1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: obj2mesh.c,v 2.18 2025/06/03 21:31:51 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Main program to compile a Wavefront .OBJ file into a Radiance mesh |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "platform.h" |
11 |
#include "standard.h" |
12 |
#include "resolu.h" |
13 |
#include "cvmesh.h" |
14 |
#include "otypes.h" |
15 |
16 |
extern int o_face(); /* XXX should go to a header file */ |
17 |
18 |
int o_default() { return(O_MISS); } |
19 |
20 |
FUN ofun[NUMOTYPE] = INIT_OTYPE; /* needed for link resolution */ |
21 |
22 |
int nowarn = 0; /* supress warnings? */ |
23 |
24 |
int objlim = 9; /* # of objects before split */ |
25 |
26 |
int resolu = 16384; /* octree resolution limit */ |
27 |
28 |
double mincusize; /* minimum cube size from resolu */ |
29 |
30 |
static void addface(CUBE *cu, OBJECT obj); |
31 |
static void add2full(CUBE *cu, OBJECT obj); |
32 |
33 |
34 |
int |
35 |
main( /* compile a .OBJ file into a mesh */ |
36 |
int argc, |
37 |
char *argv[] |
38 |
39 |
40 |
int verbose = 0; |
41 |
char *cp; |
42 |
int i, j; |
43 |
44 |
fixargv0(argv[0]); /* sets global progname */ |
45 |
46 |
ofun[OBJ_FACE].funp = o_face; |
47 |
48 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
49 |
switch (argv[i][1]) { |
50 |
case 'n': /* set limit */ |
51 |
objlim = atoi(argv[++i]); |
52 |
break; |
53 |
case 'r': /* resolution limit */ |
54 |
resolu = atoi(argv[++i]); |
55 |
break; |
56 |
case 'a': /* material file */ |
57 |
readobj(argv[++i]); |
58 |
break; |
59 |
case 'l': /* library material */ |
60 |
cp = getpath(argv[++i], getrlibpath(), R_OK); |
61 |
if (cp == NULL) { |
62 |
sprintf(errmsg, |
63 |
"cannot find library material: '%s'", |
64 |
argv[i]); |
65 |
error(SYSTEM, errmsg); |
66 |
67 |
readobj(cp); |
68 |
break; |
69 |
case 'w': /* supress warnings */ |
70 |
nowarn = 1; |
71 |
break; |
72 |
case 'v': /* print mesh stats */ |
73 |
verbose = 1; |
74 |
break; |
75 |
default: |
76 |
sprintf(errmsg, "unknown option: '%s'", argv[i]); |
77 |
error(USER, errmsg); |
78 |
break; |
79 |
80 |
81 |
if (i < argc-2) |
82 |
error(USER, "too many file arguments"); |
83 |
/* initialize mesh */ |
84 |
cvinit(i==argc-2 ? argv[i+1] : "<stdout>"); |
85 |
/* read .OBJ file into triangles */ |
86 |
if (i == argc) |
87 |
wfreadobj(NULL); |
88 |
else |
89 |
wfreadobj(argv[i]); |
90 |
91 |
cvmeshbounds(); /* set octree boundaries */ |
92 |
93 |
if (i == argc-2) /* open output file */ |
94 |
if (freopen(argv[i+1], "w", stdout) == NULL) |
95 |
error(SYSTEM, "cannot open output file"); |
96 |
SET_FILE_BINARY(stdout); |
97 |
newheader("RADIANCE", stdout); /* new binary file header */ |
98 |
printargs(i<argc ? i+1 : argc, argv, stdout); |
99 |
fputformat(MESHFMT, stdout); |
100 |
fputc('\n', stdout); |
101 |
102 |
mincusize = ourmesh->mcube.cusize / resolu - FTINY; |
103 |
104 |
for (i = 0; i < nobjects; i++) /* add triangles to octree */ |
105 |
if (objptr(i)->otype == OBJ_FACE) |
106 |
addface(&ourmesh->mcube, i); |
107 |
108 |
/* optimize octree */ |
