root/radiance/ray/src/ot/o_cone.c
Thu Apr 21 00:40:35 2016 UTC (9 years ago) by greg
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.6: +14 -8 lines
Made zero cone and ring radii non-fatal (degenerate -> ignore)
Wed Nov 21 18:51:04 2007 UTC (17 years, 5 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Fixed implicit declarations
Tue Jun 14 17:10:06 2005 UTC (19 years, 10 months ago) by greg
Changes since 2.4: +14 -14 lines
Fixed ancient bug in cone bounding box calculation -- caused visibility errors
Tue Mar 30 16:13:00 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.3: +3 -4 lines
Sat Mar 27 12:41:45 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.2: +21 -14 lines
Sat Feb 22 02:07:26 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.1: +1 -4 lines
Diff to previous 2.1
Tue Nov 12 17:00:48 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.2
Sat Oct 14 11:19:30 1989 UTC (35 years, 7 months ago) by greg
Thu Feb 2 10:33:02 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 2.1
