| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: o_cone.c,v 2.4 2004/03/30 16:13:00 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* o_cone.c - routines for intersecting cubes with cones.
| 6 |
| 7 |
* 2/3/86
| 8 |
| 9 |
| 10 |
#include "standard.h"
| 11 |
#include "octree.h"
| 12 |
#include "object.h"
| 13 |
#include "cone.h"
| 14 |
| 15 |
#define ROOT3 1.732050808
| 16 |
| 17 |
| 18 |
* The algorithm used to detect cube intersection with cones is
| 19 |
* recursive. First, we approximate the cube to be a sphere. Then
| 20 |
* we test for cone intersection with the sphere by testing the
| 21 |
* segment of the cone which is nearest the sphere's center.
| 22 |
* If the cone has points within the cube's bounding sphere,
| 23 |
* we must check for intersection with the cube. This is done with
| 24 |
* the 3D line clipper. The same cone segment is used in this test.
| 25 |
* If the clip fails, we still cannot be sure there is no intersection,
| 26 |
* so we subdivide the cube and recurse.
| 27 |
* If none of the sub-cubes intersect, then our cube does not intersect.
| 28 |
| 29 |
| 30 |
extern double mincusize; /* minimum cube size */
| 31 |
| 32 |
static int findcseg(FVECT ep0, FVECT ep1, CONE *co, FVECT p);
| 33 |
| 34 |
| 35 |
| 36 |
extern int
| 37 |
o_cone( /* determine if cone intersects cube */
| 38 |
OBJREC *o,
| 39 |
register CUBE *cu
| 40 |
| 41 |
| 42 |
CONE *co;
| 43 |
FVECT ep0, ep1;
| 44 |
#ifdef STRICT
| 45 |
FVECT cumin, cumax;
| 46 |
CUBE cukid;
| 47 |
register int j;
| 48 |
#endif
| 49 |
double r;
| 50 |
FVECT p;
| 51 |
register int i;
| 52 |
/* get cone arguments */
| 53 |
co = getcone(o, 0);
| 54 |
/* get cube center */
| 55 |
r = cu->cusize * 0.5;
| 56 |
for (i = 0; i < 3; i++)
| 57 |
p[i] = cu->cuorg[i] + r;
| 58 |
r *= ROOT3; /* bounding radius for cube */
| 59 |
| 60 |
if (findcseg(ep0, ep1, co, p)) {
| 61 |
/* check min. distance to cone */
| 62 |
if (dist2lseg(p, ep0, ep1) > (r+FTINY)*(r+FTINY))
| 63 |
return(O_MISS);
| 64 |
#ifdef STRICT
| 65 |
/* get cube boundaries */
| 66 |
| 67 |
cumax[i] = (cumin[i] = cu->cuorg[i]) + cu->cusize;
| 68 |
/* closest segment intersects? */
| 69 |
if (clip(ep0, ep1, cumin, cumax))
| 70 |
return(O_HIT);
| 71 |
| 72 |
/* check sub-cubes */
| 73 |
cukid.cusize = cu->cusize * 0.5;
| 74 |
if (cukid.cusize < mincusize)
| 75 |
return(O_HIT); /* cube too small */
| 76 |
cukid.cutree = EMPTY;
| 77 |
| 78 |
for (j = 0; j < 8; j++) {
| 79 |
for (i = 0; i < 3; i++) {
| 80 |
cukid.cuorg[i] = cu->cuorg[i];
| 81 |
if (1<<i & j)
| 82 |
cukid.cuorg[i] += cukid.cusize;
| 83 |
| 84 |
if (o_cone(o, &cukid))
| 85 |
return(O_HIT); /* sub-cube intersects */
| 86 |
| 87 |
return(O_MISS); /* no intersection */
| 88 |
#else
| 89 |
| 90 |
return(O_HIT); /* assume intersection */
| 91 |
#endif
| 92 |
| 93 |
| 94 |
| 95 |
static int
| 96 |
findcseg( /* find line segment from cone closest to p */
| 97 |
FVECT ep0,
| 98 |
FVECT ep1,
| 99 |
register CONE *co,
| 100 |
FVECT p
| 101 |
| 102 |
| 103 |
double d;
| 104 |
FVECT v;
| 105 |
register int i;
| 106 |
/* find direction from axis to point */
| 107 |
VSUB(v, p, CO_P0(co));
| 108 |
d = DOT(v, co->ad);
| 109 |
| 110 |
v[i] -= d*co->ad[i];
| 111 |
if (normalize(v) == 0.0)
| 112 |
return(0);
| 113 |
/* find endpoints of segment */
| 114 |
| 115 |
ep0[i] = CO_R0(co)*v[i] + CO_P0(co)[i];
| 116 |
ep1[i] = CO_R1(co)*v[i] + CO_P1(co)[i];
| 117 |
| 118 |
return(1); /* return distance from axis */
| 119 |
