root/radiance/ray/src/ot/SConscript
Tue Dec 23 15:04:00 2008 UTC (16 years, 4 months ago) by schorsch
Changes since 1.4: +8 -5 lines
Diff to previous 1.4
Sun Apr 27 17:22:49 2008 UTC (17 years ago) by schorsch
Diff to previous 1.3
Mon Apr 21 07:31:29 2008 UTC (17 years ago) by schorsch
Diff to previous 1.2
Scons update for mingw.
Mon Oct 27 10:35:43 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 1.1: +2 -1 lines
Diff to previous 1.1
Tue Oct 21 19:27:29 2003 UTC (21 years, 6 months ago) by schorsch
