root/radiance/ray/src/meta/xmeta.c
Revision: 1.1
Committed: Sat Feb 22 02:07:26 2003 UTC (22 years ago) by greg
5 * Program to output meta-files to X window system.
6 *
7 * cc -o Xmeta Xmeta.c Xplot.o plot.o mfio.o syscalls.o misc.o
8 *
9 * 2/26/86
10 */
11
12
13 #include "meta.h"
14
15 #include "plot.h"
16
17
18 #define overlap(p,xmn,ymn,xmx,ymx) (ov((p)->xy[XMN],(p)->xy[XMX],xmn,xmx) \
19 &&ov((p)->xy[YMN],(p)->xy[YMX],ymn,ymx))
20
21 #define ov(mn1,mx1,mn2,mx2) ((mn1)<(mx2)&&(mn2)<(mx1))
22
23 #define XCOM "pexpand +OCIsv -P %s"
24
25
26 char *progname;
27
28 static short newpage = TRUE;
29
30 static PLIST recording;
31
32 int maxalloc = 0; /* no limit */
33
34
35
36 main(argc, argv)
37
38 int argc;
39 char **argv;
40
41 {
42 FILE *fp;
43 FILE *popen();
44 char *geometry = NULL;
45 short condonly, conditioned;
46 char comargs[500], command[600];
47
48 progname = *argv++;
49 argc--;
50
51 condonly = FALSE;
52 conditioned = FALSE;
53
54 for ( ; argc; argv++, argc--)
55 if (!strcmp(*argv, "-c"))
56 condonly = TRUE;
57 else if (!strcmp(*argv, "-r"))
58 conditioned = TRUE;
59 else if (**argv == '=')
60 geometry = *argv;
61 else
62 break;
63
64 if (conditioned) {
65 init(progname, geometry);
66 if (argc)
67 while (argc) {
68 fp = efopen(*argv, "r");
69 plot(fp);
70 fclose(fp);
71 argv++;
72 argc--;
73 }
74 else
75 plot(stdin);
76 } else {
77 comargs[0] = '\0';
78 while (argc) {
79 strcat(comargs, " ");
80 strcat(comargs, *argv);
81 argv++;
82 argc--;
83 }
84 sprintf(command, XCOM, comargs);
85 if (condonly)
86 return(system(command));
87 else {
88 init(progname, geometry);
89 if ((fp = popen(command, "r")) == NULL)
90 error(SYSTEM, "cannot execute input filter");
91 plot(fp);
92 pclose(fp);
93 }
94 }
95
96 if (!newpage)
97 endpage();
98
99 return(0);
100 }
101
102
103
104
105 plot(infp) /* plot meta-file */
106
107 FILE *infp;
108
109 {
110 PRIMITIVE nextp;
111
112 set(SALL, NULL);
113 do {
114 readp(&nextp, infp);
115 while (isprim(nextp.com)) {
116 doprim(&nextp, 1);
117 readp(&nextp, infp);
118 }
119 doglobal(&nextp, 1);
120 } while (nextp.com != PEOF);
121
122 }
123
124
125
126 replay(xmin, ymin, xmax, ymax) /* play back region */
127 int xmin, ymin, xmax, ymax;
128 {
129 register PRIMITIVE *p;
130
131 unset(SALL);
132 set(SALL, NULL);
133 for (p = recording.ptop; p != NULL; p = p->pnext)
134 if (isprim(p->com)) {
135 if (overlap(p, xmin, ymin, xmax, ymax))
136 doprim(p, 0);
137 } else
138 doglobal(p, 0);
139
140 }
141
142
143
144
145 save(p) /* record primitive */
146 PRIMITIVE *p;
147 {
148 register PRIMITIVE *pnew;
149
150 if ((pnew = palloc()) == NULL)
151 error(SYSTEM, "out of memory in save");
152 mcopy(pnew, p, sizeof(PRIMITIVE));
153 add(pnew, &recording);
154 }
155
156
157
158
159 doglobal(g, sf) /* execute a global command */
160
161 register PRIMITIVE *g;
162 int sf;
163
164 {
165
166 switch (g->com) {
167
168 case PEOF:
169 return;
170
171 case PDRAW:
172 XFlush();
173 break;
174
175 case PEOP:
176 endpage();
177 plfree(&recording);
178 set(SALL, NULL);
179 newpage = TRUE;
180 return;
181
182 case PSET:
183 set(g->arg0, g->args);
184 break;
185
186 case PUNSET:
187 unset(g->arg0);
188 break;
189
190 case PRESET:
191 reset(g->arg0);
192 break;
193
194 default:
195 sprintf(errmsg, "unknown command '%c' in doglobal", g->com);
196 error(WARNING, errmsg);
197 return;
198 }
199 if (sf)
200 save(g);
201
202 }
203
204
205
206
207 doprim(p, sf) /* plot primitive */
208
209 register PRIMITIVE *p;
210 int sf;
211
212 {
213
214 switch (p->com) {
215
216 case PMSTR:
217 printstr(p);
218 break;
219
220 case PLSEG:
221 plotlseg(p);
222 break;
223
224 case PRFILL:
225 fillrect(p);
226 break;
227
228 case PTFILL:
229 filltri(p);
230 break;
231
232 case PPFILL:
233 fillpoly(p);
234 break;
235
236 default:
237 sprintf(errmsg, "unknown command '%c' in doprim", p->com);
238 error(WARNING, errmsg);
239 return;
240 }
241 if (sf) {
242 save(p);
243 newpage = FALSE;
244 }
245
246 }
