| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: cvmesh.c,v 2.8 2004/01/29 22:21:34 greg Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* Radiance triangle mesh conversion routines |
| 6 |
| 7 |
| 8 |
#include "copyright.h" |
| 9 |
#include "standard.h" |
| 10 |
#include "cvmesh.h" |
| 11 |
#include "otypes.h" |
| 12 |
#include "face.h" |
| 13 |
#include "tmesh.h" |
| 14 |
| 15 |
| 16 |
* We need to divide faces into triangles and record auxiliary information |
| 17 |
* if given (surface normal and uv coordinates). We do this by extending |
| 18 |
* the face structure linked to the OBJREC os member and putting our |
| 19 |
* auxiliary after it -- a bit sly, but it works. |
| 20 |
| 21 |
| 22 |
/* Auxiliary data for triangle */ |
| 23 |
typedef struct { |
| 24 |
int fl; /* flags of what we're storing */ |
| 25 |
OBJECT obj; /* mesh triangle ID */ |
| 26 |
FVECT vn[3]; /* normals */ |
| 27 |
RREAL vc[3][2]; /* uv coords. */ |
| 28 |
} TRIDATA; |
| 29 |
| 30 |
#define tdsize(fl) ((fl)&MT_UV ? sizeof(TRIDATA) : \ |
| 31 |
(fl)&MT_N ? sizeof(TRIDATA)-6*sizeof(RREAL) : \ |
| 32 |
sizeof(int)+sizeof(OBJECT)) |
| 33 |
| 34 |
#define OMARGIN (10*FTINY) /* margin around global cube */ |
| 35 |
| 36 |
MESH *ourmesh = NULL; /* our global mesh data structure */ |
| 37 |
| 38 |
FVECT meshbounds[2]; /* mesh bounding box */ |
| 39 |
| 40 |
static void add2bounds(FVECT vp, RREAL vc[2]); |
| 41 |
static OBJECT cvmeshtri(OBJECT obj); |
| 42 |
static OCTREE cvmeshoct(OCTREE ot); |
| 43 |
| 44 |
| 45 |
| 46 |
MESH * |
| 47 |
cvinit( /* initialize empty mesh */ |
| 48 |
char *nm |
| 49 |
| 50 |
| 51 |
/* free old mesh, first */ |
| 52 |
if (ourmesh != NULL) { |
| 53 |
freemesh(ourmesh); |
| 54 |
ourmesh = NULL; |
| 55 |
freeobjects(0, nobjects); |
| 56 |
donesets(); |
| 57 |
| 58 |
if (nm == NULL) |
| 59 |
return(NULL); |
| 60 |
ourmesh = (MESH *)calloc(1, sizeof(MESH)); |
| 61 |
if (ourmesh == NULL) |
| 62 |
goto nomem; |
| 63 |
ourmesh->name = savestr(nm); |
| 64 |
ourmesh->nref = 1; |
| 65 |
ourmesh->ldflags = 0; |
| 66 |
ourmesh->mcube.cutree = EMPTY; |
| 67 |
ourmesh->uvlim[0][0] = ourmesh->uvlim[0][1] = FHUGE; |
| 68 |
ourmesh->uvlim[1][0] = ourmesh->uvlim[1][1] = -FHUGE; |
| 69 |
meshbounds[0][0] = meshbounds[0][1] = meshbounds[0][2] = FHUGE; |
| 70 |
meshbounds[1][0] = meshbounds[1][1] = meshbounds[1][2] = -FHUGE; |
| 71 |
return(ourmesh); |
| 72 |
nomem: |
| 73 |
error(SYSTEM, "out of memory in cvinit"); |
| 74 |
return(NULL); |
| 75 |
| 76 |
| 77 |
| 78 |
int |
| 79 |
cvpoly( /* convert a polygon to extended triangles */ |
| 80 |
OBJECT mo, |
| 81 |
int n, |
| 82 |
FVECT *vp, |
| 83 |
FVECT *vn, |
| 84 |
RREAL (*vc)[2] |
| 85 |
| 86 |
| 87 |
int tcnt = 0; |
| 88 |
int flags; |
| 89 |
RREAL *tn[3], *tc[3]; |
| 90 |
int *ord; |
| 91 |
int i, j; |
| 92 |
| 93 |
if (n < 3) /* degenerate face */ |
