root/radiance/ray/src/ot/o_instance.c
Revision: 2.6
Committed: Tue Mar 30 16:13:00 2004 UTC (21 years, 4 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
Changes since 2.5: +1 -3 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.6 static const char RCSid[] = "$Id: o_instance.c,v 2.5 2004/03/27 12:41:45 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5 greg 2.3 * o_instance.c - routines for creating octrees for other octrees
6 greg 1.1 */
7
8     #include "standard.h"
9
10     #include "object.h"
11 greg 2.2
12     #include "octree.h"
13 greg 1.1
14     #include "instance.h"
15
16 greg 2.3 #include "mesh.h"
17
18 greg 1.1 #include "plocate.h"
19
20     /*
21     * To determine if two cubes intersect:
22     *
23     * 1) Check to see if any vertices of first cube are inside the
24     * second (intersection).
25     *
26     * 2) Check to see if all vertices of first are to one side of
27     * second (no intersection).
28     *
29     * 3) Perform 1 and 2 with roles reversed.
30     *
31     * 4) Check to see if any portion of any edge of second is inside
32     * first (intersection).
33     *
34     * 5) If test 4 fails, we have no intersection.
35     *
36     * Note that if we were testing two boxes, we would need
37     * to check that neither had any edges inside the other to be sure.
38     * Since an octree is a volume rather than a surface, we will
39     * return a value of 2 if the cube is entirely within the octree.
40     */
41
42
43 schorsch 2.5 static int o_cube(CUBE *cu1, FULLXF *fxf, CUBE *cu);
44
45
46 greg 2.3 static int
47 schorsch 2.5 o_cube( /* determine if cubes intersect */
48     CUBE *cu1,
49     FULLXF *fxf,
50     CUBE *cu
51     )
52 greg 1.1 {
53 greg 1.2 static int vstart[4] = {0, 3, 5, 6};
54 greg 1.1 FVECT cumin, cumax;
55     FVECT vert[8];
56     FVECT v1, v2;
57     int vloc, vout;
58     register int i, j;
59     /* check if cube vertex in octree */
60     for (j = 0; j < 3; j++)
61 greg 2.3 cumax[j] = (cumin[j] = cu1->cuorg[j]) + cu1->cusize;
62 greg 1.1 vloc = ABOVE | BELOW;
63     vout = 0;
64     for (i = 0; i < 8; i++) {
65     for (j = 0; j < 3; j++) {
66     v1[j] = cu->cuorg[j];
67     if (i & 1<<j)
68     v1[j] += cu->cusize;
69     }
70 greg 2.3 multp3(v2, v1, fxf->b.xfm);
71 schorsch 2.4 if ( (j = plocate(v2, cumin, cumax)) )
72 greg 1.1 vout++;
73     vloc &= j;
74     }
75     if (vout == 0) /* all inside */
76 greg 1.3 return(O_IN);
77 greg 1.1 if (vout < 8) /* some inside */
78 greg 1.3 return(O_HIT);
79 greg 1.1 if (vloc) /* all to one side */
80 greg 1.3 return(O_MISS);
81 greg 1.1 /* octree vertices in cube? */
82     for (j = 0; j < 3; j++)
83     cumax[j] = (cumin[j] = cu->cuorg[j]) + cu->cusize;
84     vloc = ABOVE | BELOW;
85     for (i = 0; i < 8; i++) {
86     for (j = 0; j < 3; j++) {
87 greg 2.3 v1[j] = cu1->cuorg[j];
88 greg 1.1 if (i & 1<<j)
89 greg 2.3 v1[j] += cu1->cusize;
90 greg 1.1 }
91 greg 2.3 multp3(vert[i], v1, fxf->f.xfm);
92 schorsch 2.4 if ( (j = plocate(vert[i], cumin, cumax)) )
93 greg 1.1 vloc &= j;
94     else
95 greg 1.3 return(O_HIT); /* vertex inside */
96 greg 1.1 }
97     if (vloc) /* all to one side */
98 greg 1.3 return(O_MISS);
99 greg 1.1 /* check edges */
100     for (i = 0; i < 4; i++)
101     for (j = 0; j < 3; j++) {
102     /* clip modifies vertices! */
103     VCOPY(v1, vert[vstart[i]]);
104     VCOPY(v2, vert[vstart[i] ^ 1<<j]);
105     if (clip(v1, v2, cumin, cumax))
106 greg 1.3 return(O_HIT); /* edge inside */
107 greg 1.1 }
108
109 greg 1.3 return(O_MISS); /* no intersection */
110 greg 2.3 }
111
112
113     int
114 schorsch 2.5 o_instance( /* determine if instance intersects */
115     OBJREC *o,
116     CUBE *cu
117     )
118 greg 2.3 {
119     INSTANCE *ins;
120     /* get octree bounds */
121     ins = getinstance(o, IO_BOUNDS);
122     /* call o_cube to do the work */
123     return(o_cube(&ins->obj->scube, &ins->x, cu));
124     }
125
126
127     int
128 schorsch 2.5 o_mesh( /* determine if mesh intersects */
129     OBJREC *o,
130     CUBE *cu
131     )
132 greg 2.3 {
133     MESHINST *mip;
134     /* get mesh bounds */
135     mip = getmeshinst(o, IO_BOUNDS);
136     /* call o_cube to do the work */
137     return(o_cube(&mip->msh->mcube, &mip->x, cu));
138 greg 1.1 }
