1 |
greg |
2.1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Radiance triangle mesh conversion routines |
6 |
7 |
8 |
#include "copyright.h" |
9 |
#include "standard.h" |
10 |
#include "cvmesh.h" |
11 |
#include "otypes.h" |
12 |
#include "face.h" |
13 |
14 |
15 |
* We need to divide faces into triangles and record auxiliary information |
16 |
* if given (surface normal and uv coordinates). We do this by extending |
17 |
* the face structure linked to the OBJREC os member and putting our |
18 |
* auxiliary after it -- a bit sly, but it works. |
19 |
20 |
21 |
/* Auxiliary data for triangle */ |
22 |
typedef struct { |
23 |
int fl; /* flags of what we're storing */ |
24 |
OBJECT obj; /* mesh triangle ID */ |
25 |
FVECT vn[3]; /* normals */ |
26 |
FLOAT vc[3][2]; /* uv coords. */ |
27 |
} TRIDATA; |
28 |
29 |
#define tdsize(fl) ((fl)&MT_UV ? sizeof(TRIDATA) : \ |
30 |
(fl)&MT_N ? sizeof(TRIDATA)-2*sizeof(FLOAT) : \ |
31 |
sizeof(int)+sizeof(OBJECT)) |
32 |
33 |
#define OMARGIN (10*FTINY) /* margin around global cube */ |
34 |
35 |
MESH *ourmesh = NULL; /* our global mesh data structure */ |
36 |
37 |
FVECT meshbounds[2]; /* mesh bounding box */ |
38 |
39 |
40 |
MESH * |
41 |
cvinit(nm) /* initialize empty mesh */ |
42 |
char *nm; |
43 |
44 |
/* free old mesh, first */ |
45 |
if (ourmesh != NULL) { |
46 |
freemesh(ourmesh); |
47 |
ourmesh = NULL; |
48 |
freeobjects(0, nobjects); |
49 |
donesets(); |
50 |
51 |
if (nm == NULL) |
52 |
return(NULL); |
53 |
ourmesh = (MESH *)calloc(1, sizeof(MESH)); |
54 |
if (ourmesh == NULL) |
55 |
goto nomem; |
56 |
ourmesh->name = savestr(nm); |
57 |
ourmesh->nref = 1; |
58 |
ourmesh->ldflags = 0; |
59 |
ourmesh->mcube.cutree = EMPTY; |
60 |
greg |
2.2 |
ourmesh->uvlim[0][0] = ourmesh->uvlim[0][1] = FHUGE; |
61 |
ourmesh->uvlim[1][0] = ourmesh->uvlim[1][1] = -FHUGE; |
62 |
greg |
2.1 |
meshbounds[0][0] = meshbounds[0][1] = meshbounds[0][2] = FHUGE; |
63 |
meshbounds[1][0] = meshbounds[1][1] = meshbounds[1][2] = -FHUGE; |
64 |
return(ourmesh); |
65 |
nomem: |
66 |
error(SYSTEM, "out of memory in cvinit"); |
67 |
return(NULL); |
68 |
69 |
70 |
71 |
int |
72 |
greg |
2.3 |
cvpoly(mo, n, vp, vn, vc) /* convert a polygon to extended triangles */ |
73 |
OBJECT mo; |
74 |
greg |
2.1 |
int n; |
75 |
FVECT *vp; |
76 |
FVECT *vn; |
77 |
FLOAT (*vc)[2]; |
78 |
79 |
int tcnt = 0; |
80 |
int flags; |
81 |
FLOAT *tn[3], *tc[3]; |
82 |
int *ord; |
83 |
int i, j; |
84 |
85 |
if (n < 3) /* degenerate face */ |
86 |
return(0); |
