root/radiance/ray/src/ogl/gdio.c
Revision: 3.3
Committed: Fri Feb 28 20:25:32 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.2: +0 -0 lines
State: FILE REMOVED
Removed unused ray/src/ogl directory
# User Rev Content
1 greg 3.1 /* Copyright (c) 1997 Regents of the University of California */
2
3     #ifndef lint
4     static char SCCSid[] = "$SunId$ LBL";
5     #endif
6
7     /*
8 greg 3.2 * I/O routines for GL display process.
9 greg 3.1 */
10
11     #include "standard.h"
12 greg 3.2 #include <sys/uio.h>
13 greg 3.1 #include "gldisp.h"
14 greg 3.2 #include "gderrs.h"
15 greg 3.1
16
17 greg 3.2 gdSendRequest(d, r) /* send a request across a connection */
18     GDconnect *d;
19     GDrequest *r;
20     {
21     unsigned char rbuf[10];
22     struct iovec iov[2];
23     /* encode header */
24     gdPutInt(rbuf, (int4)r->type, 2);
25     gdPutInt(rbuf+2, r->id, 4);
26     gdPutInt(rbuf+6, r->alen, 4);
27     if (r->alen == 0) /* write header, null body */
28     write(d->fdout, rbuf, 10);
29     else { /* write header and body */
30     iov[0].iov_base = (MEM_PTR)rbuf;
31     iov[0].iov_len = 10;
32     iov[1].iov_base = (MEM_PTR)r->args;
33     iov[1].iov_len = r->alen;
34     writev(d->fdout, iov, 2);
35     }
36     }
37 greg 3.1
38
39 greg 3.2 GDrequest *
40     gdRecvRequest(d) /* receive a request across a connection */
41     register GDconnect *d;
42     {
43     register GDrequest *r;
44     int type;
45     int4 id, alen;
46     unsigned char rbuf[10];
47     /* read header */
48     fread(rbuf, 1, 10, d->fpin);
49     if (feof(d->fpin))
50     return(NULL);
51     type = gdGetInt(rbuf, 2);
52     id = gdGetInt(rbuf+2, 4);
53     if (type < 0 | type > GD_NREQ) {
54     gdSendError(d, GD_E_UNRECOG, id);
55     return(NULL);
56     }
57     alen = gdGetInt(rbuf+6, 4);
58     r = (GDrequest *)malloc(sizeof(GDrequest)-GD_ARG0+alen);
59     if (r == NULL) {
60     gdSendError(d, GD_E_NOMEMOR, id);
61     return(NULL);
62     }
63     r->type = type;
64     r->id = id;
65     if ((r->alen = alen) > 0) { /* read arguments */
66     fread(r->args, 1, alen, d->fpin);
67     if (feof(d->fpin)) {
68     gdSendError(d, GD_E_ARGMISS, id);
69     gdFree(r);
70     return(NULL);
71     }
72     }
73     if (type == GD_R_Error) { /* our error */
74     gdReportError(d, (int)gdGetInt(r->args, 2), id);
75     gdFree(r);
76     return(NULL);
77     }
78     return(r); /* success! */
79     }
80 greg 3.1
81
82 greg 3.2 gdSendError(d, ec, id) /* send fatal error associated with a request */
83     GDconnect *d;
84     int ec;
85     int4 id;
86     {
87     GDrequest rq;
88     /* build error request */
89     rq.type = GD_R_Error;
90     rq.id = id;
91     gdPutInt(rq.args, (int4)ec, rq.alen=2);
92     gdSendRequest(d, &rq); /* send it */
93     gdClose(d); /* all errors are fatal */
94     }
95 greg 3.1
96
97 greg 3.2 gdReportError(d, ec, id) /* report fatal error to stderr */
98     GDconnect *d;
99     int ec;
100     int4 id;
101     {
102     fprintf(stderr, "RequestId %d: %s\nConnection %d closed.\n",
103     id, gdErrMsg[ec], d->cno);
104     gdClose(d); /* all errors are fatal */
105     }
106 greg 3.1