| 94 |
return(0); |
| 95 |
flags = MT_V; |
| 96 |
if (vn != NULL) { |
| 97 |
tn[0] = vn[0]; tn[1] = vn[1]; tn[2] = vn[2]; |
| 98 |
flags |= MT_N; |
| 99 |
} else { |
| 100 |
tn[0] = tn[1] = tn[2] = NULL; |
| 101 |
| 102 |
if (vc != NULL) { |
| 103 |
tc[0] = vc[0]; tc[1] = vc[1]; tc[2] = vc[2]; |
| 104 |
flags |= MT_UV; |
| 105 |
} else { |
| 106 |
tc[0] = tc[1] = tc[2] = NULL; |
| 107 |
| 108 |
if (n == 3) /* output single triangle */ |
| 109 |
return(cvtri(mo, vp[0], vp[1], vp[2], |
| 110 |
tn[0], tn[1], tn[2], |
| 111 |
tc[0], tc[1], tc[2])); |
| 112 |
| 113 |
/* decimate polygon (assumes convex) */ |
| 114 |
ord = (int *)malloc(n*sizeof(int)); |
| 115 |
if (ord == NULL) |
| 116 |
error(SYSTEM, "out of memory in cvpoly"); |
| 117 |
for (i = n; i--; ) |
| 118 |
ord[i] = i; |
| 119 |
while (n >= 3) { |
| 120 |
if (flags & MT_N) |
| 121 |
for (i = 3; i--; ) |
| 122 |
tn[i] = vn[ord[i]]; |
| 123 |
if (flags & MT_UV) |
| 124 |
| 125 |
tc[i] = vc[ord[i]]; |
| 126 |
tcnt += cvtri(mo, vp[ord[0]], vp[ord[1]], vp[ord[2]], |
| 127 |
| 128 |
tc[0], tc[1], tc[2]); |
| 129 |
/* remove vertex and rotate */ |
| 130 |
n--; |
| 131 |
j = ord[0]; |
| 132 |
for (i = 0; i < n-1; i++) |
| 133 |
ord[i] = ord[i+2]; |
| 134 |
ord[i] = j; |
| 135 |
| 136 |
free((void *)ord); |
| 137 |
return(tcnt); |
| 138 |
| 139 |
| 140 |
| 141 |
static void |
| 142 |
add2bounds( /* add point and uv coordinate to bounds */ |
| 143 |
FVECT vp, |
| 144 |
RREAL vc[2] |
| 145 |
| 146 |
| 147 |
register int j; |
| 148 |
| 149 |
for (j = 3; j--; ) { |
| 150 |
if (vp[j] < meshbounds[0][j]) |
| 151 |
meshbounds[0][j] = vp[j]; |
| 152 |
if (vp[j] > meshbounds[1][j]) |
| 153 |
meshbounds[1][j] = vp[j]; |
| 154 |
| 155 |
if (vc == NULL) |
| 156 |
return; |
| 157 |
for (j = 2; j--; ) { |
| 158 |
if (vc[j] < ourmesh->uvlim[0][j]) |
| 159 |
ourmesh->uvlim[0][j] = vc[j]; |
| 160 |
if (vc[j] > ourmesh->uvlim[1][j]) |
| 161 |
ourmesh->uvlim[1][j] = vc[j]; |
| 162 |
| 163 |
| 164 |
| 165 |
| 166 |
int /* create an extended triangle */ |
| 167 |
cvtri( |
| 168 |
OBJECT mo, |
| 169 |
FVECT vp1, |
| 170 |
FVECT vp2, |
| 171 |
FVECT vp3, |
| 172 |
FVECT vn1, |
| 173 |
FVECT vn2, |
| 174 |
FVECT vn3, |
| 175 |
RREAL vc1[2], |
| 176 |
RREAL vc2[2], |
| 177 |
RREAL vc3[2] |
| 178 |
| 179 |
| 180 |
static OBJECT fobj = OVOID; |
| 181 |
char buf[32]; |
| 182 |
int flags; |
| 183 |
TRIDATA *ts; |
| 184 |
FACE *f; |
| 185 |
OBJREC *fop; |
| 186 |
int j; |
| 187 |
| 188 |
flags = MT_V; /* check what we have */ |
| 189 |
if (vn1 != NULL && vn2 != NULL && vn3 != NULL) { |
| 190 |
RREAL *rp; |
| 191 |
switch (flat_tri(vp1, vp2, vp3, vn1, vn2, vn3)) { |
| 192 |
case ISBENT: |
| 193 |
flags |= MT_N; |
| 194 |
/* fall through */ |
| 195 |
case ISFLAT: |
| 196 |
break; |
| 197 |
case RVBENT: |
| 198 |
flags |= MT_N; |
| 199 |
rp = vn1; vn1 = vn3; vn3 = rp; |
