root/radiance/ray/src/ot/obj2mesh.c
Revision: 2.6
Committed: Sun Jun 8 12:03:10 2003 UTC (22 years, 1 month ago) by schorsch
2 static const char RCSid[] = "$Id: obj2mesh.c,v 2.5 2003/06/05 19:29:34 schorsch Exp $";
5 * Main program to compile a Wavefront .OBJ file into a Radiance mesh
6 */
7
8 #include "copyright.h"
9 #include "platform.h"
10 #include "standard.h"
11 #include "cvmesh.h"
12 #include "otypes.h"
13
14 extern int o_face();
15
16 int o_default() { return(O_MISS); }
17
18 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* needed for link resolution */
19
20 char *progname; /* argv[0] */
21
22 int nowarn = 0; /* supress warnings? */
23
24 int objlim = 15; /* # of objects before split */
25
26 int resolu = 16384; /* octree resolution limit */
27
28 double mincusize; /* minimum cube size from resolu */
29
30
31 main(argc, argv) /* compile a .OBJ file into a mesh */
32 int argc;
33 char *argv[];
34 {
35 int nmatf = 0;
36 char *matinp[32];
37 int i, j;
38
39 progname = argv[0];
40 ofun[OBJ_FACE].funp = o_face;
41
42 for (i = 1; i < argc && argv[i][0] == '-'; i++)
43 switch (argv[i][1]) {
44 case 'n': /* set limit */
45 objlim = atoi(argv[++i]);
46 break;
47 case 'r': /* resolution limit */
48 resolu = atoi(argv[++i]);
49 break;
50 case 'a': /* material file */
51 matinp[nmatf++] = argv[++i];
52 break;
53 case 'w': /* supress warnings */
54 nowarn = 1;
55 break;
56 default:
57 sprintf(errmsg, "unknown option: '%s'", argv[i]);
58 error(USER, errmsg);
59 break;
60 }
61 /* initialize mesh */
62 cvinit(i==argc-2 ? argv[i+1] : "<stdout>");
63 /* load material input */
64 for (j = 0; j < nmatf; j++)
65 readobj(matinp[j]);
66 /* read .OBJ file into triangles */
67 if (i == argc)
68 wfreadobj(NULL);
69 else
70 wfreadobj(argv[i]);
71
72 cvmeshbounds(); /* set octree boundaries */
73
74 if (i == argc-2) /* open output file */
75 if (freopen(argv[i+1], "w", stdout) == NULL)
76 error(SYSTEM, "cannot open output file");
77 SET_FILE_BINARY(stdout);
78 newheader("RADIANCE", stdout); /* new binary file header */
79 printargs(i<argc ? i+1 : argc, argv, stdout);
80 fputformat(MESHFMT, stdout);
81 fputc('\n', stdout);
82
83 mincusize = ourmesh->mcube.cusize / resolu - FTINY;
84
85 for (i = 0; i < nobjects; i++) /* add triangles to octree */
86 if (objptr(i)->otype == OBJ_FACE)
87 addface(&ourmesh->mcube, i);
88
89 /* optimize octree */
90 ourmesh->mcube.cutree = combine(ourmesh->mcube.cutree);
91
92 if (ourmesh->mcube.cutree == EMPTY)
93 error(WARNING, "mesh is empty");
94
95 cvmesh(); /* convert mesh and leaf nodes */
96
97 writemesh(ourmesh, stdout); /* write mesh to output */
98
99 /* printmeshstats(ourmesh, stderr); */
100
101 quit(0);
102 }
103
104
105 void
106 quit(code) /* exit program */
107 int code;
108 {
109 exit(code);
110 }
111
112
113 void
114 cputs() /* interactive error */
115 {
116 /* referenced, but not used */
117 }
118
119
120 void
121 wputs(s) /* warning message */
122 char *s;
123 {
124 if (!nowarn)
125 eputs(s);
126 }
127
128
129 void
130 eputs(s) /* put string to stderr */
131 register char *s;
132 {
133 static int inln = 0;
134
135 if (!inln++) {
136 fputs(progname, stderr);
137 fputs(": ", stderr);
138 }
139 fputs(s, stderr);
140 if (*s && s[strlen(s)-1] == '\n')
141 inln = 0;
142 }
143
144
145 addface(cu, obj) /* add a face to a cube */
146 register CUBE *cu;
147 OBJECT obj;
148 {
149
150 if (o_face(objptr(obj), cu) == O_MISS)
151 return;
152
153 if (istree(cu->cutree)) {
154 CUBE cukid; /* do children */
155 int i, j;
156 cukid.cusize = cu->cusize * 0.5;
157 for (i = 0; i < 8; i++) {
158 cukid.cutree = octkid(cu->cutree, i);
159 for (j = 0; j < 3; j++) {
160 cukid.cuorg[j] = cu->cuorg[j];
161 if ((1<<j) & i)
162 cukid.cuorg[j] += cukid.cusize;
163 }
164 addface(&cukid, obj);
165 octkid(cu->cutree, i) = cukid.cutree;
166 }
167 return;
168 }
169 if (isempty(cu->cutree)) {
170 OBJECT oset[2]; /* singular set */
171 oset[0] = 1; oset[1] = obj;
172 cu->cutree = fullnode(oset);
173 return;
174 }
175 /* add to full node */
176 add2full(cu, obj);
177 }
178
179
180 add2full(cu, obj) /* add object to full node */
181 register CUBE *cu;
182 OBJECT obj;
183 {
184 OCTREE ot;
185 OBJECT oset[MAXSET+1];
186 CUBE cukid;
187 register int i, j;
188
189 objset(oset, cu->cutree);
190 cukid.cusize = cu->cusize * 0.5;
191
192 if (oset[0] < objlim || cukid.cusize < mincusize) {
193 /* add to set */
194 if (oset[0] >= MAXSET) {
195 sprintf(errmsg, "set overflow in addobject (%s)",
196 objptr(obj)->oname);
197 error(INTERNAL, errmsg);
198 }
199 insertelem(oset, obj);
200 cu->cutree = fullnode(oset);
201 return;
202 }
203 /* subdivide cube */
204 if ((ot = octalloc()) == EMPTY)
205 error(SYSTEM, "out of octree space");
206 /* assign subcubes */
207 for (i = 0; i < 8; i++) {
208 cukid.cutree = EMPTY;
209 for (j = 0; j < 3; j++) {
210 cukid.cuorg[j] = cu->cuorg[j];
211 if ((1<<j) & i)
212 cukid.cuorg[j] += cukid.cusize;
213 }
214 for (j = 1; j <= oset[0]; j++)
215 addface(&cukid, oset[j]);
216 addface(&cukid, obj);
217 /* returned node */
218 octkid(ot, i) = cukid.cutree;
219 }
220 cu->cutree = ot;
221 }
