root/radiance/ray/src/ot/cvmesh.c
Fri Jan 24 01:26:44 2014 UTC (10 years, 4 months ago) by greg
Changes since 2.11: +1 -64 lines
Fri Feb 18 19:00:43 2011 UTC (13 years, 3 months ago) by greg
Bug fix for 64-bit compile
Thu Nov 25 14:45:38 2004 UTC (19 years, 6 months ago) by greg
Minor bug fix for .OBJ files with all identical texture coordinates
Sat Mar 27 12:41:45 2004 UTC (20 years, 2 months ago) by schorsch
Changes since 2.8: +41 -24 lines
Thu Jan 29 22:21:34 2004 UTC (20 years, 4 months ago) by greg
Changes since 2.7: +26 -4 lines
Thu Sep 18 16:53:53 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.6: +5 -4 lines
Changes since 2.5: +8 -8 lines
Wed May 14 03:08:22 2003 UTC (21 years, 1 month ago) by greg
Minor bug fix for flat scenes
Wed Apr 23 00:52:34 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.3: +0 -0 lines
Fri Mar 14 21:27:46 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.2: +37 -31 lines
Wed Mar 12 04:59:04 2003 UTC (21 years, 3 months ago) by greg
Tue Mar 11 17:08:55 2003 UTC (21 years, 3 months ago) by greg
