root/Development/ray/src/ot/Rmakefile
Fri Mar 10 19:40:13 2006 UTC (19 years, 8 months ago) by schorsch
CVS Tags: rad3R8, rad3R9
Diff to previous 2.15 , to selected 2.7
Wed Oct 27 23:36:09 2004 UTC (21 years ago) by greg
Diff to previous 2.14 , to selected 2.7
Sat Mar 27 12:43:30 2004 UTC (21 years, 7 months ago) by schorsch
Thu Jan 29 22:21:34 2004 UTC (21 years, 9 months ago) by greg
Fri Jun 27 06:53:22 2003 UTC (22 years, 4 months ago) by greg
Sat Mar 15 17:55:48 2003 UTC (22 years, 8 months ago) by greg
Fri Mar 14 21:27:46 2003 UTC (22 years, 8 months ago) by greg
Tue Mar 11 22:48:20 2003 UTC (22 years, 8 months ago) by greg
Tue Mar 11 17:08:55 2003 UTC (22 years, 8 months ago) by greg
Sat Feb 22 02:07:26 2003 UTC (22 years, 9 months ago) by greg
Mon Apr 3 16:46:46 1995 UTC (30 years, 7 months ago) by greg
Thu Apr 14 05:02:05 1994 UTC (31 years, 7 months ago) by greg
Thu Dec 9 17:29:51 1993 UTC (31 years, 11 months ago) by greg
Thu Sep 24 21:28:29 1992 UTC (33 years, 2 months ago) by greg
Wed Jul 1 15:07:42 1992 UTC (33 years, 4 months ago) by greg
Tue Nov 12 17:00:51 1991 UTC (34 years ago) by greg
Diff to previous 1.25 , to selected 2.7
Thu Nov 7 11:05:44 1991 UTC (34 years ago) by greg
Diff to previous 1.24 , to selected 2.7
removed STRUCTASSIGN macro
Wed Oct 23 13:43:35 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.23 , to selected 2.7
Wed Oct 23 10:46:27 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.22 , to selected 2.7
standardized macro settings
Tue Oct 8 15:31:38 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.21 , to selected 2.7
*** empty log message ***
Thu Sep 5 11:17:38 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.20 , to selected 2.7
Thu Aug 22 09:24:11 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.19 , to selected 2.7
moved librt.a to ../lib
Mon Jul 22 12:13:48 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.18 , to selected 2.7
Fri Jul 19 09:29:26 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.17 , to selected 2.7
Thu Jul 18 10:47:59 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.16 , to selected 2.7
Mon Jul 15 12:15:08 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.15 , to selected 2.7
Mon Jul 15 11:42:58 1991 UTC (34 years, 4 months ago) by greg
Diff to previous 1.14 , to selected 2.7
Wed May 29 17:33:39 1991 UTC (34 years, 5 months ago) by greg
Diff to previous 1.13 , to selected 2.7
added getbbox
Wed May 29 16:22:34 1991 UTC (34 years, 5 months ago) by greg
Diff to previous 1.12 , to selected 2.7
added define for DEFPATH
Tue May 7 16:17:19 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.11 , to selected 2.7
Thu Apr 11 09:21:24 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.10 , to selected 2.7
Tue Apr 2 09:51:22 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.9 , to selected 2.7
Wed Mar 6 09:56:04 1991 UTC (34 years, 8 months ago) by greg
Diff to previous 1.8 , to selected 2.7
makefile normalization
Sat Dec 15 15:17:44 1990 UTC (34 years, 11 months ago) by greg
Diff to previous 1.7 , to selected 2.7
added mat4.h dependencies
Thu Dec 13 10:52:49 1990 UTC (34 years, 11 months ago) by greg
Diff to previous 1.6 , to selected 2.7
Thu Sep 6 23:30:15 1990 UTC (35 years, 2 months ago) by greg
Diff to previous 1.5 , to selected 2.7
Thu Jan 18 23:59:28 1990 UTC (35 years, 10 months ago) by greg
Diff to previous 1.4 , to selected 2.7
Sat Oct 14 11:33:05 1989 UTC (36 years, 1 month ago) by greg
Diff to previous 1.3 , to selected 2.7
Changed option defines.
Wed Oct 4 16:06:46 1989 UTC (36 years, 1 month ago) by greg
added fgetline.o
Tue Feb 21 14:44:51 1989 UTC (36 years, 9 months ago) by greg
portability fixes
Thu Feb 2 10:33:07 1989 UTC (36 years, 9 months ago) by greg
Diff to selected 2.7
