundaries */ |
76 |
77 |
if (i == argc-2) /* open output file */ |
78 |
if (freopen(argv[i+1], "w", stdout) == NULL) |
79 |
error(SYSTEM, "cannot open output file"); |
80 |
SET_FILE_BINARY(stdout); |
81 |
newheader("RADIANCE", stdout); /* new binary file header */ |
82 |
printargs(i<argc ? i+1 : argc, argv, stdout); |
83 |
fputformat(MESHFMT, stdout); |
84 |
fputc('\n', stdout); |
85 |
86 |
mincusize = ourmesh->mcube.cusize / resolu - FTINY; |
87 |
88 |
for (i = 0; i < nobjects; i++) /* add triangles to octree */ |
89 |
if (objptr(i)->otype == OBJ_FACE) |
90 |
addface(&ourmesh->mcube, i); |
91 |
92 |
/* optimize octree */ |
93 |
ourmesh->mcube.cutree = combine(ourmesh->mcube.cutree); |
94 |
95 |
if (ourmesh->mcube.cutree == EMPTY) |
96 |
error(WARNING, "mesh is empty"); |
97 |
98 |
cvmesh(); /* convert mesh and leaf nodes */ |
99 |
100 |
writemesh(ourmesh, stdout); /* write mesh to output */ |
101 |
102 |
/* printmeshstats(ourmesh, stderr); */ |
103 |
104 |
quit(0); |
105 |
106 |
107 |
108 |
void |
109 |
quit(code) /* exit program */ |
110 |
int code; |
111 |
112 |
exit(code); |
113 |
114 |
115 |
116 |
void |
117 |
cputs() /* interactive error */ |
118 |
119 |
/* referenced, but not used */ |
120 |
121 |
122 |
123 |
void |
124 |
wputs(s) /* warning message */ |
125 |
char *s; |
126 |
127 |
if (!nowarn) |
128 |
eputs(s); |
129 |
130 |
131 |
132 |
void |
133 |
eputs(s) /* put string to stderr */ |
134 |
register char *s; |
135 |
136 |
static int inln = 0; |
137 |
138 |
if (!inln++) { |
139 |
fputs(progname, stderr); |
140 |
fputs(": ", stderr); |
141 |
142 |
fputs(s, stderr); |
143 |
if (*s && s[strlen(s)-1] == '\n') |
144 |
inln = 0; |
145 |
146 |
147 |
148 |
addface(cu, obj) /* add a face to a cube */ |
149 |
register CUBE *cu; |
150 |
OBJECT obj; |
151 |
152 |
153 |
if (o_face(objptr(obj), cu) == O_MISS) |
154 |
return; |
155 |
156 |
if (istree(cu->cutree)) { |
157 |
CUBE cukid; /* do children */ |
158 |
int i, j; |
159 |
cukid.cusize = cu->cusize * 0.5; |
160 |
for (i = 0; i < 8; i++) { |
161 |
cukid.cutree = octkid(cu->cutree, i); |
162 |
for (j = 0; j < 3; j++) { |
163 |
cukid.cuorg[j] = cu->cuorg[j]; |
164 |
if ((1<<j) & i) |
165 |
cukid.cuorg[j] += cukid.cusize; |
166 |
167 |
addface(&cukid, obj); |
168 |
octkid(cu->cutree, i) = cukid.cutree; |
169 |
170 |
return; |
171 |
172 |
if (isempty(cu->cutree)) { |
173 |
OBJECT oset[2]; /* singular set */ |
174 |
oset[0] = 1; oset[1] = obj; |
175 |
cu->cutree = fullnode(oset); |
176 |
return; |
177 |
178 |
/* add to full node */ |
179 |
add2full(cu, obj); |
180 |
181 |
182 |
183 |
add2full(cu, obj) /* add object to full node */ |
184 |
185 |
OBJECT obj; |
186 |
187 |
OCTREE ot; |
188 |
OBJECT oset[MAXSET+1]; |
189 |
CUBE cukid; |
190 |
register int i, j; |
191 |
192 |
objset(oset, cu->cutree); |
193 |
194 |
195 |
if (oset[0] < objlim || cukid.cusize < mincusize) { |
196 |
/* add to set */ |
197 |
if (oset[0] >= MAXSET) { |
198 |
sprintf(errmsg, "set overflow in addobject (%s)", |
199 |
objptr(obj)->oname); |
200 |
error(INTERNAL, errmsg); |
201 |
202 |
insertelem(oset, obj); |
203 |
204 |
return; |
205 |
206 |
/* subdivide cube */ |
207 |
if ((ot = octalloc()) == EMPTY) |
208 |
error(SYSTEM, "out of octree space"); |
209 |
/* assign subcubes */ |
210 |
211 |
cukid.cutree = EMPTY; |
212 |
213 |
214 |
if ((1<<j) & i) |
215 |
216 |
217 |
for (j = 1; j <= oset[0]; j++) |
218 |
addface(&cukid, oset[j]); |
219 |
220 |
/* returned node */ |
221 |
octkid(ot, i) = cukid.cutree; |
222 |
223 |
cu->cutree = ot; |
224 |
