1 |
/* Copyright (c) 1988 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* o_instance.c - routines for creating octrees for other octrees. |
9 |
10 |
* 11/11/88 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "object.h" |
16 |
17 |
#include "instance.h" |
18 |
19 |
#include "plocate.h" |
20 |
21 |
22 |
* To determine if two cubes intersect: |
23 |
24 |
* 1) Check to see if any vertices of first cube are inside the |
25 |
* second (intersection). |
26 |
27 |
* 2) Check to see if all vertices of first are to one side of |
28 |
* second (no intersection). |
29 |
30 |
* 3) Perform 1 and 2 with roles reversed. |
31 |
32 |
* 4) Check to see if any portion of any edge of second is inside |
33 |
* first (intersection). |
34 |
35 |
* 5) If test 4 fails, we have no intersection. |
36 |
37 |
* Note that if we were testing two boxes, we would need |
38 |
* to check that neither had any edges inside the other to be sure. |
39 |
* Since an octree is a volume rather than a surface, we will |
40 |
* return a value of 2 if the cube is entirely within the octree. |
41 |
42 |
43 |
44 |
o_instance(o, cu) /* determine if cubes intersect */ |
45 |
OBJREC *o; |
46 |
CUBE *cu; |
47 |
48 |
static int vstart[4] = {0, 3, 5, 6}; |
49 |
FVECT cumin, cumax; |
50 |
FVECT vert[8]; |
51 |
FVECT v1, v2; |
52 |
register INSTANCE *in; |
53 |
int vloc, vout; |
54 |
register int i, j; |
55 |
/* get octree arguments */ |
56 |
in = getinstance(o, GET_BOUNDS); |
57 |
/* check if cube vertex in octree */ |
58 |
for (j = 0; j < 3; j++) |
59 |
cumax[j] = (cumin[j] = in->obj->scube.cuorg[j]) + |
60 |
in->obj->scube.cusize; |
61 |
vloc = ABOVE | BELOW; |
62 |
vout = 0; |
63 |
for (i = 0; i < 8; i++) { |
64 |
for (j = 0; j < 3; j++) { |
65 |
v1[j] = cu->cuorg[j]; |
66 |
if (i & 1<<j) |
67 |
v1[j] += cu->cusize; |
68 |
69 |
multp3(v2, v1, in->b.xfm); |
70 |
if (j = plocate(v2, cumin, cumax)) |
71 |
vout++; |
72 |
vloc &= j; |
73 |
74 |
if (vout == 0) /* all inside */ |
75 |
return(O_IN); |
76 |
if (vout < 8) /* some inside */ |
77 |
return(O_HIT); |
78 |
if (vloc) /* all to one side */ |
79 |
return(O_MISS); |
80 |
/* octree vertices in cube? */ |
81 |
82 |
cumax[j] = (cumin[j] = cu->cuorg[j]) + cu->cusize; |
83 |
84 |
85 |
86 |
v1[j] = in->obj->scube.cuorg[j]; |
87 |
if (i & 1<<j) |
88 |
v1[j] += in->obj->scube.cusize; |
89 |
90 |
multp3(vert[i], v1, in->f.xfm); |
91 |
if (j = plocate(vert[i], cumin, cumax)) |
92 |
vloc &= j; |
93 |
else |
94 |
return(O_HIT); /* vertex inside */ |
95 |
96 |
97 |
return(O_MISS); |
98 |
/* check edges */ |
99 |
for (i = 0; i < 4; i++) |
100 |
101 |
/* clip modifies vertices! */ |
102 |
VCOPY(v1, vert[vstart[i]]); |
103 |
VCOPY(v2, vert[vstart[i] ^ 1<<j]); |
104 |
if (clip(v1, v2, cumin, cumax)) |
105 |
return(O_HIT); /* edge inside */ |
106 |
107 |
108 |
return(O_MISS); /* no intersection */ |
109 |
