--- ray/src/ot/cvmesh.c 2003/03/11 17:08:55 2.1 +++ ray/src/ot/cvmesh.c 2003/05/14 03:08:22 2.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: cvmesh.c,v 2.1 2003/03/11 17:08:55 greg Exp $"; +static const char RCSid[] = "$Id: cvmesh.c,v 2.5 2003/05/14 03:08:22 greg Exp $"; #endif /* * Radiance triangle mesh conversion routines @@ -27,7 +27,7 @@ typedef struct { } TRIDATA; #define tdsize(fl) ((fl)&MT_UV ? sizeof(TRIDATA) : \ - (fl)&MT_N ? sizeof(TRIDATA)-2*sizeof(FLOAT) : \ + (fl)&MT_N ? sizeof(TRIDATA)-6*sizeof(FLOAT) : \ sizeof(int)+sizeof(OBJECT)) #define OMARGIN (10*FTINY) /* margin around global cube */ @@ -57,8 +57,8 @@ char *nm; ourmesh->nref = 1; ourmesh->ldflags = 0; ourmesh->mcube.cutree = EMPTY; - ourmesh->uvlim[0][0] = ourmesh->uvlim[1][0] = FHUGE; - ourmesh->uvlim[0][1] = ourmesh->uvlim[1][1] = -FHUGE; + ourmesh->uvlim[0][0] = ourmesh->uvlim[0][1] = FHUGE; + ourmesh->uvlim[1][0] = ourmesh->uvlim[1][1] = -FHUGE; meshbounds[0][0] = meshbounds[0][1] = meshbounds[0][2] = FHUGE; meshbounds[1][0] = meshbounds[1][1] = meshbounds[1][2] = -FHUGE; return(ourmesh); @@ -69,7 +69,8 @@ nomem: int -cvpoly(n, vp, vn, vc) /* convert a polygon to extended triangles */ +cvpoly(mo, n, vp, vn, vc) /* convert a polygon to extended triangles */ +OBJECT mo; int n; FVECT *vp; FVECT *vn; @@ -97,7 +98,7 @@ FLOAT (*vc)[2]; tc[0] = tc[1] = tc[2] = NULL; } if (n == 3) /* output single triangle */ - return(cvtri(vp[0], vp[1], vp[2], + return(cvtri(mo, vp[0], vp[1], vp[2], tn[0], tn[1], tn[2], tc[0], tc[1], tc[2])); @@ -114,12 +115,9 @@ FLOAT (*vc)[2]; if (flags & MT_UV) for (i = 3; i--; ) tc[i] = vc[ord[i]]; - i = cvtri(vp[ord[0]], vp[ord[1]], vp[ord[2]], + tcnt += cvtri(mo, vp[ord[0]], vp[ord[1]], vp[ord[2]], tn[0], tn[1], tn[2], tc[0], tc[1], tc[2]); - if (i < 0) - return(i); - tcnt += i; /* remove vertex and rotate */ n--; j = ord[0]; @@ -157,49 +155,56 @@ FLOAT vc[2]; int /* create an extended triangle */ -cvtri(vp1, vp2, vp3, vn1, vn2, vn3, vc1, vc2, vc3) +cvtri(mo, vp1, vp2, vp3, vn1, vn2, vn3, vc1, vc2, vc3) +OBJECT mo; FVECT vp1, vp2, vp3; FVECT vn1, vn2, vn3; FLOAT vc1[2], vc2[2], vc3[2]; { - char buf[32]; - int flags; - TRIDATA *ts; - OBJECT fobj; - FACE *f; - OBJREC *fop; - int j; + static OBJECT fobj = OVOID; + char buf[32]; + int flags; + TRIDATA *ts; + FACE *f; + OBJREC *fop; + int j; flags = MT_V; if (vn1 != NULL && vn2 != NULL && vn3 != NULL) flags |= MT_N; if (vc1 != NULL && vc2 != NULL && vc3 != NULL) flags |= MT_UV; - /* create extended triangle */ - fobj = newobject(); - if (fobj == OVOID) - return(-1); - fop = objptr(fobj); - fop->omod = OVOID; - fop->otype = OBJ_FACE; - sprintf(buf, "t%d", fobj); - fop->oname = savqstr(buf); - fop->oargs.nfargs = 9; - fop->oargs.farg = (FLOAT *)malloc(9*sizeof(FLOAT)); - if (fop->oargs.farg == NULL) - goto nomem; + if (fobj == OVOID) { /* create new triangle object */ + fobj = newobject(); + if (fobj == OVOID) + goto nomem; + fop = objptr(fobj); + fop->omod = mo; + fop->otype = OBJ_FACE; + sprintf(buf, "t%d", fobj); + fop->oname = savqstr(buf); + fop->oargs.nfargs = 9; + fop->oargs.farg = (FLOAT *)malloc(9*sizeof(FLOAT)); + if (fop->oargs.farg == NULL) + goto nomem; + } else { /* else reuse failed one */ + fop = objptr(fobj); + if (fop->otype != OBJ_FACE || fop->oargs.nfargs != 9) + error(CONSISTENCY, "code error 1 in cvtri"); + } for (j = 3; j--; ) { fop->oargs.farg[j] = vp1[j]; fop->oargs.farg[3+j] = vp2[j]; fop->oargs.farg[6+j] = vp3[j]; } /* create face record */ - if ((f = getface(fop)) == NULL || f->area == 0.) { - freeobjects(fobj, 1); + f = getface(fop); + if (f->area == 0.) { + free_os(fop); return(0); } if (fop->os != (char *)f) - error(CONSISTENCY, "code error in cvtri"); + error(CONSISTENCY, "code error 2 in cvtri"); /* follow with auxliary data */ f = (FACE *)realloc((void *)f, sizeof(FACE)+tdsize(flags)); if (f == NULL) @@ -226,6 +231,7 @@ FLOAT vc1[2], vc2[2], vc3[2]; add2bounds(vp1, vc1); add2bounds(vp2, vc2); add2bounds(vp3, vc3); + fobj = OVOID; /* we used this one */ return(1); nomem: error(SYSTEM, "out of memory in cvtri"); @@ -263,7 +269,7 @@ OBJECT obj; for (i = 3; i--; ) for (j = 2; j--; ) vert[i].uv[j] = ts->vc[i][j]; - ts->obj = addmeshtri(ourmesh, vert); + ts->obj = addmeshtri(ourmesh, vert, o->omod); if (ts->obj == OVOID) error(INTERNAL, "addmeshtri failed"); return(ts->obj); @@ -279,7 +285,7 @@ cvmeshbounds() /* set mesh boundaries */ return; /* fix coordinate bounds */ for (i = 0; i < 3; i++) { - if (meshbounds[0][i] >= meshbounds[1][i]) + if (meshbounds[0][i] > meshbounds[1][i]) error(USER, "no polygons in mesh"); meshbounds[0][i] -= OMARGIN; meshbounds[1][i] += OMARGIN; @@ -290,7 +296,7 @@ cvmeshbounds() /* set mesh boundaries */ for (i = 0; i < 3; i++) ourmesh->mcube.cuorg[i] = (meshbounds[1][i]+meshbounds[0][i] - ourmesh->mcube.cusize)*.5; - if (ourmesh->uvlim[0][0] >= ourmesh->uvlim[1][0]) { + if (ourmesh->uvlim[0][0] > ourmesh->uvlim[1][0]) { ourmesh->uvlim[0][0] = ourmesh->uvlim[0][1] = 0.; ourmesh->uvlim[1][0] = ourmesh->uvlim[1][1] = 0.; } else {
