Bug fix for 64-bit compile
Minor bug fix for .OBJ files with all identical texture coordinates
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Minor bug fix for flat scenes
