root/radiance/ray/src/ot/Rmakefile
Thu Apr 21 00:40:35 2016 UTC (8 years, 1 month ago) by greg
Diff to previous 2.18 , to selected 2.17
Made zero cone and ring radii non-fatal (degenerate -> ignore)
Sat Apr 26 15:59:38 2014 UTC (10 years, 1 month ago) by greg
Diff to previous 2.17
Revision 2.17 - (view) (download) (annotate) - [selected]
Tue Jun 24 02:01:20 2008 UTC (15 years, 11 months ago) by greg
CVS Tags: rad4R0, rad4R1
Diff to previous 2.16
Fri Mar 10 19:40:13 2006 UTC (18 years, 3 months ago) by schorsch
CVS Tags: rad3R8, rad3R9
Diff to previous 2.15 , to selected 2.17
Wed Oct 27 23:36:09 2004 UTC (19 years, 7 months ago) by greg
Diff to previous 2.14 , to selected 2.17
Sat Mar 27 12:43:30 2004 UTC (20 years, 2 months ago) by schorsch
Diff to previous 2.13 , to selected 2.17
Thu Jan 29 22:21:34 2004 UTC (20 years, 4 months ago) by greg
Diff to previous 2.12 , to selected 2.17
Fri Jun 27 06:53:22 2003 UTC (20 years, 11 months ago) by greg
Diff to previous 2.11 , to selected 2.17
Sat Mar 15 17:55:48 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.10 , to selected 2.17
Fri Mar 14 21:27:46 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.9 , to selected 2.17
Tue Mar 11 22:48:20 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.8 , to selected 2.17
Tue Mar 11 17:08:55 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.7 , to selected 2.17
Sat Feb 22 02:07:26 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.6 , to selected 2.17
Mon Apr 3 16:46:46 1995 UTC (29 years, 2 months ago) by greg
Diff to previous 2.5 , to selected 2.17
Thu Apr 14 05:02:05 1994 UTC (30 years, 2 months ago) by greg
Diff to previous 2.4 , to selected 2.17
Thu Dec 9 17:29:51 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.3 , to selected 2.17
Thu Sep 24 21:28:29 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.2 , to selected 2.17
Wed Jul 1 15:07:42 1992 UTC (31 years, 11 months ago) by greg
Diff to previous 2.1 , to selected 2.17
Tue Nov 12 17:00:51 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.25 , to selected 2.17
Thu Nov 7 11:05:44 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.24 , to selected 2.17
removed STRUCTASSIGN macro
Wed Oct 23 13:43:35 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.23 , to selected 2.17
Wed Oct 23 10:46:27 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.22 , to selected 2.17
standardized macro settings
Tue Oct 8 15:31:38 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.21 , to selected 2.17
*** empty log message ***
Thu Sep 5 11:17:38 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.20 , to selected 2.17
Thu Aug 22 09:24:11 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.19 , to selected 2.17
moved librt.a to ../lib
Mon Jul 22 12:13:48 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.18 , to selected 2.17
Fri Jul 19 09:29:26 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.17 , to selected 2.17
Thu Jul 18 10:47:59 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.16 , to selected 2.17
Mon Jul 15 12:15:08 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.15 , to selected 2.17
Mon Jul 15 11:42:58 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.14 , to selected 2.17
Wed May 29 17:33:39 1991 UTC (33 years ago) by greg
Diff to previous 1.13 , to selected 2.17
added getbbox
Wed May 29 16:22:34 1991 UTC (33 years ago) by greg
Diff to previous 1.12 , to selected 2.17
added define for DEFPATH
Tue May 7 16:17:19 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.11 , to selected 2.17
Thu Apr 11 09:21:24 1991 UTC (33 years, 2 months ago) by greg
Diff to previous 1.10 , to selected 2.17
Tue Apr 2 09:51:22 1991 UTC (33 years, 2 months ago) by greg
Diff to previous 1.9 , to selected 2.17
Wed Mar 6 09:56:04 1991 UTC (33 years, 3 months ago) by greg
Diff to previous 1.8 , to selected 2.17
makefile normalization
Sat Dec 15 15:17:44 1990 UTC (33 years, 6 months ago) by greg
Diff to previous 1.7 , to selected 2.17
added mat4.h dependencies
Thu Dec 13 10:52:49 1990 UTC (33 years, 6 months ago) by greg
Diff to previous 1.6 , to selected 2.17
Thu Sep 6 23:30:15 1990 UTC (33 years, 9 months ago) by greg
Diff to previous 1.5 , to selected 2.17
Thu Jan 18 23:59:28 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.4 , to selected 2.17
Sat Oct 14 11:33:05 1989 UTC (34 years, 8 months ago) by greg
Diff to previous 1.3 , to selected 2.17
Changed option defines.
Wed Oct 4 16:06:46 1989 UTC (34 years, 8 months ago) by greg
Diff to previous 1.2 , to selected 2.17
added fgetline.o
Tue Feb 21 14:44:51 1989 UTC (35 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 2.17
portability fixes
Thu Feb 2 10:33:07 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.17
