--- ray/src/ot/cvmesh.c 2004/01/29 22:21:34 2.8 +++ ray/src/ot/cvmesh.c 2014/01/24 01:26:44 2.12 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: cvmesh.c,v 2.8 2004/01/29 22:21:34 greg Exp $"; +static const char RCSid[] = "$Id: cvmesh.c,v 2.12 2014/01/24 01:26:44 greg Exp $"; #endif /* * Radiance triangle mesh conversion routines @@ -37,10 +37,16 @@ MESH *ourmesh = NULL; /* our global mesh data structu FVECT meshbounds[2]; /* mesh bounding box */ +static void add2bounds(FVECT vp, RREAL vc[2]); +static OBJECT cvmeshtri(OBJECT obj); +static OCTREE cvmeshoct(OCTREE ot); + + MESH * -cvinit(nm) /* initialize empty mesh */ -char *nm; +cvinit( /* initialize empty mesh */ + char *nm +) { /* free old mesh, first */ if (ourmesh != NULL) { @@ -69,72 +75,11 @@ nomem: } -int -cvpoly(mo, n, vp, vn, vc) /* convert a polygon to extended triangles */ -OBJECT mo; -int n; -FVECT *vp; -FVECT *vn; -RREAL (*vc)[2]; -{ - int tcnt = 0; - int flags; - RREAL *tn[3], *tc[3]; - int *ord; - int i, j; - - if (n < 3) /* degenerate face */ - return(0); - flags = MT_V; - if (vn != NULL) { - tn[0] = vn[0]; tn[1] = vn[1]; tn[2] = vn[2]; - flags |= MT_N; - } else { - tn[0] = tn[1] = tn[2] = NULL; - } - if (vc != NULL) { - tc[0] = vc[0]; tc[1] = vc[1]; tc[2] = vc[2]; - flags |= MT_UV; - } else { - tc[0] = tc[1] = tc[2] = NULL; - } - if (n == 3) /* output single triangle */ - return(cvtri(mo, vp[0], vp[1], vp[2], - tn[0], tn[1], tn[2], - tc[0], tc[1], tc[2])); - - /* decimate polygon (assumes convex) */ - ord = (int *)malloc(n*sizeof(int)); - if (ord == NULL) - error(SYSTEM, "out of memory in cvpoly"); - for (i = n; i--; ) - ord[i] = i; - while (n >= 3) { - if (flags & MT_N) - for (i = 3; i--; ) - tn[i] = vn[ord[i]]; - if (flags & MT_UV) - for (i = 3; i--; ) - tc[i] = vc[ord[i]]; - tcnt += cvtri(mo, vp[ord[0]], vp[ord[1]], vp[ord[2]], - tn[0], tn[1], tn[2], - tc[0], tc[1], tc[2]); - /* remove vertex and rotate */ - n--; - j = ord[0]; - for (i = 0; i < n-1; i++) - ord[i] = ord[i+2]; - ord[i] = j; - } - free((void *)ord); - return(tcnt); -} - - static void -add2bounds(vp, vc) /* add point and uv coordinate to bounds */ -FVECT vp; -RREAL vc[2]; +add2bounds( /* add point and uv coordinate to bounds */ + FVECT vp, + RREAL vc[2] +) { register int j; @@ -156,11 +101,18 @@ RREAL vc[2]; int /* create an extended triangle */ -cvtri(mo, vp1, vp2, vp3, vn1, vn2, vn3, vc1, vc2, vc3) -OBJECT mo; -FVECT vp1, vp2, vp3; -FVECT vn1, vn2, vn3; -RREAL vc1[2], vc2[2], vc3[2]; +cvtri( + OBJECT mo, + FVECT vp1, + FVECT vp2, + FVECT vp3, + FVECT vn1, + FVECT vn2, + FVECT vn3, + RREAL vc1[2], + RREAL vc2[2], + RREAL vc3[2] +) { static OBJECT fobj = OVOID; char buf[32]; @@ -203,7 +155,7 @@ RREAL vc1[2], vc2[2], vc3[2]; fop = objptr(fobj); fop->omod = mo; fop->otype = OBJ_FACE; - sprintf(buf, "t%d", fobj); + sprintf(buf, "t%ld", (long)fobj); fop->oname = savqstr(buf); fop->oargs.nfargs = 9; fop->oargs.farg = (RREAL *)malloc(9*sizeof(RREAL)); @@ -262,8 +214,9 @@ nomem: static OBJECT -cvmeshtri(obj) /* add an extended triangle to our mesh */ -OBJECT obj; +cvmeshtri( /* add an extended triangle to our mesh */ + OBJECT obj +) { OBJREC *o = objptr(obj); TRIDATA *ts; @@ -299,7 +252,7 @@ OBJECT obj; void -cvmeshbounds() /* set mesh boundaries */ +cvmeshbounds(void) /* set mesh boundaries */ { int i; @@ -326,7 +279,7 @@ cvmeshbounds() /* set mesh boundaries */ double marg; /* expand past endpoints */ marg = (2./(1L<<(8*sizeof(uint16)))) * (ourmesh->uvlim[1][i] - - ourmesh->uvlim[0][i]); + ourmesh->uvlim[0][i]) + FTINY; ourmesh->uvlim[0][i] -= marg; ourmesh->uvlim[1][i] += marg; } @@ -336,8 +289,9 @@ cvmeshbounds() /* set mesh boundaries */ static OCTREE -cvmeshoct(ot) /* convert triangles in subtree */ -OCTREE ot; +cvmeshoct( /* convert triangles in subtree */ + OCTREE ot +) { int i; @@ -361,7 +315,7 @@ OCTREE ot; MESH * -cvmesh() /* convert mesh and octree leaf nodes */ +cvmesh(void) /* convert mesh and octree leaf nodes */ { if (ourmesh == NULL) return(NULL);