| 200 |
| 201 |
case RVFLAT: |
| 202 |
rp = vp1; vp1 = vp3; vp3 = rp; |
| 203 |
rp = vc1; vc1 = vc3; vc3 = rp; |
| 204 |
break; |
| 205 |
case DEGEN: |
| 206 |
error(WARNING, "degenerate triangle"); |
| 207 |
return(0); |
| 208 |
default: |
| 209 |
error(INTERNAL, "bad return from flat_tri()"); |
| 210 |
| 211 |
| 212 |
if (vc1 != NULL && vc2 != NULL && vc3 != NULL) |
| 213 |
flags |= MT_UV; |
| 214 |
if (fobj == OVOID) { /* create new triangle object */ |
| 215 |
fobj = newobject(); |
| 216 |
if (fobj == OVOID) |
| 217 |
goto nomem; |
| 218 |
fop = objptr(fobj); |
| 219 |
fop->omod = mo; |
| 220 |
fop->otype = OBJ_FACE; |
| 221 |
sprintf(buf, "t%ld", fobj); |
| 222 |
fop->oname = savqstr(buf); |
| 223 |
fop->oargs.nfargs = 9; |
| 224 |
fop->oargs.farg = (RREAL *)malloc(9*sizeof(RREAL)); |
| 225 |
if (fop->oargs.farg == NULL) |
| 226 |
goto nomem; |
| 227 |
} else { /* else reuse failed one */ |
| 228 |
| 229 |
if (fop->otype != OBJ_FACE || fop->oargs.nfargs != 9) |
| 230 |
error(CONSISTENCY, "code error 1 in cvtri"); |
| 231 |
| 232 |
| 233 |
fop->oargs.farg[j] = vp1[j]; |
| 234 |
fop->oargs.farg[3+j] = vp2[j]; |
| 235 |
fop->oargs.farg[6+j] = vp3[j]; |
| 236 |
| 237 |
/* create face record */ |
| 238 |
f = getface(fop); |
| 239 |
if (f->area == 0.) { |
| 240 |
free_os(fop); |
| 241 |
return(0); |
| 242 |
| 243 |
if (fop->os != (char *)f) |
| 244 |
error(CONSISTENCY, "code error 2 in cvtri"); |
| 245 |
/* follow with auxliary data */ |
| 246 |
f = (FACE *)realloc((void *)f, sizeof(FACE)+tdsize(flags)); |
| 247 |
if (f == NULL) |
| 248 |
goto nomem; |
| 249 |
fop->os = (char *)f; |
| 250 |
ts = (TRIDATA *)(f+1); |
| 251 |
ts->fl = flags; |
| 252 |
ts->obj = OVOID; |
| 253 |
if (flags & MT_N) |
| 254 |
| 255 |
ts->vn[0][j] = vn1[j]; |
| 256 |
ts->vn[1][j] = vn2[j]; |
| 257 |
ts->vn[2][j] = vn3[j]; |
| 258 |
| 259 |
| 260 |
| 261 |
ts->vc[0][j] = vc1[j]; |
| 262 |
ts->vc[1][j] = vc2[j]; |
| 263 |
ts->vc[2][j] = vc3[j]; |
| 264 |
| 265 |
else |
| 266 |
vc1 = vc2 = vc3 = NULL; |
| 267 |
/* update bounds */ |
| 268 |
add2bounds(vp1, vc1); |
| 269 |
add2bounds(vp2, vc2); |
| 270 |
add2bounds(vp3, vc3); |
| 271 |
fobj = OVOID; /* we used this one */ |
| 272 |
return(1); |
| 273 |
nomem: |
| 274 |
error(SYSTEM, "out of memory in cvtri"); |
| 275 |
return(0); |
| 276 |
| 277 |
| 278 |
| 279 |
static OBJECT |
| 280 |
cvmeshtri( /* add an extended triangle to our mesh */ |
| 281 |
OBJECT obj |
| 282 |
| 283 |
| 284 |
OBJREC *o = objptr(obj); |
| 285 |
TRIDATA *ts; |
| 286 |
MESHVERT vert[3]; |
| 287 |
int i, j; |
| 288 |
| 289 |
if (o->otype != OBJ_FACE) |
| 290 |
error(CONSISTENCY, "non-face in mesh"); |
| 291 |
if (o->oargs.nfargs != 9) |
| 292 |
error(CONSISTENCY, "non-triangle in mesh"); |
| 293 |
if (o->os == NULL) |
| 294 |
error(CONSISTENCY, "missing face record in cvmeshtri"); |
| 295 |
