root/radiance/ray/src/ot/obj2mesh.c
Mon Feb 6 22:40:21 2023 UTC (2 years, 3 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.16: +6 -6 lines
Diff to previous 2.16 , to selected 2.3
Wed Jul 28 22:16:43 2021 UTC (3 years, 9 months ago) by greg
Changes since 2.15: +3 -12 lines
Diff to previous 2.15 , to selected 2.3
perf(obj2mesh): eliminated unnecessary material file name storage
Fri Mar 3 01:25:27 2017 UTC (8 years, 2 months ago) by greg
Diff to previous 2.14 , to selected 2.3
Added -v option to obj2mesh for reporting mesh statistics
Tue Mar 22 03:56:17 2016 UTC (9 years, 2 months ago) by greg
Diff to previous 2.13 , to selected 2.3
Made error messages more consistent when library file not found
Wed Nov 12 03:54:31 2008 UTC (16 years, 6 months ago) by greg
Diff to previous 2.12 , to selected 2.3
Fixes for Visual Studio compilation
Thu Jul 12 14:58:53 2007 UTC (17 years, 10 months ago) by greg
Diff to previous 2.11 , to selected 2.3
Decreased default -n setting in obj2mesh from 15 to 9
Fri Apr 23 00:56:27 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.10: +16 -1 lines
Diff to previous 2.10 , to selected 2.3
Thu Apr 22 17:35:54 2004 UTC (21 years, 1 month ago) by greg
Diff to previous 2.9 , to selected 2.3
Correction to last change
Thu Apr 22 17:33:48 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.8: +3 -2 lines
Made obj2mesh more robust to set overflow
Sat Mar 27 12:41:45 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.7: +32 -18 lines
Mon Jul 14 05:00:45 2003 UTC (21 years, 10 months ago) by greg
Changes since 2.6: +4 -1 lines
Added better command-line argument checking
Sun Jun 8 12:03:10 2003 UTC (21 years, 11 months ago) by schorsch
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.4: +2 -4 lines
Fri Apr 18 21:47:45 2003 UTC (22 years, 1 month ago) by greg
Removed mesh statistics output line from obj2mesh
Fri Mar 14 21:27:46 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.2: +13 -4 lines
Wed Mar 12 04:59:04 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.1: +17 -7 lines
Tue Mar 11 17:08:55 2003 UTC (22 years, 2 months ago) by greg
Diff to selected 2.3
