| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: obj2mesh.c,v 2.11 2004/04/23 00:56:27 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Main program to compile a Wavefront .OBJ file into a Radiance mesh
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
#include "platform.h"
| 10 |
#include "standard.h"
| 11 |
#include "resolu.h"
| 12 |
#include "cvmesh.h"
| 13 |
#include "otypes.h"
| 14 |
| 15 |
extern int o_face(); /* XXX should go to a header file */
| 16 |
| 17 |
int o_default() { return(O_MISS); }
| 18 |
| 19 |
FUN ofun[NUMOTYPE] = INIT_OTYPE; /* needed for link resolution */
| 20 |
| 21 |
char *progname; /* argv[0] */
| 22 |
| 23 |
int nowarn = 0; /* supress warnings? */
| 24 |
| 25 |
int objlim = 9; /* # of objects before split */
| 26 |
| 27 |
int resolu = 16384; /* octree resolution limit */
| 28 |
| 29 |
double mincusize; /* minimum cube size from resolu */
| 30 |
| 31 |
static void addface(CUBE *cu, OBJECT obj);
| 32 |
static void add2full(CUBE *cu, OBJECT obj);
| 33 |
| 34 |
| 35 |
int
| 36 |
main( /* compile a .OBJ file into a mesh */
| 37 |
int argc,
| 38 |
char *argv[]
| 39 |
| 40 |
| 41 |
int nmatf = 0;
| 42 |
char pathnames[12800];
| 43 |
char *pns = pathnames;
| 44 |
char *matinp[128];
| 45 |
char *cp;
| 46 |
int i, j;
| 47 |
| 48 |
progname = argv[0];
| 49 |
ofun[OBJ_FACE].funp = o_face;
| 50 |
| 51 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 52 |
switch (argv[i][1]) {
| 53 |
case 'n': /* set limit */
| 54 |
objlim = atoi(argv[++i]);
| 55 |
break;
| 56 |
case 'r': /* resolution limit */
| 57 |
resolu = atoi(argv[++i]);
| 58 |
break;
| 59 |
case 'a': /* material file */
| 60 |
matinp[nmatf++] = argv[++i];
| 61 |
break;
| 62 |
case 'l': /* library material */
| 63 |
cp = getpath(argv[++i], getrlibpath(), R_OK);
| 64 |
if (cp == NULL) {
| 65 |
sprintf(errmsg,
| 66 |
"cannot find library material: '%s'",
| 67 |
argv[i]);
| 68 |
error(USER, errmsg);
| 69 |
| 70 |
matinp[nmatf++] = strcpy(pns, cp);
| 71 |
while (*pns++)
| 72 |
| 73 |
break;
| 74 |
case 'w': /* supress warnings */
| 75 |
nowarn = 1;
| 76 |
break;
| 77 |
default:
| 78 |
sprintf(errmsg, "unknown option: '%s'", argv[i]);
| 79 |
| 80 |
break;
| 81 |
| 82 |
| 83 |
if (i < argc-2)
| 84 |
error(USER, "too many file arguments");
| 85 |
/* initialize mesh */
| 86 |
cvinit(i==argc-2 ? argv[i+1] : "<stdout>");
| 87 |
/* load material input */
| 88 |
for (j = 0; j < nmatf; j++)
| 89 |
readobj(matinp[j]);
| 90 |
/* read .OBJ file into triangles */
| 91 |
if (i == argc)
| 92 |
wfreadobj(NULL);
| 93 |
else
| 94 |
wfreadobj(argv[i]);
| 95 |
| 96 |
cvmeshbounds(); /* set octree boundaries */
| 97 |
| 98 |
if (i == argc-2) /* open output file */
| 99 |
if (freopen(argv[i+1], "w", stdout) == NULL)
| 100 |
error(SYSTEM, "cannot open output file");
| 101 |
SET_FILE_BINARY(stdout);
| 102 |
newheader("RADIANCE", stdout); /* new binary file header */
| 103 |
printargs(i<argc ? i+1 : argc, argv, stdout);
| 104 |
fputformat(MESHFMT, stdout);
| 105 |
fputc('\n', stdout);
| 106 |
| 107 |
mincusize = ourmesh->mcube.cusize / resolu - FTINY;
| 108 |
| 109 |
for (i = 0; i < nobjects; i++) /* add triangles to octree */
| 110 |
if (objptr(i)->otype == OBJ_FACE)
| 111 |
addface(&ourmesh->mcube, i);
