--- ray/src/ot/cvmesh.c 2011/02/18 19:00:43 2.11 +++ ray/src/ot/cvmesh.c 2014/01/24 01:26:44 2.12 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: cvmesh.c,v 2.11 2011/02/18 19:00:43 greg Exp $"; +static const char RCSid[] = "$Id: cvmesh.c,v 2.12 2014/01/24 01:26:44 greg Exp $"; #endif /* * Radiance triangle mesh conversion routines @@ -72,69 +72,6 @@ cvinit( /* initialize empty mesh */ nomem: error(SYSTEM, "out of memory in cvinit"); return(NULL); -} - - -int -cvpoly( /* convert a polygon to extended triangles */ - OBJECT mo, - int n, - FVECT *vp, - FVECT *vn, - RREAL (*vc)[2] -) -{ - int tcnt = 0; - int flags; - RREAL *tn[3], *tc[3]; - int *ord; - int i, j; - - if (n < 3) /* degenerate face */ - return(0); - flags = MT_V; - if (vn != NULL) { - tn[0] = vn[0]; tn[1] = vn[1]; tn[2] = vn[2]; - flags |= MT_N; - } else { - tn[0] = tn[1] = tn[2] = NULL; - } - if (vc != NULL) { - tc[0] = vc[0]; tc[1] = vc[1]; tc[2] = vc[2]; - flags |= MT_UV; - } else { - tc[0] = tc[1] = tc[2] = NULL; - } - if (n == 3) /* output single triangle */ - return(cvtri(mo, vp[0], vp[1], vp[2], - tn[0], tn[1], tn[2], - tc[0], tc[1], tc[2])); - - /* decimate polygon (assumes convex) */ - ord = (int *)malloc(n*sizeof(int)); - if (ord == NULL) - error(SYSTEM, "out of memory in cvpoly"); - for (i = n; i--; ) - ord[i] = i; - while (n >= 3) { - if (flags & MT_N) - for (i = 3; i--; ) - tn[i] = vn[ord[i]]; - if (flags & MT_UV) - for (i = 3; i--; ) - tc[i] = vc[ord[i]]; - tcnt += cvtri(mo, vp[ord[0]], vp[ord[1]], vp[ord[2]], - tn[0], tn[1], tn[2], - tc[0], tc[1], tc[2]); - /* remove vertex and rotate */ - n--; - j = ord[0]; - for (i = 0; i < n-1; i++) - ord[i] = ord[i+2]; - ord[i] = j; - } - free((void *)ord); - return(tcnt); }
