--- ray/src/ot/obj2mesh.c 2003/03/11 17:08:55 2.1 +++ ray/src/ot/obj2mesh.c 2003/06/05 19:29:34 2.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: obj2mesh.c,v 2.1 2003/03/11 17:08:55 greg Exp $"; +static const char RCSid[] = "$Id: obj2mesh.c,v 2.5 2003/06/05 19:29:34 schorsch Exp $"; #endif /* * Main program to compile a Wavefront .OBJ file into a Radiance mesh @@ -31,7 +31,9 @@ main(argc, argv) /* compile a .OBJ file into a mesh * int argc; char *argv[]; { - int i; + int nmatf = 0; + char *matinp[32]; + int i, j; progname = argv[0]; ofun[OBJ_FACE].funp = o_face; @@ -44,6 +46,9 @@ char *argv[]; case 'r': /* resolution limit */ resolu = atoi(argv[++i]); break; + case 'a': /* material file */ + matinp[nmatf++] = argv[++i]; + break; case 'w': /* supress warnings */ nowarn = 1; break; @@ -54,8 +59,11 @@ char *argv[]; } /* initialize mesh */ cvinit(i==argc-2 ? argv[i+1] : ""); - - if (i == argc) /* read .OBJ file into triangles */ + /* load material input */ + for (j = 0; j < nmatf; j++) + readobj(matinp[j]); + /* read .OBJ file into triangles */ + if (i == argc) wfreadobj(NULL); else wfreadobj(argv[i]); @@ -65,9 +73,7 @@ char *argv[]; if (i == argc-2) /* open output file */ if (freopen(argv[i+1], "w", stdout) == NULL) error(SYSTEM, "cannot open output file"); -#ifdef MSDOS - setmode(fileno(stdout), O_BINARY); -#endif + SET_FILE_BINARY(stdout); newheader("RADIANCE", stdout); /* new binary file header */ printargs(imcube.cusize / resolu - FTINY; for (i = 0; i < nobjects; i++) /* add triangles to octree */ - addface(&ourmesh->mcube, i); + if (objptr(i)->otype == OBJ_FACE) + addface(&ourmesh->mcube, i); /* optimize octree */ ourmesh->mcube.cutree = combine(ourmesh->mcube.cutree); @@ -88,7 +95,7 @@ char *argv[]; writemesh(ourmesh, stdout); /* write mesh to output */ -printmeshstats(ourmesh, stderr); + /* printmeshstats(ourmesh, stderr); */ quit(0); } @@ -138,16 +145,13 @@ addface(cu, obj) /* add a face to a cube */ register CUBE *cu; OBJECT obj; { - CUBE cukid; - OCTREE ot; - OBJECT oset[MAXSET+1]; - register int i, j; if (o_face(objptr(obj), cu) == O_MISS) return; if (istree(cu->cutree)) { - /* do children */ + CUBE cukid; /* do children */ + int i, j; cukid.cusize = cu->cusize * 0.5; for (i = 0; i < 8; i++) { cukid.cutree = octkid(cu->cutree, i); @@ -162,19 +166,32 @@ OBJECT obj; return; } if (isempty(cu->cutree)) { - /* singular set */ + OBJECT oset[2]; /* singular set */ oset[0] = 1; oset[1] = obj; cu->cutree = fullnode(oset); return; } /* add to full node */ + add2full(cu, obj); +} + + +add2full(cu, obj) /* add object to full node */ +register CUBE *cu; +OBJECT obj; +{ + OCTREE ot; + OBJECT oset[MAXSET+1]; + CUBE cukid; + register int i, j; + objset(oset, cu->cutree); cukid.cusize = cu->cusize * 0.5; if (oset[0] < objlim || cukid.cusize < mincusize) { /* add to set */ if (oset[0] >= MAXSET) { - sprintf(errmsg, "set overflow in addface (%s)", + sprintf(errmsg, "set overflow in addobject (%s)", objptr(obj)->oname); error(INTERNAL, errmsg); }
