--- ray/src/ot/obj2mesh.c 2003/07/14 05:00:45 2.7 +++ ray/src/ot/obj2mesh.c 2004/04/22 17:35:54 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: obj2mesh.c,v 2.7 2003/07/14 05:00:45 greg Exp $"; +static const char RCSid[] = "$Id: obj2mesh.c,v 2.10 2004/04/22 17:35:54 greg Exp $"; #endif /* * Main program to compile a Wavefront .OBJ file into a Radiance mesh @@ -8,10 +8,11 @@ static const char RCSid[] = "$Id: obj2mesh.c,v 2.7 200 #include "copyright.h" #include "platform.h" #include "standard.h" +#include "resolu.h" #include "cvmesh.h" #include "otypes.h" -extern int o_face(); +extern int o_face(); /* XXX should go to a header file */ int o_default() { return(O_MISS); } @@ -27,10 +28,15 @@ int resolu = 16384; /* octree resolution limit */ double mincusize; /* minimum cube size from resolu */ +static void addface(CUBE *cu, OBJECT obj); +static void add2full(CUBE *cu, OBJECT obj); -main(argc, argv) /* compile a .OBJ file into a mesh */ -int argc; -char *argv[]; + +int +main( /* compile a .OBJ file into a mesh */ + int argc, + char *argv[] +) { int nmatf = 0; char *matinp[32]; @@ -102,27 +108,30 @@ char *argv[]; /* printmeshstats(ourmesh, stderr); */ quit(0); + return 0; /* pro forma return */ } void -quit(code) /* exit program */ -int code; +quit( /* exit program */ + int code +) { exit(code); } void -cputs() /* interactive error */ +cputs(void) /* interactive error */ { /* referenced, but not used */ } void -wputs(s) /* warning message */ -char *s; +wputs( /* warning message */ + char *s +) { if (!nowarn) eputs(s); @@ -130,8 +139,9 @@ char *s; void -eputs(s) /* put string to stderr */ -register char *s; +eputs( /* put string to stderr */ + register char *s +) { static int inln = 0; @@ -145,9 +155,11 @@ register char *s; } -addface(cu, obj) /* add a face to a cube */ -register CUBE *cu; -OBJECT obj; +static void +addface( /* add a face to a cube */ + register CUBE *cu, + OBJECT obj +) { if (o_face(objptr(obj), cu) == O_MISS) @@ -180,9 +192,11 @@ OBJECT obj; } -add2full(cu, obj) /* add object to full node */ -register CUBE *cu; -OBJECT obj; +static void +add2full( /* add object to full node */ + register CUBE *cu, + OBJECT obj +) { OCTREE ot; OBJECT oset[MAXSET+1]; @@ -192,7 +206,8 @@ OBJECT obj; objset(oset, cu->cutree); cukid.cusize = cu->cusize * 0.5; - if (oset[0] < objlim || cukid.cusize < mincusize) { + if (oset[0] < objlim || cukid.cusize < + (oset[0] < MAXSET ? mincusize : mincusize/256.0)) { /* add to set */ if (oset[0] >= MAXSET) { sprintf(errmsg, "set overflow in addobject (%s)",