109 |
ourmesh->mcube.cutree = combine(ourmesh->mcube.cutree); |
110 |
111 |
if (ourmesh->mcube.cutree == EMPTY) |
112 |
error(WARNING, "mesh is empty"); |
113 |
114 |
cvmesh(); /* convert mesh and leaf nodes */ |
115 |
116 |
writemesh(ourmesh, stdout); /* write mesh to output */ |
117 |
118 |
if (verbose) |
119 |
printmeshstats(ourmesh, stderr); |
120 |
121 |
quit(0); |
122 |
return 0; /* pro forma return */ |
123 |
124 |
125 |
126 |
void |
127 |
quit( /* exit program */ |
128 |
int code |
129 |
130 |
131 |
exit(code); |
132 |
133 |
134 |
135 |
void |
136 |
cputs(void) /* interactive error */ |
137 |
138 |
/* referenced, but not used */ |
139 |
140 |
141 |
142 |
void |
143 |
wputs( /* warning message */ |
144 |
const char *s |
145 |
146 |
147 |
if (!nowarn) |
148 |
eputs(s); |
149 |
150 |
151 |
152 |
void |
153 |
eputs( /* put string to stderr */ |
154 |
const char *s |
155 |
156 |
157 |
static int inln = 0; |
158 |
159 |
if (!inln++) { |
160 |
fputs(progname, stderr); |
161 |
fputs(": ", stderr); |
162 |
163 |
fputs(s, stderr); |
164 |
if (*s && s[strlen(s)-1] == '\n') |
165 |
inln = 0; |
166 |
167 |
168 |
169 |
static void |
170 |
addface( /* add a face to a cube */ |
171 |
CUBE *cu, |
172 |
OBJECT obj |
173 |
174 |
175 |
176 |
if (o_face(objptr(obj), cu) == O_MISS) |
177 |
return; |
178 |
179 |
if (istree(cu->cutree)) { |
180 |
CUBE cukid; /* do children */ |
181 |
int i, j; |
182 |
cukid.cusize = cu->cusize * 0.5; |
183 |
for (i = 0; i < 8; i++) { |
184 |
cukid.cutree = octkid(cu->cutree, i); |
185 |
for (j = 0; j < 3; j++) { |
186 |
cukid.cuorg[j] = cu->cuorg[j]; |
187 |
if ((1<<j) & i) |
188 |
cukid.cuorg[j] += cukid.cusize; |
189 |
190 |
addface(&cukid, obj); |
191 |
octkid(cu->cutree, i) = cukid.cutree; |
192 |
193 |
return; |
194 |
195 |
if (isempty(cu->cutree)) { |
196 |
OBJECT oset[2]; /* singular set */ |
197 |
oset[0] = 1; oset[1] = obj; |
198 |
cu->cutree = fullnode(oset); |
199 |
return; |
200 |
201 |
/* add to full node */ |
202 |
add2full(cu, obj); |
203 |
204 |
205 |
206 |
static void |
207 |
add2full( /* add object to full node */ |
208 |
CUBE *cu, |
209 |
OBJECT obj |
210 |
211 |
212 |
OCTREE ot; |
213 |
OBJECT oset[MAXSET+1]; |
214 |
CUBE cukid; |
215 |
int i, j; |
216 |
217 |
objset(oset, cu->cutree); |
218 |
219 |
220 |
if (oset[0] < objlim || cukid.cusize < |
221 |
(oset[0] < MAXSET ? mincusize : mincusize/256.0)) { |
222 |
/* add to set */ |
223 |
if (oset[0] >= MAXSET) { |
224 |
sprintf(errmsg, "set overflow in addobject (%s)", |
225 |
objptr(obj)->oname); |
226 |
error(INTERNAL, errmsg); |
227 |
228 |
insertelem(oset, obj); |
229 |
230 |
return; |
231 |
232 |
/* subdivide cube */ |
233 |
if ((ot = octalloc()) == EMPTY) |
234 |
error(SYSTEM, "out of octree space"); |
235 |
/* assign subcubes */ |
236 |
237 |
cukid.cutree = EMPTY; |
238 |
239 |
240 |
if ((1<<j) & i) |
241 |
242 |
243 |
for (j = 1; j <= oset[0]; j++) |
244 |
addface(&cukid, oset[j]); |
245 |
246 |
/* returned node */ |
247 |
octkid(ot, i) = cukid.cutree; |
248 |
249 |
cu->cutree = ot; |
250 |
