1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* o_face.c - routines for creating octrees for polygonal faces. |
9 |
10 |
* 8/27/85 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "octree.h" |
16 |
17 |
#include "object.h" |
18 |
19 |
#include "face.h" |
20 |
21 |
#include "plocate.h" |
22 |
23 |
24 |
* The algorithm for determining a face's intersection |
25 |
* with a cube is relatively straightforward: |
26 |
27 |
* 1) Check to see if any vertices are inside the cube |
28 |
* (intersection). |
29 |
30 |
* 2) Check to see if all vertices are to one side of |
31 |
* cube (no intersection). |
32 |
33 |
* 3) Check to see if any portion of any edge is inside |
34 |
* cube (intersection). |
35 |
36 |
* 4) Check to see if the cube cuts the plane of the |
37 |
* face and one of its edges passes through |
38 |
* the face (intersection). |
39 |
40 |
* 5) If test 4 fails, we have no intersection. |
41 |
42 |
43 |
44 |
o_face(o, cu) /* determine if face intersects cube */ |
45 |
OBJREC *o; |
46 |
CUBE *cu; |
47 |
48 |
FVECT cumin, cumax; |
49 |
FVECT v1, v2; |
50 |
double d1, d2; |
51 |
int vloc; |
52 |
register FACE *f; |
53 |
register int i, j; |
54 |
/* get face arguments */ |
55 |
f = getface(o); |
56 |
if (f->area == 0.0) /* empty face */ |
57 |
return(0); |
58 |
/* compute cube boundaries */ |
59 |
for (j = 0; j < 3; j++) |
60 |
cumax[j] = (cumin[j] = cu->cuorg[j]) + cu->cusize; |
61 |
62 |
vloc = ABOVE | BELOW; /* check vertices */ |
63 |
for (i = 0; i < f->nv; i++) |
64 |
if (j = plocate(VERTEX(f,i), cumin, cumax)) |
65 |
vloc &= j; |
66 |
else |
67 |
return(1); /* vertex inside */ |
68 |
69 |
if (vloc) /* all to one side */ |
70 |
return(0); |
71 |
72 |
for (i = 0; i < f->nv; i++) { /* check edges */ |
73 |
if ((j = i + 1) >= f->nv) |
74 |
j = 0; /* wrap around */ |
75 |
VCOPY(v1, VERTEX(f,i)); /* clip modifies */ |
76 |
VCOPY(v2, VERTEX(f,j)); /* the vertices! */ |
77 |
if (clip(v1, v2, cumin, cumax)) |
78 |
return(1); /* edge inside */ |
79 |
80 |
/* see if cube cuts plane */ |
81 |
82 |
if (f->norm[j] > 0.0) { |
83 |
v1[j] = cumin[j]; |
84 |
v2[j] = cumax[j]; |
85 |
} else { |
86 |
v1[j] = cumax[j]; |
87 |
v2[j] = cumin[j]; |
88 |
89 |
if ((d1 = DOT(v1, f->norm) - f->const) > FTINY) |
90 |
return(0); |
91 |
if ((d2 = DOT(v2, f->norm) - f->const) < -FTINY) |
92 |
return(0); |
93 |
/* intersect face */ |
94 |
95 |
v1[j] = (v1[j]*d2 - v2[j]*d1)/(d2 - d1); |
96 |
if (inface(v1, f)) |
97 |
return(1); |
98 |
99 |
return(0); /* no intersection */ |
100 |
