--- ray/src/ot/Rmakefile 1993/12/09 17:29:51 2.4 +++ ray/src/ot/Rmakefile 2023/02/09 00:18:05 2.20 @@ -1,50 +1,55 @@ -# SCCSid "$SunId$ LBL" - +# RCSid: $Id: Rmakefile,v 2.20 2023/02/09 00:18:05 greg Exp $ # # Compiles for octree conversion program # # The compile define "STRICT" enforces strict intersection calculations # so that no cube which does not intersect an object contains that object. # Otherwise, a somewhat faster more lax approach is taken by certain routines. +# This is set to "1" by default, so -DSTRICT=0 now turns it off. # OPT = -O MACH = -DBSD -CFLAGS = -DSTRICT $(OPT) $(MACH) -I../common -L../lib +CFLAGS = -I../common -L../lib $(OPT) $(MACH) CC = cc MLIB = -lm +INSTALL = cp + LIBDIR = /usr/local/lib/ray INSTDIR = /usr/local/bin -all: oconv getbbox +PROGS = oconv getbbox obj2mesh -oconv: oconv.o sphere.o writeoct.o o_face.o plocate.o \ -clip.o o_cone.o o_instance.o bbox.o initotypes.o readfargs.o malloc.o +all: $(PROGS) + +oconv: oconv.o sphere.o writeoct.o o_face.o \ +o_cone.o o_instance.o bbox.o initotypes.o $(CC) $(CFLAGS) -o oconv oconv.o writeoct.o sphere.o o_face.o \ -plocate.o clip.o o_cone.o o_instance.o bbox.o readfargs.o \ -initotypes.o malloc.o -lrt $(MLIB) +o_cone.o o_instance.o bbox.o \ +initotypes.o -lrtrad $(MLIB) getbbox: getbbox.o readobj2.o bbox.o init2otypes.o $(CC) $(CFLAGS) -o getbbox getbbox.o readobj2.o \ -bbox.o init2otypes.o -lrt $(MLIB) +bbox.o init2otypes.o -lrtrad $(MLIB) -install: oconv getbbox - cp oconv getbbox $(INSTDIR) +obj2mesh: obj2mesh.o cvmesh.o wfconv.o o_face.o writemesh.o + $(CC) $(CFLAGS) -o obj2mesh obj2mesh.o cvmesh.o wfconv.o \ +o_face.o writemesh.o -lrtrad $(MLIB) +install: $(PROGS) + $(INSTALL) $(PROGS) $(INSTDIR) + clean: - set nonomatch; rm -f oconv getbbox *.o core + set nonomatch; rm -f $(PROGS) *.o -oconv.o: oconv.c - $(CC) $(CFLAGS) -DDEFPATH=\":$(LIBDIR)\" -c oconv.c - -readfargs.o: readfargs.c ../common/object.h - $(CC) $(CFLAGS) -DMEMHOG -c readfargs.c - bbox.o initotypes.o o_cone.o o_face.o \ o_instance.o oconv.o sphere.o \ -writeoct.o: ../common/standard.h ../common/mat4.h ../common/fvect.h +cvmesh.o obj2mesh.o wfconv.o \ +writeoct.o: ../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h initotypes.o o_cone.o o_face.o oconv.o \ sphere.o writeoct.o: ../common/octree.h @@ -52,17 +57,26 @@ sphere.o writeoct.o: ../common/octree.h bbox.o o_cone.o o_face.o o_instance.o oconv.o \ sphere.o writeoct.o: ../common/object.h -bbox.o initotypes.o oconv.o \ -sphere.o writeoct.o: ../common/otypes.h +bbox.o initotypes.o oconv.o obj2mesh.o sphere.o: ../common/otypes.h +bbox.o getbbox.o initotypes.o oconv.o readobj2.o writeoct.o: oconv.h + +oconv.o: ../common/paths.h + bbox.o o_cone.o: ../common/cone.h bbox.o o_face.o: ../common/face.h -bbox.o o_instance.o: ../common/instance.h ../common/octree.h +bbox.o getbbox.o o_instance.o: ../common/instance.h \ +../common/mesh.h ../common/octree.h -clip.o o_face.o plocate.o: plocate.h +o_face.o: ../common/plocate.h clip.o plocate.o: ../common/fvect.h initotypes.o init2otypes.o: ../common/otypes.h + +cvmesh.o obj2mesh.o wfconv.o: cvmesh.h \ +../common/octree.h ../common/object.h ../common/mesh.h + +cvmesh.o: ../common/otypes.h ../common/face.h ../common/tmesh.h
