--- ray/src/ot/Rmakefile 1989/10/14 11:33:05 1.4 +++ ray/src/ot/Rmakefile 2023/02/09 00:18:05 2.20 @@ -1,57 +1,82 @@ -# SCCSid "$SunId$ LBL" - +# RCSid: $Id: Rmakefile,v 2.20 2023/02/09 00:18:05 greg Exp $ # # Compiles for octree conversion program # # The compile define "STRICT" enforces strict intersection calculations # so that no cube which does not intersect an object contains that object. # Otherwise, a somewhat faster more lax approach is taken by certain routines. +# This is set to "1" by default, so -DSTRICT=0 now turns it off. # OPT = -O -MACH = -f68881 /usr/lib/f68881.il -CFLAGS = -DSTRICT $(OPT) $(MACH) +MACH = -DBSD +CFLAGS = -I../common -L../lib $(OPT) $(MACH) +CC = cc +MLIB = -lm -INSTDIR = /usr/local/ray +INSTALL = cp -INSTALL = install +LIBDIR = /usr/local/lib/ray -COMPAT = malloc.o +INSTDIR = /usr/local/bin -oconv: dummy.o misc.o objset.o oconv.o octree.o readobj.o \ -readoct.o sphere.o fvect.o otypes.o writeoct.o o_face.o face.o plocate.o xf.o \ -clip.o cone.o o_cone.o instance.o o_instance.o bbox.o savestr.o header.o \ -mat4.o fgetline.o $(COMPAT) - cc $(CFLAGS) -o oconv oconv.o readoct.o octree.o objset.o \ -readobj.o writeoct.o fvect.o otypes.o sphere.o dummy.o misc.o o_face.o \ -face.o plocate.o clip.o cone.o o_cone.o instance.o o_instance.o mat4.o xf.o \ -bbox.o savestr.o header.o fgetline.o $(COMPAT) -lm +PROGS = oconv getbbox obj2mesh -install: oconv - $(INSTALL) oconv $(INSTDIR) +all: $(PROGS) -xf.o: xf.c - cc $(CFLAGS) -DINVXF -c xf.c +oconv: oconv.o sphere.o writeoct.o o_face.o \ +o_cone.o o_instance.o bbox.o initotypes.o + $(CC) $(CFLAGS) -o oconv oconv.o writeoct.o sphere.o o_face.o \ +o_cone.o o_instance.o bbox.o \ +initotypes.o -lrtrad $(MLIB) -bbox.o cone.o face.o misc.o o_cone.o o_face.o \ -o_instance.o objset.o oconv.o instance.o octree.o \ -otypes.o readobj.o readoct.o sphere.o writeoct.o: standard.h fvect.h +getbbox: getbbox.o readobj2.o bbox.o init2otypes.o + $(CC) $(CFLAGS) -o getbbox getbbox.o readobj2.o \ +bbox.o init2otypes.o -lrtrad $(MLIB) -o_cone.o o_face.o objset.o oconv.o octree.o \ -readoct.o sphere.o writeoct.o: octree.h +obj2mesh: obj2mesh.o cvmesh.o wfconv.o o_face.o writemesh.o + $(CC) $(CFLAGS) -o obj2mesh obj2mesh.o cvmesh.o wfconv.o \ +o_face.o writemesh.o -lrtrad $(MLIB) -bbox.o cone.o face.o o_cone.o o_face.o o_instance.o objset.o oconv.o \ -instance.o otypes.o readobj.o readoct.o sphere.o writeoct.o: object.h +install: $(PROGS) + $(INSTALL) $(PROGS) $(INSTDIR) -bbox.o cone.o oconv.o otypes.o \ -readobj.o readoct.o sphere.o writeoct.o: otypes.h +clean: + set nonomatch; rm -f $(PROGS) *.o -fvect.o: fvect.h +bbox.o initotypes.o o_cone.o o_face.o \ +o_instance.o oconv.o sphere.o \ +cvmesh.o obj2mesh.o wfconv.o \ +writeoct.o: ../common/standard.h ../common/rtmisc.h ../common/rtio.h \ +../common/rtmath.h ../common/mat4.h ../common/fvect.h \ +../common/rterror.h -bbox.o cone.o o_cone.o: cone.h +initotypes.o o_cone.o o_face.o oconv.o \ +sphere.o writeoct.o: ../common/octree.h -bbox.o face.o o_face.o: face.h +bbox.o o_cone.o o_face.o o_instance.o oconv.o \ +sphere.o writeoct.o: ../common/object.h -bbox.o o_instance.o instance.o: instance.h octree.h +bbox.o initotypes.o oconv.o obj2mesh.o sphere.o: ../common/otypes.h -clip.o o_face.o plocate.o: plocate.h +bbox.o getbbox.o initotypes.o oconv.o readobj2.o writeoct.o: oconv.h + +oconv.o: ../common/paths.h + +bbox.o o_cone.o: ../common/cone.h + +bbox.o o_face.o: ../common/face.h + +bbox.o getbbox.o o_instance.o: ../common/instance.h \ +../common/mesh.h ../common/octree.h + +o_face.o: ../common/plocate.h + +clip.o plocate.o: ../common/fvect.h + +initotypes.o init2otypes.o: ../common/otypes.h + +cvmesh.o obj2mesh.o wfconv.o: cvmesh.h \ +../common/octree.h ../common/object.h ../common/mesh.h + +cvmesh.o: ../common/otypes.h ../common/face.h ../common/tmesh.h
