root/radiance/ray/src/ogl/gdio.c
Revision: 3.3
Committed: Fri Feb 28 20:25:32 2003 UTC (21 years, 3 months ago) by greg
Changes since 3.2: +0 -0 lines
State: FILE REMOVED
Removed unused ray/src/ogl directory
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * I/O routines for GL display process.
9 */
10
11 #include "standard.h"
12 #include <sys/uio.h>
13 #include "gldisp.h"
14 #include "gderrs.h"
15
16
17 gdSendRequest(d, r) /* send a request across a connection */
18 GDconnect *d;
19 GDrequest *r;
20 {
21 unsigned char rbuf[10];
22 struct iovec iov[2];
23 /* encode header */
24 gdPutInt(rbuf, (int4)r->type, 2);
25 gdPutInt(rbuf+2, r->id, 4);
26 gdPutInt(rbuf+6, r->alen, 4);
27 if (r->alen == 0) /* write header, null body */
28 write(d->fdout, rbuf, 10);
29 else { /* write header and body */
30 iov[0].iov_base = (MEM_PTR)rbuf;
31 iov[0].iov_len = 10;
32 iov[1].iov_base = (MEM_PTR)r->args;
33 iov[1].iov_len = r->alen;
34 writev(d->fdout, iov, 2);
35 }
36 }
37
38
39 GDrequest *
40 gdRecvRequest(d) /* receive a request across a connection */
41 register GDconnect *d;
42 {
43 register GDrequest *r;
44 int type;
45 int4 id, alen;
46 unsigned char rbuf[10];
47 /* read header */
48 fread(rbuf, 1, 10, d->fpin);
49 if (feof(d->fpin))
50 return(NULL);
51 type = gdGetInt(rbuf, 2);
52 id = gdGetInt(rbuf+2, 4);
53 if (type < 0 | type > GD_NREQ) {
54 gdSendError(d, GD_E_UNRECOG, id);
55 return(NULL);
56 }
57 alen = gdGetInt(rbuf+6, 4);
58 r = (GDrequest *)malloc(sizeof(GDrequest)-GD_ARG0+alen);
59 if (r == NULL) {
60 gdSendError(d, GD_E_NOMEMOR, id);
61 return(NULL);
62 }
63 r->type = type;
64 r->id = id;
65 if ((r->alen = alen) > 0) { /* read arguments */
66 fread(r->args, 1, alen, d->fpin);
67 if (feof(d->fpin)) {
68 gdSendError(d, GD_E_ARGMISS, id);
69 gdFree(r);
70 return(NULL);
71 }
72 }
73 if (type == GD_R_Error) { /* our error */
74 gdReportError(d, (int)gdGetInt(r->args, 2), id);
75 gdFree(r);
76 return(NULL);
77 }
78 return(r); /* success! */
79 }
80
81
82 gdSendError(d, ec, id) /* send fatal error associated with a request */
83 GDconnect *d;
84 int ec;
85 int4 id;
86 {
87 GDrequest rq;
88 /* build error request */
89 rq.type = GD_R_Error;
90 rq.id = id;
91 gdPutInt(rq.args, (int4)ec, rq.alen=2);
92 gdSendRequest(d, &rq); /* send it */
93 gdClose(d); /* all errors are fatal */
94 }
95
96
97 gdReportError(d, ec, id) /* report fatal error to stderr */
98 GDconnect *d;
99 int ec;
100 int4 id;
101 {
102 fprintf(stderr, "RequestId %d: %s\nConnection %d closed.\n",
103 id, gdErrMsg[ec], d->cno);
104 gdClose(d); /* all errors are fatal */
105 }
106
107
108 GDconnect *
109 gdOpen(inp, outp, x, y) /* establish a client/server connection */
110 char *inp, *outp; /* named pipes, currently */
111 int x, y; /* (0,0) for client */
112 {
113 static int nconnections = 0;
114 register GDrequest *rp;
115 GDrequest rq;
116 register GDconnect *dp;
117
118 dp = (GDconnect *)malloc(sizeof(GDconnect));
119 if (dp == NULL) {
120 gdReportError(dp, GD_E_NOMEMOR, 0);
121 return(NULL);
122 }
123 dp->cno = ++nconnections;
124 if (!x) /* client opens to write first */
125 dp->fdout = open(outp, O_WRONLY);
126 dp->fpin = fopen(inp, "r");
127 if (dp->fpin == NULL)
128 goto connecterr;
129 if (x) /* server opens to write second */
130 dp->fdout = open(outp, O_WRONLY);
131 if (dp->fdout < 0)
132 goto connecterr;
133 if (x) { /* server sends resolution */
134 dp->xres = x; dp->yres = y;
135 rq.type = GD_R_Init;
136 rq.id = dp->cno;
137 rq.alen = 4;
138 gdPutInt(rq.args, (int4)x, 2);
139 gdPutInt(rq.args+2, (int4)y, 2);
140 gdSendRequest(dp, &rq);
141 } else { /* client receives resolution */
142 rp = gdRecvRequest(dp);
143 if (rp == NULL)
144 return(NULL);
145 if (rp->type != GD_R_Init)
146 goto connecterr;
147 dp->cno = rp->id;
148 dp->xres = gdGetInt(rp->args, 2);
149 dp->yres = gdGetInt(rp->args+2, 2);
150 gdFree(rp);
151 }
152 return(dp); /* success! */
153 connecterr:
154 gdReportError(dp, GD_E_CONNECT, 0);
155 return(NULL);
156 }
157
158
159 gdClose(d) /* close a display server/client connection */
160 register GDconnect *d;
161 {
162 if (d == NULL) return;
163 close(d->fdout);
164 fclose(d->fpin);
165 gdFree(d); /* free associated memory */
166 }
167
168
169 int4
170 gdGetInt(ab, n) /* get an n-byte integer from buffer ab */
171 register unsigned char *ab;
172 register int n; /* maximum length 4 */
173 {
174 register int4 res;
175
176 res = *ab&0x80 ? -1 : 0; /* sign extend */
177 while (n--)
178 res = res<<8 | *ab++;
179 return(res);
180 }
181
182
183 gdPutInt(ab, i, n) /* put an n-byte integer into buffer ab */
184 register unsigned char *ab;
185 register int4 i;
186 register int n;
187 {
188 while (n--)
189 *ab++ = i>>(n<<3) & 0xff;
190 }
191
192
193 double
194 gdGetReal(ab) /* get a 5-byte real value from buffer ab */
195 char *ab;
196 {
197 register int4 i;
198 register double d;
199
200 i = gdGetInt(ab, 4);
201 d = (i + (i>0 ? .5 : -.5)) * (1./0x7fffffff);
202 return(ldexp(d, (int)gdGetInt(ab+4,1)));
203 }
204
205
206 gdPutReal(ab, d) /* put a 5-byte real value to buffer ab */
207 unsigned char *ab;
208 double d;
209 {
210 int e;
211
212 gdPutInt(ab, (int4)(frexp(d,&e)*0x7fffffff), 4);
213 gdPutInt(ab+4, (int4)e, 1);
214 }
