root/radiance/ray/src/ot/o_instance.c
Tue Mar 30 16:13:00 2004 UTC (21 years, 1 month ago) by schorsch
CVS Tags: HEAD, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.5: +1 -3 lines
Sat Mar 27 12:41:45 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.4: +19 -11 lines
Sun Jul 27 22:12:03 2003 UTC (21 years, 9 months ago) by schorsch
Tue Mar 11 17:08:55 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.2: +39 -15 lines
Sat Feb 22 02:07:26 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.1: +3 -4 lines
Diff to previous 2.1
Tue Nov 12 17:00:49 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.7 , to selected 2.2
Sat Jan 5 09:41:26 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.6 , to selected 2.2
fixed error introduced in 1.6
Sat Dec 15 19:55:05 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.5 , to selected 2.2
increased bounds of test cube by FTINY
Sat Dec 15 15:23:58 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.4: +3 -3 lines
added XF and FULLXF types
Tue Oct 24 13:57:42 1989 UTC (35 years, 6 months ago) by greg
changed GET_ macro to IO_
Sat Oct 14 11:19:33 1989 UTC (35 years, 6 months ago) by greg
Changes since 1.2: +7 -7 lines
Fri Oct 13 20:08:08 1989 UTC (35 years, 6 months ago) by greg
changed type of static variable for efficiency
Thu Feb 2 10:33:04 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 2.2
