root/radiance/ray/src/meta/xmeta.c
Revision: 1.5
Committed: Wed Nov 21 18:51:05 2007 UTC (17 years ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1, rad5R3, HEAD
Changes since 1.4: +2 -1 lines
Fixed implicit declarations
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 1.5 static const char RCSid[] = "$Id: xmeta.c,v 1.4 2007/10/08 18:07:57 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Program to output meta-files to X window system.
6     *
7     * cc -o Xmeta Xmeta.c Xplot.o plot.o mfio.o syscalls.o misc.o
8     *
9     * 2/26/86
10     */
11
12 schorsch 1.2 #include "rtprocess.h"
13 greg 1.4 #include "string.h"
14 greg 1.1 #include "meta.h"
15     #include "plot.h"
16
17 greg 1.5 extern void init(char *name, char *geom);
18 greg 1.1
19     #define overlap(p,xmn,ymn,xmx,ymx) (ov((p)->xy[XMN],(p)->xy[XMX],xmn,xmx) \
20     &&ov((p)->xy[YMN],(p)->xy[YMX],ymn,ymx))
21
22     #define ov(mn1,mx1,mn2,mx2) ((mn1)<(mx2)&&(mn2)<(mx1))
23
24     #define XCOM "pexpand +OCIsv -P %s"
25
26
27     char *progname;
28
29     static short newpage = TRUE;
30
31     static PLIST recording;
32
33     int maxalloc = 0; /* no limit */
34
35 greg 1.4 extern void pXFlush(void);
36 greg 1.1
37
38 greg 1.3 void
39 greg 1.1 save(p) /* record primitive */
40     PRIMITIVE *p;
41     {
42     register PRIMITIVE *pnew;
43
44     if ((pnew = palloc()) == NULL)
45     error(SYSTEM, "out of memory in save");
46 greg 1.3 mcopy((char *)pnew, (char *)p, sizeof(PRIMITIVE));
47 greg 1.1 add(pnew, &recording);
48     }
49
50
51 greg 1.4 void
52 greg 1.1 doglobal(g, sf) /* execute a global command */
53     register PRIMITIVE *g;
54     int sf;
55     {
56
57     switch (g->com) {
58
59     case PEOF:
60     return;
61
62     case PDRAW:
63 greg 1.4 pXFlush();
64 greg 1.1 break;
65
66     case PEOP:
67     endpage();
68     plfree(&recording);
69     set(SALL, NULL);
70     newpage = TRUE;
71     return;
72
73     case PSET:
74     set(g->arg0, g->args);
75     break;
76
77     case PUNSET:
78     unset(g->arg0);
79     break;
80
81     case PRESET:
82     reset(g->arg0);
83     break;
84
85     default:
86     sprintf(errmsg, "unknown command '%c' in doglobal", g->com);
87     error(WARNING, errmsg);
88     return;
89     }
90     if (sf)
91     save(g);
92
93     }
94
95
96 greg 1.4 void
97 greg 1.1 doprim(p, sf) /* plot primitive */
98     register PRIMITIVE *p;
99     int sf;
100     {
101
102     switch (p->com) {
103
104     case PMSTR:
105     printstr(p);
106     break;
107
108     case PLSEG:
109     plotlseg(p);
110     break;
111
112     case PRFILL:
113     fillrect(p);
114     break;
115
116     case PTFILL:
117     filltri(p);
118     break;
119
120     case PPFILL:
121     fillpoly(p);
122     break;
123
124     default:
125     sprintf(errmsg, "unknown command '%c' in doprim", p->com);
126     error(WARNING, errmsg);
127     return;
128     }
129     if (sf) {
130     save(p);
131     newpage = FALSE;
132     }
133
134     }
135 greg 1.4
136
137     void
138     plot(infp) /* plot meta-file */
139     FILE *infp;
140     {
141     PRIMITIVE nextp;
142
143     set(SALL, NULL);
144     do {
145     readp(&nextp, infp);
146     while (isprim(nextp.com)) {
147     doprim(&nextp, 1);
148     readp(&nextp, infp);
149     }
150     doglobal(&nextp, 1);
151     } while (nextp.com != PEOF);
152
153     }
154
155
156     void
157     replay(xmin, ymin, xmax, ymax) /* play back region */
158     int xmin, ymin, xmax, ymax;
159     {
160     register PRIMITIVE *p;
161
162     unset(SALL);
163     set(SALL, NULL);
164     for (p = recording.ptop; p != NULL; p = p->pnext)
165     if (isprim(p->com)) {
166     if (overlap(p, xmin, ymin, xmax, ymax))
167     doprim(p, 0);
168     } else
169     doglobal(p, 0);
170
171     }
172
173
174     int
175     main(argc, argv)
176     int argc;
177     char **argv;
178     {
179     FILE *fp;
180     char *geometry = NULL;
181     short condonly, conditioned;
182     char comargs[500], command[600];
183
184     progname = *argv++;
185     argc--;
186
187     condonly = FALSE;
188     conditioned = FALSE;
189
190     for ( ; argc; argv++, argc--)
191     if (!strcmp(*argv, "-c"))
192     condonly = TRUE;
193     else if (!strcmp(*argv, "-r"))
194     conditioned = TRUE;
195     else if (**argv == '=')
196     geometry = *argv;
197     else
198     break;
199
200     if (conditioned) {
201     init(progname, geometry);
202     if (argc)
203     while (argc) {
204     fp = efopen(*argv, "r");
205     plot(fp);
206     fclose(fp);
207     argv++;
208     argc--;
209     }
210     else
211     plot(stdin);
212     } else {
213     comargs[0] = '\0';
214     while (argc) {
215     strcat(comargs, " ");
216     strcat(comargs, *argv);
217     argv++;
218     argc--;
219     }
220     sprintf(command, XCOM, comargs);
221     if (condonly)
222     return(system(command));
223     else {
224     init(progname, geometry);
225     if ((fp = popen(command, "r")) == NULL)
226     error(SYSTEM, "cannot execute input filter");
227     plot(fp);
228     pclose(fp);
229     }
230     }
231
232     if (!newpage)
233     endpage();
234
235     return(0);
236     }
