Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
removed STRUCTASSIGN macro
standardized macro settings
*** empty log message ***
moved librt.a to ../lib
added getbbox
added define for DEFPATH
makefile normalization
added mat4.h dependencies
Changed option defines.
added fgetline.o
portability fixes
