1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: xmeta.c,v 1.4 2007/10/08 18:07:57 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Program to output meta-files to X window system. |
6 |
7 |
* cc -o Xmeta Xmeta.c Xplot.o plot.o mfio.o syscalls.o misc.o |
8 |
9 |
* 2/26/86 |
10 |
11 |
12 |
#include "rtprocess.h" |
13 |
#include "string.h" |
14 |
#include "meta.h" |
15 |
#include "plot.h" |
16 |
17 |
extern void init(char *name, char *geom); |
18 |
19 |
#define overlap(p,xmn,ymn,xmx,ymx) (ov((p)->xy[XMN],(p)->xy[XMX],xmn,xmx) \ |
20 |
&&ov((p)->xy[YMN],(p)->xy[YMX],ymn,ymx)) |
21 |
22 |
#define ov(mn1,mx1,mn2,mx2) ((mn1)<(mx2)&&(mn2)<(mx1)) |
23 |
24 |
#define XCOM "pexpand +OCIsv -P %s" |
25 |
26 |
27 |
char *progname; |
28 |
29 |
static short newpage = TRUE; |
30 |
31 |
static PLIST recording; |
32 |
33 |
int maxalloc = 0; /* no limit */ |
34 |
35 |
extern void pXFlush(void); |
36 |
37 |
38 |
void |
39 |
save(p) /* record primitive */ |
40 |
PRIMITIVE *p; |
41 |
42 |
register PRIMITIVE *pnew; |
43 |
44 |
if ((pnew = palloc()) == NULL) |
45 |
error(SYSTEM, "out of memory in save"); |
46 |
mcopy((char *)pnew, (char *)p, sizeof(PRIMITIVE)); |
47 |
add(pnew, &recording); |
48 |
49 |
50 |
51 |
void |
52 |
doglobal(g, sf) /* execute a global command */ |
53 |
register PRIMITIVE *g; |
54 |
int sf; |
55 |
56 |
57 |
switch (g->com) { |
58 |
59 |
case PEOF: |
60 |
return; |
61 |
62 |
case PDRAW: |
63 |
pXFlush(); |
64 |
break; |
65 |
66 |
case PEOP: |
67 |
endpage(); |
68 |
plfree(&recording); |
69 |
set(SALL, NULL); |
70 |
newpage = TRUE; |
71 |
return; |
72 |
73 |
case PSET: |
74 |
set(g->arg0, g->args); |
75 |
break; |
76 |
77 |
case PUNSET: |
78 |
unset(g->arg0); |
79 |
break; |
80 |
81 |
case PRESET: |
82 |
reset(g->arg0); |
83 |
break; |
84 |
85 |
default: |
86 |
sprintf(errmsg, "unknown command '%c' in doglobal", g->com); |
87 |
error(WARNING, errmsg); |
88 |
return; |
89 |
90 |
if (sf) |
91 |
save(g); |
92 |
93 |
94 |
95 |
96 |
void |
97 |
doprim(p, sf) /* plot primitive */ |
98 |
register PRIMITIVE *p; |
99 |
int sf; |
100 |
101 |
102 |
switch (p->com) { |
103 |
104 |
case PMSTR: |
105 |
printstr(p); |
106 |
break; |
107 |
108 |
case PLSEG: |
109 |
plotlseg(p); |
110 |
break; |
111 |
112 |
case PRFILL: |
113 |
fillrect(p); |
114 |
break; |
115 |
116 |
case PTFILL: |
117 |
filltri(p); |
118 |
break; |
119 |
120 |
case PPFILL: |
121 |
fillpoly(p); |
122 |
break; |
123 |
124 |
default: |
125 |
sprintf(errmsg, "unknown command '%c' in doprim", p->com); |
126 |
127 |
return; |
128 |
129 |
if (sf) { |
130 |
save(p); |
131 |
newpage = FALSE; |
132 |
133 |
134 |
135 |
136 |
137 |
void |
138 |
plot(infp) /* plot meta-file */ |
139 |
FILE *infp; |
140 |
141 |
PRIMITIVE nextp; |
142 |
143 |
set(SALL, NULL); |
144 |
do { |
145 |
readp(&nextp, infp); |
146 |
while (isprim(nextp.com)) { |
147 |
doprim(&nextp, 1); |
148 |
149 |
150 |
doglobal(&nextp, 1); |
151 |
} while (nextp.com != PEOF); |
152 |
153 |
154 |
155 |
156 |
void |
157 |
replay(xmin, ymin, xmax, ymax) /* play back region */ |
158 |
int xmin, ymin, xmax, ymax; |
159 |
160 |
161 |
162 |
unset(SALL); |
163 |
set(SALL, NULL); |
164 |
for (p = recording.ptop; p != NULL; p = p->pnext) |
165 |
if (isprim(p->com)) { |
166 |
if (overlap(p, xmin, ymin, xmax, ymax)) |
167 |
doprim(p, 0); |
168 |
} else |
169 |
doglobal(p, 0); |
170 |
171 |
172 |
173 |
174 |
int |
175 |
main(argc, argv) |
176 |
int argc; |
177 |
char **argv; |
178 |
179 |
FILE *fp; |
180 |
char *geometry = NULL; |
181 |
short condonly, conditioned; |
182 |
char comargs[500], command[600]; |
183 |
184 |
progname = *argv++; |
185 |
argc--; |
186 |
187 |
condonly = FALSE; |
188 |
conditioned = FALSE; |
189 |
190 |
for ( ; argc; argv++, argc--) |
191 |
if (!strcmp(*argv, "-c")) |
192 |
condonly = TRUE; |
193 |
else if (!strcmp(*argv, "-r")) |
194 |
conditioned = TRUE; |
195 |
else if (**argv == '=') |
196 |
geometry = *argv; |
197 |
else |
198 |
break; |
199 |
200 |
if (conditioned) { |
201 |
init(progname, geometry); |
202 |
if (argc) |
203 |
while (argc) { |
204 |
fp = efopen(*argv, "r"); |
205 |
plot(fp); |
206 |
fclose(fp); |
207 |
argv++; |
208 |
argc--; |
209 |
210 |
else |
211 |
plot(stdin); |
212 |
} else { |
213 |
comargs[0] = '\0'; |
214 |
while (argc) { |
215 |
strcat(comargs, " "); |
216 |
strcat(comargs, *argv); |
217 |
argv++; |
218 |
argc--; |
219 |
220 |
sprintf(command, XCOM, comargs); |
221 |
if (condonly) |
222 |
return(system(command)); |
223 |
else { |
224 |
225 |
if ((fp = popen(command, "r")) == NULL) |
226 |
error(SYSTEM, "cannot execute input filter"); |
227 |
plot(fp); |
228 |
pclose(fp); |
229 |
230 |
231 |
232 |
if (!newpage) |
233 |
endpage(); |
234 |
235 |
return(0); |
236 |