87 |
flags = MT_V; |
88 |
if (vn != NULL) { |
89 |
tn[0] = vn[0]; tn[1] = vn[1]; tn[2] = vn[2]; |
90 |
flags |= MT_N; |
91 |
} else { |
92 |
tn[0] = tn[1] = tn[2] = NULL; |
93 |
94 |
if (vc != NULL) { |
95 |
tc[0] = vc[0]; tc[1] = vc[1]; tc[2] = vc[2]; |
96 |
flags |= MT_UV; |
97 |
} else { |
98 |
tc[0] = tc[1] = tc[2] = NULL; |
99 |
100 |
if (n == 3) /* output single triangle */ |
101 |
greg |
2.3 |
return(cvtri(mo, vp[0], vp[1], vp[2], |
102 |
greg |
2.1 |
tn[0], tn[1], tn[2], |
103 |
tc[0], tc[1], tc[2])); |
104 |
105 |
/* decimate polygon (assumes convex) */ |
106 |
ord = (int *)malloc(n*sizeof(int)); |
107 |
if (ord == NULL) |
108 |
error(SYSTEM, "out of memory in cvpoly"); |
109 |
for (i = n; i--; ) |
110 |
ord[i] = i; |
111 |
while (n >= 3) { |
112 |
if (flags & MT_N) |
113 |
for (i = 3; i--; ) |
114 |
tn[i] = vn[ord[i]]; |
115 |
if (flags & MT_UV) |
116 |
117 |
tc[i] = vc[ord[i]]; |
118 |
greg |
2.3 |
tcnt += cvtri(mo, vp[ord[0]], vp[ord[1]], vp[ord[2]], |
119 |
greg |
2.1 |
120 |
tc[0], tc[1], tc[2]); |
121 |
/* remove vertex and rotate */ |
122 |
n--; |
123 |
j = ord[0]; |
124 |
for (i = 0; i < n-1; i++) |
125 |
ord[i] = ord[i+2]; |
126 |
ord[i] = j; |
127 |
128 |
free((void *)ord); |
129 |
return(tcnt); |
130 |
131 |
132 |
133 |
static void |
134 |
add2bounds(vp, vc) /* add point and uv coordinate to bounds */ |
135 |
FVECT vp; |
136 |
FLOAT vc[2]; |
137 |
138 |
register int j; |
139 |
140 |
for (j = 3; j--; ) { |
141 |
if (vp[j] < meshbounds[0][j]) |
142 |
meshbounds[0][j] = vp[j]; |
143 |
if (vp[j] > meshbounds[1][j]) |
144 |
meshbounds[1][j] = vp[j]; |
145 |
146 |
if (vc == NULL) |
147 |
return; |
148 |
for (j = 2; j--; ) { |
149 |
if (vc[j] < ourmesh->uvlim[0][j]) |
150 |
ourmesh->uvlim[0][j] = vc[j]; |
151 |
if (vc[j] > ourmesh->uvlim[1][j]) |
152 |
ourmesh->uvlim[1][j] = vc[j]; |
153 |
154 |
155 |
156 |
157 |
int /* create an extended triangle */ |
158 |
greg |
2.3 |
cvtri(mo, vp1, vp2, vp3, vn1, vn2, vn3, vc1, vc2, vc3) |
159 |
OBJECT mo; |
160 |
greg |
2.1 |
FVECT vp1, vp2, vp3; |
161 |
FVECT vn1, vn2, vn3; |
162 |
FLOAT vc1[2], vc2[2], vc3[2]; |
163 |
164 |
greg |
2.3 |
static OBJECT fobj = OVOID; |
165 |
char buf[32]; |
166 |
int flags; |
167 |
TRIDATA *ts; |
168 |
FACE *f; |
169 |
OBJREC *fop; |
170 |
int j; |
171 |
greg |
2.1 |
172 |
flags = MT_V; |
173 |
if (vn1 != NULL && vn2 != NULL && vn3 != NULL) |
174 |
flags |= MT_N; |
175 |
if (vc1 != NULL && vc2 != NULL && vc3 != NULL) |
176 |
flags |= MT_UV; |
177 |
greg |
2.3 |
