root/radiance/ray/src/ogl/gldisp.h
Revision: 3.4
Committed: Fri Feb 28 20:25:32 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.3: +0 -0 lines
State: FILE REMOVED
Removed unused ray/src/ogl directory
# User Rev Content
1 greg 3.1 /* Copyright (c) 1997 Regents of the University of California */
2
3     /* SCCSid "$SunId$ LBL" */
4
5     /*
6 greg 3.2 * Header file for OpenGL display process.
7 greg 3.1 */
8
9 greg 3.2 #ifndef MEM_PTR
10     #define MEM_PTR char *
11     #endif
12     #ifndef int4
13     #define int4 int /* assume 32-bit integers */
14     #endif
15 greg 3.1
16 greg 3.3 /* request types */
17     #define GD_R_ViewSync 0 /* synchronize current view */
18     #define GD_R_SetView 1 /* set new view parameters */
19     #define GD_R_AddBg 2 /* add background rectangle */
20     #define GD_R_DelBg 3 /* delete background rectangle */
21     #define GD_R_Error 4 /* error to report */
22     #define GD_R_Init 5 /* initialize connection */
23     #define GD_NREQ 6 /* number of requests */
24 greg 3.2
25     /* error codes */
26 greg 3.3 #define GD_OK 0 /* normal return value */
27     #define GD_E_UNRECOG 1 /* unrecognized request */
28     #define GD_E_ARGMISS 2 /* missing argument(s) */
29     #define GD_E_NOMEMOR 3 /* out of memory */
30     #define GD_E_CONNECT 4 /* can't establish connection */
31     #define GD_NERRS 5 /* number of errors */
32 greg 3.2
33 greg 3.3 extern char *gdErrMsg[GD_NERRS]; /* our error message list */
34 greg 3.2
35 greg 3.3 /* request structure */
36     #define GD_ARG0 4 /* minimum argument length */
37 greg 3.1 typedef struct {
38 greg 3.3 short type; /* request type */
39     unsigned int4 id; /* unique identifier */
40     unsigned int4 alen; /* argument buffer length */
41     unsigned char args[GD_ARG0]; /* followed by the actual arguments */
42     } GDrequest; /* a GL display request */
43 greg 3.1
44 greg 3.3 typedef struct {
45     int cno; /* connection number */
46     int xres, yres; /* display window size (renderable area) */
47     int fdout; /* send descriptor */
48     FILE *fpin; /* receive stream */
49     } GDconnect; /* display server/client connection */
50 greg 3.1
51 greg 3.3 /* argument lengths */
52     #define GD_L_REAL 5 /* reals are 5 bytes */
53     #define gdStrLen(s) (strlen(s)+1) /* strings are nul-terminated */
54 greg 3.2
55     #define gdFree(p) free((MEM_PTR)(p))
56
57 greg 3.3 extern GDrequest *gdRecvRequest();
58     extern GDconnect *gdOpen();
59     extern int4 gdGetInt();
60     extern double gdGetReal();
