root/radiance/ray/src/ot/Rmakefile
Revision: 2.20
Committed: Thu Feb 9 00:18:05 2023 UTC (2 years, 3 months ago) by greg
CVS Tags: rad5R4, HEAD
Changes since 2.19: +4 -2 lines
Error occurred while calculating annotation data.
1 # RCSid: $Id: Rmakefile,v 2.19 2016/04/21 00:40:35 greg Exp $
2 #
3 # Compiles for octree conversion program
4 #
5 # The compile define "STRICT" enforces strict intersection calculations
6 # so that no cube which does not intersect an object contains that object.
7 # Otherwise, a somewhat faster more lax approach is taken by certain routines.
8 # This is set to "1" by default, so -DSTRICT=0 now turns it off.
9 #
10
11 OPT = -O
12 MACH = -DBSD
13 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
14 CC = cc
15 MLIB = -lm
16
17 INSTALL = cp
18
19 LIBDIR = /usr/local/lib/ray
20
21 INSTDIR = /usr/local/bin
22
23 PROGS = oconv getbbox obj2mesh
24
25 all: $(PROGS)
26
27 oconv: oconv.o sphere.o writeoct.o o_face.o \
28 o_cone.o o_instance.o bbox.o initotypes.o
29 $(CC) $(CFLAGS) -o oconv oconv.o writeoct.o sphere.o o_face.o \
30 o_cone.o o_instance.o bbox.o \
31 initotypes.o -lrtrad $(MLIB)
32
33 getbbox: getbbox.o readobj2.o bbox.o init2otypes.o
34 $(CC) $(CFLAGS) -o getbbox getbbox.o readobj2.o \
35 bbox.o init2otypes.o -lrtrad $(MLIB)
36
37 obj2mesh: obj2mesh.o cvmesh.o wfconv.o o_face.o writemesh.o
38 $(CC) $(CFLAGS) -o obj2mesh obj2mesh.o cvmesh.o wfconv.o \
39 o_face.o writemesh.o -lrtrad $(MLIB)
40
41 install: $(PROGS)
42 $(INSTALL) $(PROGS) $(INSTDIR)
43
44 clean:
45 set nonomatch; rm -f $(PROGS) *.o
46
47 bbox.o initotypes.o o_cone.o o_face.o \
48 o_instance.o oconv.o sphere.o \
49 cvmesh.o obj2mesh.o wfconv.o \
50 writeoct.o: ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
51 ../common/rtmath.h ../common/mat4.h ../common/fvect.h \
52 ../common/rterror.h
53
54 initotypes.o o_cone.o o_face.o oconv.o \
55 sphere.o writeoct.o: ../common/octree.h
56
57 bbox.o o_cone.o o_face.o o_instance.o oconv.o \
58 sphere.o writeoct.o: ../common/object.h
59
60 bbox.o initotypes.o oconv.o obj2mesh.o sphere.o: ../common/otypes.h
61
62 bbox.o getbbox.o initotypes.o oconv.o readobj2.o writeoct.o: oconv.h
63
64 oconv.o: ../common/paths.h
65
66 bbox.o o_cone.o: ../common/cone.h
67
68 bbox.o o_face.o: ../common/face.h
69
70 bbox.o getbbox.o o_instance.o: ../common/instance.h \
71 ../common/mesh.h ../common/octree.h
72
73 o_face.o: ../common/plocate.h
74
75 clip.o plocate.o: ../common/fvect.h
76
77 initotypes.o init2otypes.o: ../common/otypes.h
78
79 cvmesh.o obj2mesh.o wfconv.o: cvmesh.h \
80 ../common/octree.h ../common/object.h ../common/mesh.h
81
82 cvmesh.o: ../common/otypes.h ../common/face.h ../common/tmesh.h