if (fobj == OVOID) { /* create new triangle object */ |
178 |
fobj = newobject(); |
179 |
if (fobj == OVOID) |
180 |
goto nomem; |
181 |
fop = objptr(fobj); |
182 |
fop->omod = mo; |
183 |
fop->otype = OBJ_FACE; |
184 |
sprintf(buf, "t%d", fobj); |
185 |
fop->oname = savqstr(buf); |
186 |
fop->oargs.nfargs = 9; |
187 |
fop->oargs.farg = (FLOAT *)malloc(9*sizeof(FLOAT)); |
188 |
if (fop->oargs.farg == NULL) |
189 |
goto nomem; |
190 |
} else { /* else reuse failed one */ |
191 |
192 |
if (fop->otype != OBJ_FACE || fop->oargs.nfargs != 9) |
193 |
error(CONSISTENCY, "code error 1 in cvtri"); |
194 |
195 |
greg |
2.1 |
196 |
fop->oargs.farg[j] = vp1[j]; |
197 |
fop->oargs.farg[3+j] = vp2[j]; |
198 |
fop->oargs.farg[6+j] = vp3[j]; |
199 |
200 |
/* create face record */ |
201 |
greg |
2.3 |
f = getface(fop); |
202 |
if (f->area == 0.) { |
203 |
free_os(fop); |
204 |
greg |
2.1 |
return(0); |
205 |
206 |
if (fop->os != (char *)f) |
207 |
greg |
2.3 |
error(CONSISTENCY, "code error 2 in cvtri"); |
208 |
greg |
2.1 |
/* follow with auxliary data */ |
209 |
f = (FACE *)realloc((void *)f, sizeof(FACE)+tdsize(flags)); |
210 |
if (f == NULL) |
211 |
goto nomem; |
212 |
fop->os = (char *)f; |
213 |
ts = (TRIDATA *)(f+1); |
214 |
ts->fl = flags; |
215 |
ts->obj = OVOID; |
216 |
if (flags & MT_N) |
217 |
218 |
ts->vn[0][j] = vn1[j]; |
219 |
ts->vn[1][j] = vn2[j]; |
220 |
ts->vn[2][j] = vn3[j]; |
221 |
222 |
223 |
224 |
ts->vc[0][j] = vc1[j]; |
225 |
ts->vc[1][j] = vc2[j]; |
226 |
ts->vc[2][j] = vc3[j]; |
227 |
228 |
else |
229 |
vc1 = vc2 = vc3 = NULL; |
230 |
/* update bounds */ |
231 |
add2bounds(vp1, vc1); |
232 |
add2bounds(vp2, vc2); |
233 |
add2bounds(vp3, vc3); |
234 |
greg |
2.3 |
fobj = OVOID; /* we used this one */ |
235 |
greg |
2.1 |
return(1); |
236 |
nomem: |
237 |
error(SYSTEM, "out of memory in cvtri"); |
238 |
return(0); |
239 |
240 |
241 |
242 |
static OBJECT |
243 |
cvmeshtri(obj) /* add an extended triangle to our mesh */ |
244 |
OBJECT obj; |
245 |
246 |
OBJREC *o = objptr(obj); |
247 |
TRIDATA *ts; |
248 |
MESHVERT vert[3]; |
249 |
int i, j; |
250 |
251 |
if (o->otype != OBJ_FACE) |
252 |
error(CONSISTENCY, "non-face in mesh"); |
253 |
if (o->oargs.nfargs != 9) |
254 |
error(CONSISTENCY, "non-triangle in mesh"); |
255 |
if (o->os == NULL) |
256 |
error(CONSISTENCY, "missing face record in cvmeshtri"); |
257 |
ts = (TRIDATA *)((FACE *)o->os + 1); |
258 |
if (ts->obj != OVOID) /* already added? */ |
259 |
return(ts->obj); |
260 |