ts = (TRIDATA *)((FACE *)o->os + 1); |
| 296 |
if (ts->obj != OVOID) /* already added? */ |
| 297 |
return(ts->obj); |
| 298 |
vert[0].fl = vert[1].fl = vert[2].fl = ts->fl; |
| 299 |
| 300 |
for (j = 3; j--; ) |
| 301 |
vert[i].v[j] = o->oargs.farg[3*i+j]; |
| 302 |
if (ts->fl & MT_N) |
| 303 |
| 304 |
| 305 |
vert[i].n[j] = ts->vn[i][j]; |
| 306 |
if (ts->fl & MT_UV) |
| 307 |
| 308 |
for (j = 2; j--; ) |
| 309 |
vert[i].uv[j] = ts->vc[i][j]; |
| 310 |
ts->obj = addmeshtri(ourmesh, vert, o->omod); |
| 311 |
if (ts->obj == OVOID) |
| 312 |
error(INTERNAL, "addmeshtri failed"); |
| 313 |
return(ts->obj); |
| 314 |
| 315 |
| 316 |
| 317 |
void |
| 318 |
cvmeshbounds(void) /* set mesh boundaries */ |
| 319 |
| 320 |
int i; |
| 321 |
| 322 |
| 323 |
return; |
| 324 |
/* fix coordinate bounds */ |
| 325 |
for (i = 0; i < 3; i++) { |
| 326 |
if (meshbounds[0][i] > meshbounds[1][i]) |
| 327 |
error(USER, "no polygons in mesh"); |
| 328 |
meshbounds[0][i] -= OMARGIN; |
| 329 |
meshbounds[1][i] += OMARGIN; |
| 330 |
if (meshbounds[1][i]-meshbounds[0][i] > ourmesh->mcube.cusize) |
| 331 |
ourmesh->mcube.cusize = meshbounds[1][i] - |
| 332 |
meshbounds[0][i]; |
| 333 |
| 334 |
for (i = 0; i < 3; i++) |
| 335 |
ourmesh->mcube.cuorg[i] = (meshbounds[1][i]+meshbounds[0][i] - |
| 336 |
ourmesh->mcube.cusize)*.5; |
| 337 |
if (ourmesh->uvlim[0][0] > ourmesh->uvlim[1][0]) { |
| 338 |
ourmesh->uvlim[0][0] = ourmesh->uvlim[0][1] = 0.; |
| 339 |
ourmesh->uvlim[1][0] = ourmesh->uvlim[1][1] = 0.; |
| 340 |
} else { |
| 341 |
for (i = 0; i < 2; i++) { |
| 342 |
double marg; /* expand past endpoints */ |
| 343 |
marg = (2./(1L<<(8*sizeof(uint16)))) * |
| 344 |
(ourmesh->uvlim[1][i] - |
| 345 |
ourmesh->uvlim[0][i]); |
| 346 |
ourmesh->uvlim[0][i] -= marg; |
| 347 |
ourmesh->uvlim[1][i] += marg; |
| 348 |
| 349 |
| 350 |
ourmesh->ldflags |= IO_BOUNDS; |
| 351 |
| 352 |
| 353 |
| 354 |
static OCTREE |
| 355 |
cvmeshoct( /* convert triangles in subtree */ |
| 356 |
OCTREE ot |
| 357 |
| 358 |
| 359 |
int i; |
| 360 |
| 361 |
if (isempty(ot)) |
| 362 |
return(EMPTY); |
| 363 |
| 364 |
if (isfull(ot)) { |
| 365 |
OBJECT oset1[MAXSET+1]; |
| 366 |
OBJECT oset2[MAXSET+1]; |
| 367 |
objset(oset1, ot); |
| 368 |
oset2[0] = 0; |
| 369 |
for (i = oset1[0]; i > 0; i--) |
| 370 |
insertelem(oset2, cvmeshtri(oset1[i])); |
| 371 |
return(fullnode(oset2)); |
| 372 |
| 373 |
| 374 |
for (i = 8; i--; ) |
| 375 |
octkid(ot, i) = cvmeshoct(octkid(ot, i)); |
| 376 |
return(ot); |
| 377 |
| 378 |
| 379 |
| 380 |
MESH * |
| 381 |
cvmesh(void) /* convert mesh and octree leaf nodes */ |
| 382 |
| 383 |
| 384 |
return(NULL); |
| 385 |
/* convert triangles in octree nodes */ |
| 386 |
ourmesh->mcube.cutree = cvmeshoct(ourmesh->mcube.cutree); |
| 387 |
ourmesh->ldflags |= IO_SCENE|IO_TREE; |
| 388 |
| 389 |
return(ourmesh); |
| 390 |
