--- ray/src/ot/o_cone.c 2004/03/30 16:13:00 2.4 +++ ray/src/ot/o_cone.c 2007/11/21 18:51:04 2.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: o_cone.c,v 2.4 2004/03/30 16:13:00 schorsch Exp $"; +static const char RCSid[] = "$Id: o_cone.c,v 2.6 2007/11/21 18:51:04 greg Exp $"; #endif /* * o_cone.c - routines for intersecting cubes with cones. @@ -11,6 +11,7 @@ static const char RCSid[] = "$Id: o_cone.c,v 2.4 2004/ #include "octree.h" #include "object.h" #include "cone.h" +#include "plocate.h" #define ROOT3 1.732050808 @@ -29,7 +30,7 @@ static const char RCSid[] = "$Id: o_cone.c,v 2.4 2004/ extern double mincusize; /* minimum cube size */ -static double findcseg(FVECT ep0, FVECT ep1, CONE *co, FVECT p); +static int findcseg(FVECT ep0, FVECT ep1, CONE *co, FVECT p); @@ -57,7 +58,7 @@ o_cone( /* determine if cone intersects cube */ p[i] = cu->cuorg[i] + r; r *= ROOT3; /* bounding radius for cube */ - if (findcseg(ep0, ep1, co, p) > 0.0) { + if (findcseg(ep0, ep1, co, p)) { /* check min. distance to cone */ if (dist2lseg(p, ep0, ep1) > (r+FTINY)*(r+FTINY)) return(O_MISS); @@ -92,7 +93,7 @@ o_cone( /* determine if cone intersects cube */ } -static double +static int findcseg( /* find line segment from cone closest to p */ FVECT ep0, FVECT ep1, @@ -104,16 +105,16 @@ findcseg( /* find line segment from cone closest to p FVECT v; register int i; /* find direction from axis to point */ - for (i = 0; i < 3; i++) - v[i] = p[i] - CO_P0(co)[i]; + VSUB(v, p, CO_P0(co)); d = DOT(v, co->ad); for (i = 0; i < 3; i++) - v[i] = v[i] - d*co->ad[i]; - d = normalize(v); - if (d > 0.0) /* find endpoints of segment */ - for (i = 0; i < 3; i++) { - ep0[i] = CO_R0(co)*v[i] + CO_P0(co)[i]; - ep1[i] = CO_R1(co)*v[i] + CO_P1(co)[i]; - } - return(d); /* return distance from axis */ + v[i] -= d*co->ad[i]; + if (normalize(v) == 0.0) + return(0); + /* find endpoints of segment */ + for (i = 0; i < 3; i++) { + ep0[i] = CO_R0(co)*v[i] + CO_P0(co)[i]; + ep1[i] = CO_R1(co)*v[i] + CO_P1(co)[i]; + } + return(1); /* return distance from axis */ }