vert[0].fl = vert[1].fl = vert[2].fl = ts->fl; |
261 |
262 |
for (j = 3; j--; ) |
263 |
vert[i].v[j] = o->oargs.farg[3*i+j]; |
264 |
if (ts->fl & MT_N) |
265 |
266 |
267 |
vert[i].n[j] = ts->vn[i][j]; |
268 |
if (ts->fl & MT_UV) |
269 |
270 |
for (j = 2; j--; ) |
271 |
vert[i].uv[j] = ts->vc[i][j]; |
272 |
greg |
2.3 |
ts->obj = addmeshtri(ourmesh, vert, o->omod); |
273 |
greg |
2.1 |
if (ts->obj == OVOID) |
274 |
error(INTERNAL, "addmeshtri failed"); |
275 |
return(ts->obj); |
276 |
277 |
278 |
279 |
void |
280 |
cvmeshbounds() /* set mesh boundaries */ |
281 |
282 |
int i; |
283 |
284 |
285 |
return; |
286 |
/* fix coordinate bounds */ |
287 |
for (i = 0; i < 3; i++) { |
288 |
if (meshbounds[0][i] >= meshbounds[1][i]) |
289 |
error(USER, "no polygons in mesh"); |
290 |
meshbounds[0][i] -= OMARGIN; |
291 |
meshbounds[1][i] += OMARGIN; |
292 |
if (meshbounds[1][i]-meshbounds[0][i] > ourmesh->mcube.cusize) |
293 |
ourmesh->mcube.cusize = meshbounds[1][i] - |
294 |
meshbounds[0][i]; |
295 |
296 |
for (i = 0; i < 3; i++) |
297 |
ourmesh->mcube.cuorg[i] = (meshbounds[1][i]+meshbounds[0][i] - |
298 |
ourmesh->mcube.cusize)*.5; |
299 |
greg |
2.2 |
if (ourmesh->uvlim[0][0] > ourmesh->uvlim[1][0]) { |
300 |
greg |
2.1 |
ourmesh->uvlim[0][0] = ourmesh->uvlim[0][1] = 0.; |
301 |
ourmesh->uvlim[1][0] = ourmesh->uvlim[1][1] = 0.; |
302 |
} else { |
303 |
for (i = 0; i < 2; i++) { |
304 |
double marg; |
305 |
marg = 1e-6*(ourmesh->uvlim[1][i] - |
306 |
ourmesh->uvlim[0][i]); |
307 |
ourmesh->uvlim[0][i] -= marg; |
308 |
ourmesh->uvlim[1][i] += marg; |
309 |
310 |
311 |
ourmesh->ldflags |= IO_BOUNDS; |
312 |
313 |
314 |
315 |
static OCTREE |
316 |
cvmeshoct(ot) /* convert triangles in subtree */ |
317 |
OCTREE ot; |
318 |
319 |
int i; |
320 |
321 |
if (isempty(ot)) |
322 |
return(EMPTY); |
323 |
324 |
if (isfull(ot)) { |
325 |
OBJECT oset1[MAXSET+1]; |
326 |
OBJECT oset2[MAXSET+1]; |
327 |
objset(oset1, ot); |
328 |
oset2[0] = 0; |
329 |
for (i = oset1[0]; i > 0; i--) |
330 |
insertelem(oset2, cvmeshtri(oset1[i])); |
331 |
return(fullnode(oset2)); |
332 |
333 |
334 |
for (i = 8; i--; ) |
335 |
octkid(ot, i) = cvmeshoct(octkid(ot, i)); |
336 |
return(ot); |
337 |
338 |
339 |
340 |
MESH * |
341 |
cvmesh() /* convert mesh and octree leaf nodes */ |
342 |
343 |
344 |
return(NULL); |
345 |
/* convert triangles in octree nodes */ |
346 |
ourmesh->mcube.cutree = cvmeshoct(ourmesh->mcube.cutree); |
347 |
ourmesh->ldflags |= IO_SCENE|IO_TREE; |
348 |
349 |
return(ourmesh); |
350 |
