root/radiance/ray/src/ot/o_cone.c
Revision: 2.7
Committed: Thu Apr 21 00:40:35 2016 UTC (9 years, 3 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, rad6R0, HEAD
Changes since 2.6: +14 -8 lines
Made zero cone and ring radii non-fatal (degenerate -> ignore)
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.7 static const char RCSid[] = "$Id: o_cone.c,v 2.6 2007/11/21 18:51:04 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * o_cone.c - routines for intersecting cubes with cones.
6     *
7     * 2/3/86
8     */
9
10     #include "standard.h"
11     #include "octree.h"
12     #include "object.h"
13     #include "cone.h"
14 greg 2.6 #include "plocate.h"
15 greg 1.1
16 greg 2.7 #ifndef STRICT
17     #define STRICT 1
18     #endif
19
20 greg 1.1 #define ROOT3 1.732050808
21
22     /*
23     * The algorithm used to detect cube intersection with cones is
24     * recursive. First, we approximate the cube to be a sphere. Then
25     * we test for cone intersection with the sphere by testing the
26     * segment of the cone which is nearest the sphere's center.
27     * If the cone has points within the cube's bounding sphere,
28     * we must check for intersection with the cube. This is done with
29     * the 3D line clipper. The same cone segment is used in this test.
30     * If the clip fails, we still cannot be sure there is no intersection,
31     * so we subdivide the cube and recurse.
32     * If none of the sub-cubes intersect, then our cube does not intersect.
33     */
34
35     extern double mincusize; /* minimum cube size */
36
37 greg 2.5 static int findcseg(FVECT ep0, FVECT ep1, CONE *co, FVECT p);
38 schorsch 2.3
39 greg 1.1
40 schorsch 2.3
41 schorsch 2.4 extern int
42     o_cone( /* determine if cone intersects cube */
43 schorsch 2.3 OBJREC *o,
44 greg 2.7 CUBE *cu
45 schorsch 2.3 )
46 greg 1.1 {
47     CONE *co;
48     FVECT ep0, ep1;
49 greg 2.7 #if STRICT
50 greg 1.1 FVECT cumin, cumax;
51     CUBE cukid;
52 greg 2.7 int j;
53 schorsch 2.3 #endif
54 greg 1.1 double r;
55     FVECT p;
56 greg 2.7 int i;
57 greg 1.1 /* get cone arguments */
58     co = getcone(o, 0);
59 greg 2.7 if (co == NULL) /* check for degenerate case */
60     return(O_MISS);
61 greg 1.1 /* get cube center */
62     r = cu->cusize * 0.5;
63     for (i = 0; i < 3; i++)
64     p[i] = cu->cuorg[i] + r;
65     r *= ROOT3; /* bounding radius for cube */
66
67 greg 2.5 if (findcseg(ep0, ep1, co, p)) {
68 greg 1.1 /* check min. distance to cone */
69     if (dist2lseg(p, ep0, ep1) > (r+FTINY)*(r+FTINY))
70 greg 1.2 return(O_MISS);
71 greg 2.7 #if STRICT
72 greg 1.1 /* get cube boundaries */
73     for (i = 0; i < 3; i++)
74     cumax[i] = (cumin[i] = cu->cuorg[i]) + cu->cusize;
75     /* closest segment intersects? */
76     if (clip(ep0, ep1, cumin, cumax))
77 greg 1.2 return(O_HIT);
78 greg 1.1 }
79     /* check sub-cubes */
80     cukid.cusize = cu->cusize * 0.5;
81     if (cukid.cusize < mincusize)
82 greg 1.2 return(O_HIT); /* cube too small */
83 greg 1.1 cukid.cutree = EMPTY;
84
85     for (j = 0; j < 8; j++) {
86     for (i = 0; i < 3; i++) {
87     cukid.cuorg[i] = cu->cuorg[i];
88     if (1<<i & j)
89     cukid.cuorg[i] += cukid.cusize;
90     }
91     if (o_cone(o, &cukid))
92 greg 1.2 return(O_HIT); /* sub-cube intersects */
93 greg 1.1 }
94 greg 1.2 return(O_MISS); /* no intersection */
95 greg 1.1 #else
96     }
97 greg 1.2 return(O_HIT); /* assume intersection */
98 greg 1.1 #endif
99     }
100
101
102 greg 2.5 static int
103 schorsch 2.3 findcseg( /* find line segment from cone closest to p */
104     FVECT ep0,
105     FVECT ep1,
106 greg 2.7 CONE *co,
107 schorsch 2.3 FVECT p
108     )
109 greg 1.1 {
110     double d;
111     FVECT v;
112 greg 2.7 int i;
113 greg 1.1 /* find direction from axis to point */
114 greg 2.5 VSUB(v, p, CO_P0(co));
115 greg 1.1 d = DOT(v, co->ad);
116     for (i = 0; i < 3; i++)
117 greg 2.5 v[i] -= d*co->ad[i];
118     if (normalize(v) == 0.0)
119     return(0);
120     /* find endpoints of segment */
121     for (i = 0; i < 3; i++) {
122     ep0[i] = CO_R0(co)*v[i] + CO_P0(co)[i];
123     ep1[i] = CO_R1(co)*v[i] + CO_P1(co)[i];
124     }
125     return(1); /* return distance from axis */
126 greg 1.1 }
