root/radiance/ray/src/meta/xmeta.c
Revision: 1.4
Committed: Mon Oct 8 18:07:57 2007 UTC (17 years, 8 months ago) by greg
Changes since 1.3: +108 -118 lines
2 static const char RCSid[] = "$Id: xmeta.c,v 1.3 2003/11/17 02:21:53 greg Exp $";
5 * Program to output meta-files to X window system.
6 *
7 * cc -o Xmeta Xmeta.c Xplot.o plot.o mfio.o syscalls.o misc.o
8 *
9 * 2/26/86
10 */
11
12 #include "rtprocess.h"
13 #include "string.h"
14 #include "meta.h"
15 #include "plot.h"
16
17
18 #define overlap(p,xmn,ymn,xmx,ymx) (ov((p)->xy[XMN],(p)->xy[XMX],xmn,xmx) \
19 &&ov((p)->xy[YMN],(p)->xy[YMX],ymn,ymx))
20
21 #define ov(mn1,mx1,mn2,mx2) ((mn1)<(mx2)&&(mn2)<(mx1))
22
23 #define XCOM "pexpand +OCIsv -P %s"
24
25
26 char *progname;
27
28 static short newpage = TRUE;
29
30 static PLIST recording;
31
32 int maxalloc = 0; /* no limit */
33
34 extern void pXFlush(void);
35
36
37 void
38 save(p) /* record primitive */
39 PRIMITIVE *p;
40 {
41 register PRIMITIVE *pnew;
42
43 if ((pnew = palloc()) == NULL)
44 error(SYSTEM, "out of memory in save");
45 mcopy((char *)pnew, (char *)p, sizeof(PRIMITIVE));
46 add(pnew, &recording);
47 }
48
49
50 void
51 doglobal(g, sf) /* execute a global command */
52 register PRIMITIVE *g;
53 int sf;
54 {
55
56 switch (g->com) {
57
58 case PEOF:
59 return;
60
61 case PDRAW:
62 pXFlush();
63 break;
64
65 case PEOP:
66 endpage();
67 plfree(&recording);
68 set(SALL, NULL);
69 newpage = TRUE;
70 return;
71
72 case PSET:
73 set(g->arg0, g->args);
74 break;
75
76 case PUNSET:
77 unset(g->arg0);
78 break;
79
80 case PRESET:
81 reset(g->arg0);
82 break;
83
84 default:
85 sprintf(errmsg, "unknown command '%c' in doglobal", g->com);
86 error(WARNING, errmsg);
87 return;
88 }
89 if (sf)
90 save(g);
91
92 }
93
94
95 void
96 doprim(p, sf) /* plot primitive */
97 register PRIMITIVE *p;
98 int sf;
99 {
100
101 switch (p->com) {
102
103 case PMSTR:
104 printstr(p);
105 break;
106
107 case PLSEG:
108 plotlseg(p);
109 break;
110
111 case PRFILL:
112 fillrect(p);
113 break;
114
115 case PTFILL:
116 filltri(p);
117 break;
118
119 case PPFILL:
120 fillpoly(p);
121 break;
122
123 default:
124 sprintf(errmsg, "unknown command '%c' in doprim", p->com);
125 error(WARNING, errmsg);
126 return;
127 }
128 if (sf) {
129 save(p);
130 newpage = FALSE;
131 }
132
133 }
134
135
136 void
137 plot(infp) /* plot meta-file */
138 FILE *infp;
139 {
140 PRIMITIVE nextp;
141
142 set(SALL, NULL);
143 do {
144 readp(&nextp, infp);
145 while (isprim(nextp.com)) {
146 doprim(&nextp, 1);
147 readp(&nextp, infp);
148 }
149 doglobal(&nextp, 1);
150 } while (nextp.com != PEOF);
151
152 }
153
154
155 void
156 replay(xmin, ymin, xmax, ymax) /* play back region */
157 int xmin, ymin, xmax, ymax;
158 {
159 register PRIMITIVE *p;
160
161 unset(SALL);
162 set(SALL, NULL);
163 for (p = recording.ptop; p != NULL; p = p->pnext)
164 if (isprim(p->com)) {
165 if (overlap(p, xmin, ymin, xmax, ymax))
166 doprim(p, 0);
167 } else
168 doglobal(p, 0);
169
170 }
171
172
173 int
174 main(argc, argv)
175 int argc;
176 char **argv;
177 {
178 FILE *fp;
179 char *geometry = NULL;
180 short condonly, conditioned;
181 char comargs[500], command[600];
182
183 progname = *argv++;
184 argc--;
185
186 condonly = FALSE;
187 conditioned = FALSE;
188
189 for ( ; argc; argv++, argc--)
190 if (!strcmp(*argv, "-c"))
191 condonly = TRUE;
192 else if (!strcmp(*argv, "-r"))
193 conditioned = TRUE;
194 else if (**argv == '=')
195 geometry = *argv;
196 else
197 break;
198
199 if (conditioned) {
200 init(progname, geometry);
201 if (argc)
202 while (argc) {
203 fp = efopen(*argv, "r");
204 plot(fp);
205 fclose(fp);
206 argv++;
207 argc--;
208 }
209 else
210 plot(stdin);
211 } else {
212 comargs[0] = '\0';
213 while (argc) {
214 strcat(comargs, " ");
215 strcat(comargs, *argv);
216 argv++;
217 argc--;
218 }
219 sprintf(command, XCOM, comargs);
220 if (condonly)
221 return(system(command));
222 else {
223 init(progname, geometry);
224 if ((fp = popen(command, "r")) == NULL)
225 error(SYSTEM, "cannot execute input filter");
226 plot(fp);
227 pclose(fp);
228 }
229 }
230
231 if (!newpage)
232 endpage();
233
234 return(0);
235 }
