root/radiance/ray/src/ot/SConscript
Revision: 1.5
Committed: Tue Dec 23 15:04:00 2008 UTC (16 years, 4 months ago) by schorsch
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R1, rad4R0, rad4R2P1
Changes since 1.4: +8 -5 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # standard targets
9 env.Object(source='bbox.c')
10 env.Object(source='o_face.c')
11 PROGS = (
12 ('oconv', Split('''oconv.c writeoct.c bbox.o initotypes.c
13 sphere.c o_face.o o_cone.c o_instance.c'''), []),
14 ('getbbox', Split('getbbox.c readobj2.c bbox.o init2otypes.c'), []),
15 ('obj2mesh', Split('obj2mesh.c cvmesh.c wfconv.c o_face.o writemesh.c'),
16 ['rtdummy']),
17 )
18 for p in PROGS:
19 prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]),
20 source=p[1], LIBS=['rtproc','rtscene','rtpath','rtio','rtmath',
21 'rtargs','rtcont','rtmem','rterror','rtproc']+p[2]+mlib)
22 Default(prog)
23 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
24
25
