--- ray/src/ot/o_instance.c 1989/02/02 10:33:04 1.1 +++ ray/src/ot/o_instance.c 1989/10/14 11:19:33 1.3 @@ -45,7 +45,7 @@ o_instance(o, cu) /* determine if cubes intersect */ OBJREC *o; CUBE *cu; { - static char vstart[4] = {0, 3, 5, 6}; + static int vstart[4] = {0, 3, 5, 6}; FVECT cumin, cumax; FVECT vert[8]; FVECT v1, v2; @@ -72,11 +72,11 @@ CUBE *cu; vloc &= j; } if (vout == 0) /* all inside */ - return(2); + return(O_IN); if (vout < 8) /* some inside */ - return(1); + return(O_HIT); if (vloc) /* all to one side */ - return(0); + return(O_MISS); /* octree vertices in cube? */ for (j = 0; j < 3; j++) cumax[j] = (cumin[j] = cu->cuorg[j]) + cu->cusize; @@ -91,10 +91,10 @@ CUBE *cu; if (j = plocate(vert[i], cumin, cumax)) vloc &= j; else - return(1); /* vertex inside */ + return(O_HIT); /* vertex inside */ } if (vloc) /* all to one side */ - return(0); + return(O_MISS); /* check edges */ for (i = 0; i < 4; i++) for (j = 0; j < 3; j++) { @@ -102,8 +102,8 @@ CUBE *cu; VCOPY(v1, vert[vstart[i]]); VCOPY(v2, vert[vstart[i] ^ 1<