107
108 greg 3.2 GDconnect *
109     gdOpen(inp, outp, x, y) /* establish a client/server connection */
110     char *inp, *outp; /* named pipes, currently */
111     int x, y; /* (0,0) for client */
112     {
113     static int nconnections = 0;
114     register GDrequest *rp;
115     GDrequest rq;
116     register GDconnect *dp;
117 greg 3.1
118 greg 3.2 dp = (GDconnect *)malloc(sizeof(GDconnect));
119     if (dp == NULL) {
120     gdReportError(dp, GD_E_NOMEMOR, 0);
121     return(NULL);
122     }
123     dp->cno = ++nconnections;
124     if (!x) /* client opens to write first */
125     dp->fdout = open(outp, O_WRONLY);
126     dp->fpin = fopen(inp, "r");
127     if (dp->fpin == NULL)
128     goto connecterr;
129     if (x) /* server opens to write second */
130     dp->fdout = open(outp, O_WRONLY);
131     if (dp->fdout < 0)
132     goto connecterr;
133     if (x) { /* server sends resolution */
134     dp->xres = x; dp->yres = y;
135     rq.type = GD_R_Init;
136     rq.id = dp->cno;
137     rq.alen = 4;
138     gdPutInt(rq.args, (int4)x, 2);
139     gdPutInt(rq.args+2, (int4)y, 2);
140     gdSendRequest(dp, &rq);
141     } else { /* client receives resolution */
142     rp = gdRecvRequest(dp);
143     if (rp == NULL)
144     return(NULL);
145     if (rp->type != GD_R_Init)
146     goto connecterr;
147     dp->cno = rp->id;
148     dp->xres = gdGetInt(rp->args, 2);
149     dp->yres = gdGetInt(rp->args+2, 2);
150     gdFree(rp);
151     }
152     return(dp); /* success! */
153     connecterr:
154     gdReportError(dp, GD_E_CONNECT, 0);
155     return(NULL);
156     }
157 greg 3.1
158
159 greg 3.2 gdClose(d) /* close a display server/client connection */
160     register GDconnect *d;
161 greg 3.1 {
162 greg 3.2 if (d == NULL) return;
163     close(d->fdout);
164     fclose(d->fpin);
165     gdFree(d); /* free associated memory */
166 greg 3.1 }
167
168
169 greg 3.2 int4
170     gdGetInt(ab, n) /* get an n-byte integer from buffer ab */
171     register unsigned char *ab;
172     register int n; /* maximum length 4 */
173 greg 3.1 {
174 greg 3.2 register int4 res;
175 greg 3.1
176 greg 3.2 res = *ab&0x80 ? -1 : 0; /* sign extend */
177     while (n--)
178     res = res<<8 | *ab++;
179     return(res);
180 greg 3.1 }
181
182
183 greg 3.2 gdPutInt(ab, i, n) /* put an n-byte integer into buffer ab */
184     register unsigned char *ab;
185     register int4 i;
186     register int n;
187 greg 3.1 {
188 greg 3.2 while (n--)
189     *ab++ = i>>(n<<3) & 0xff;
190 greg 3.1 }
191
192
193 greg 3.2 double
194     gdGetReal(ab) /* get a 5-byte real value from buffer ab */
195     char *ab;
196 greg 3.1 {
197 greg 3.2 register int4 i;
198     register double d;
199 greg 3.1
200 greg 3.2 i = gdGetInt(ab, 4);
201     d = (i + (i>0 ? .5 : -.5)) * (1./0x7fffffff);
202     return(ldexp(d, (int)gdGetInt(ab+4,1)));
203 greg 3.1 }
204
205
206 greg 3.2 gdPutReal(ab, d) /* put a 5-byte real value to buffer ab */
207     unsigned char *ab;
208     double d;
209 greg 3.1 {
210 greg 3.2 int e;
211 greg 3.1
212 greg 3.2 gdPutInt(ab, (int4)(frexp(d,&e)*0x7fffffff), 4);
213     gdPutInt(ab+4, (int4)e, 1);
214 greg 3.1 }
