root/radiance/ray/src/ot/obj2mesh.c
Fri Apr 23 00:56:27 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.10: +16 -1 lines
Thu Apr 22 17:35:54 2004 UTC (21 years, 2 months ago) by greg
Correction to last change
Thu Apr 22 17:33:48 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.8: +3 -2 lines
Made obj2mesh more robust to set overflow
Sat Mar 27 12:41:45 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 2.7: +32 -18 lines
Mon Jul 14 05:00:45 2003 UTC (22 years ago) by greg
Changes since 2.6: +4 -1 lines
Added better command-line argument checking
Sun Jun 8 12:03:10 2003 UTC (22 years, 1 month ago) by schorsch
Thu Jun 5 19:29:34 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.4: +2 -4 lines
Fri Apr 18 21:47:45 2003 UTC (22 years, 3 months ago) by greg
Removed mesh statistics output line from obj2mesh
Fri Mar 14 21:27:46 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.2: +13 -4 lines
Wed Mar 12 04:59:04 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.1: +17 -7 lines
Tue Mar 11 17:08:55 2003 UTC (22 years, 4 months ago) by greg
Diff to selected 2.7
