root/radiance/ray/src/ot/o_face.c
Tue Mar 30 16:13:00 2004 UTC (21 years, 2 months ago) by schorsch
CVS Tags: HEAD, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Sat Mar 27 12:41:45 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.3: +7 -5 lines
Sat Feb 22 02:07:26 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.1: +1 -4 lines
Diff to previous 2.1
Tue Nov 12 17:00:53 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.4
Fri Dec 14 08:32:54 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.3: +2 -1 lines
added epsilon to cube size for testing
Sat Oct 14 11:19:32 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.2: +8 -8 lines
Tue Feb 21 14:44:49 1989 UTC (36 years, 3 months ago) by greg
portability fixes
Thu Feb 2 10:33:03 1989 UTC (36 years, 4 months ago) by greg
Diff to selected 2.1