| 112 |
| 113 |
/* optimize octree */
| 114 |
ourmesh->mcube.cutree = combine(ourmesh->mcube.cutree);
| 115 |
| 116 |
if (ourmesh->mcube.cutree == EMPTY)
| 117 |
error(WARNING, "mesh is empty");
| 118 |
| 119 |
cvmesh(); /* convert mesh and leaf nodes */
| 120 |
| 121 |
writemesh(ourmesh, stdout); /* write mesh to output */
| 122 |
| 123 |
/* printmeshstats(ourmesh, stderr); */
| 124 |
| 125 |
quit(0);
| 126 |
return 0; /* pro forma return */
| 127 |
| 128 |
| 129 |
| 130 |
void
| 131 |
quit( /* exit program */
| 132 |
int code
| 133 |
| 134 |
| 135 |
exit(code);
| 136 |
| 137 |
| 138 |
| 139 |
void
| 140 |
cputs(void) /* interactive error */
| 141 |
| 142 |
/* referenced, but not used */
| 143 |
| 144 |
| 145 |
| 146 |
void
| 147 |
wputs( /* warning message */
| 148 |
char *s
| 149 |
| 150 |
| 151 |
if (!nowarn)
| 152 |
eputs(s);
| 153 |
| 154 |
| 155 |
| 156 |
void
| 157 |
eputs( /* put string to stderr */
| 158 |
register char *s
| 159 |
| 160 |
| 161 |
static int inln = 0;
| 162 |
| 163 |
if (!inln++) {
| 164 |
fputs(progname, stderr);
| 165 |
fputs(": ", stderr);
| 166 |
| 167 |
fputs(s, stderr);
| 168 |
if (*s && s[strlen(s)-1] == '\n')
| 169 |
inln = 0;
| 170 |
| 171 |
| 172 |
| 173 |
static void
| 174 |
addface( /* add a face to a cube */
| 175 |
register CUBE *cu,
| 176 |
OBJECT obj
| 177 |
| 178 |
| 179 |
| 180 |
if (o_face(objptr(obj), cu) == O_MISS)
| 181 |
return;
| 182 |
| 183 |
if (istree(cu->cutree)) {
| 184 |
CUBE cukid; /* do children */
| 185 |
int i, j;
| 186 |
cukid.cusize = cu->cusize * 0.5;
| 187 |
for (i = 0; i < 8; i++) {
| 188 |
cukid.cutree = octkid(cu->cutree, i);
| 189 |
for (j = 0; j < 3; j++) {
| 190 |
cukid.cuorg[j] = cu->cuorg[j];
| 191 |
if ((1<<j) & i)
| 192 |
cukid.cuorg[j] += cukid.cusize;
| 193 |
| 194 |
addface(&cukid, obj);
| 195 |
octkid(cu->cutree, i) = cukid.cutree;
| 196 |
| 197 |
return;
| 198 |
| 199 |
if (isempty(cu->cutree)) {
| 200 |
OBJECT oset[2]; /* singular set */
| 201 |
oset[0] = 1; oset[1] = obj;
| 202 |
cu->cutree = fullnode(oset);
| 203 |
return;
| 204 |
| 205 |
/* add to full node */
| 206 |
add2full(cu, obj);
| 207 |
| 208 |
| 209 |
| 210 |
static void
| 211 |
add2full( /* add object to full node */
| 212 |
register CUBE *cu,
| 213 |
OBJECT obj
| 214 |
| 215 |
| 216 |
OCTREE ot;
| 217 |
OBJECT oset[MAXSET+1];
| 218 |
CUBE cukid;
| 219 |
register int i, j;
| 220 |
| 221 |
objset(oset, cu->cutree);
| 222 |
| 223 |
| 224 |
if (oset[0] < objlim || cukid.cusize <
| 225 |
(oset[0] < MAXSET ? mincusize : mincusize/256.0)) {
| 226 |
/* add to set */
| 227 |
if (oset[0] >= MAXSET) {
| 228 |
sprintf(errmsg, "set overflow in addobject (%s)",
| 229 |
objptr(obj)->oname);
| 230 |
error(INTERNAL, errmsg);
| 231 |
| 232 |
insertelem(oset, obj);
| 233 |
| 234 |
return;
| 235 |
| 236 |
/* subdivide cube */
| 237 |
if ((ot = octalloc()) == EMPTY)
| 238 |
error(SYSTEM, "out of octree space");
| 239 |
/* assign subcubes */
| 240 |
| 241 |
cukid.cutree = EMPTY;
| 242 |
| 243 |
| 244 |
if ((1<<j) & i)
| 245 |
| 246 |
| 247 |
for (j = 1; j <= oset[0]; j++)
| 248 |
addface(&cukid, oset[j]);
| 249 |
| 250 |
/* returned node */
| 251 |
octkid(ot, i) = cukid.cutree;
| 252 |
| 253 |
cu->cutree = ot;
| 254 |
