--- ray/src/meta/tgraph.c 2003/08/01 14:14:24 1.4 +++ ray/src/meta/tgraph.c 2003/11/15 02:13:37 1.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tgraph.c,v 1.4 2003/08/01 14:14:24 schorsch Exp $"; +static const char RCSid[] = "$Id: tgraph.c,v 1.5 2003/11/15 02:13:37 schorsch Exp $"; #endif /* * Routines for tel-a-graph file plotting @@ -9,39 +9,30 @@ static const char RCSid[] = "$Id: tgraph.c,v 1.4 2003/ #include #include +#include #include "tgraph.h" +#include "plot.h" - #define isfloat(a) (isdigit(a) || (a) == '-' || (a) == '.' || \ (a) == 'E' || (a) == '+' || (a) == 'e') -extern double log10(); - - - - -initialize() - +extern void +initialize(void) { int i; for (i = 0; i < NCUR; i++) usecurve[i] = 1; +} - } - - - - - -option(s) /* record option */ - -char *s; - +extern void +option( /* record option */ + char *s +) { double atof(); char *sp; @@ -119,12 +110,11 @@ char *s; } - - -normalize(fp, fout) /* get extrema from file */ - -FILE *fp, *fout; - +extern void +normalize( /* get extrema from file */ + FILE *fp, + FILE *fout +) { char line[255]; double x, y; @@ -170,12 +160,10 @@ FILE *fp, *fout; - - -makeaxis(flag) /* make and print x and y axis */ - -int flag; - +extern void +makeaxis( /* make and print x and y axis */ + int flag +) { double xstep, ystep, step(), pos; int xorg, yorg; @@ -324,11 +312,10 @@ int flag; } - -isdata(s) - -register char *s; - +extern int +isdata( + register char *s +) { int commas = 0; @@ -346,28 +333,24 @@ register char *s; } - - -islabel(s) - -char s[]; - +extern int +islabel( + char *s +) { int i; i = strlen(s) - 2; return(i > 0 && s[0] == '"' && s[i] == '"'); - } +} - - double -step(mn, mx) /* compute step size for axis */ - -double *mn, *mx; - +step( /* compute step size for axis */ + double *mn, + double *mx +) { static int steps[] = {100, 50, 20, 10, 5, 2, 1}; int i; @@ -394,11 +377,10 @@ double *mn, *mx; double -pown(x, n) /* raise x to an integer power */ - -double x; -int n; - +pown( /* raise x to an integer power */ + double x, + int n +) { register int i; double p = 1.0; @@ -414,12 +396,10 @@ int n; } - - -istitle(s) - -char *s; - +extern int +istitle( + char *s +) { char word[32]; @@ -431,11 +411,10 @@ char *s; - -isdivlab(s) /* return TRUE if division label(s) */ - -register char *s; - +extern int +isdivlab( /* return TRUE if division label(s) */ + register char *s +) { return(instr(s, "division") != NULL); @@ -443,11 +422,10 @@ register char *s; - -isxlabel(s) - -register char *s; - +extern int +isxlabel( + register char *s +) { register char *xindex = instr(s, "x "); @@ -455,12 +433,10 @@ register char *s; } - - -isylabel(s) - -register char *s; - +extern int +isylabel( + register char *s +) { register char *yindex = instr(s, "y "); @@ -469,12 +445,11 @@ register char *s; -char * -instr(s, t) /* return pointer to first occurrence of t in s */ - -char *s, - *t; - +extern char * +instr( /* return pointer to first occurrence of t in s */ + char *s, + char *t +) { register char *pt, *ps; @@ -496,12 +471,10 @@ char *s, - -char * -snagquo(s) /* find and return quoted string within s */ - -register char *s; - +extern char * +snagquo( /* find and return quoted string within s */ + register char *s +) { register char *rval = NULL; @@ -520,12 +493,12 @@ register char *s; - -getdata(s, xp, yp) /* get data from line */ - -char *s; -double *xp, *yp; - +extern int +getdata( /* get data from line */ + char *s, + double *xp, + double *yp +) { double sin(), cos(); int oobounds = 0; @@ -570,13 +543,13 @@ double *xp, *yp; - -symout(a0, x, y, sname) /* output a symbol */ - -int a0; -int x, y; -char *sname; - +extern void +symout( /* output a symbol */ + int a0, + int x, + int y, + char *sname +) { pprim(PSEG, a0, x-symrad, y-symrad, x+symrad, y+symrad, sname); @@ -584,13 +557,15 @@ char *sname; } - -boxstring(a0, xmn, ymn, xmx, ymx, s) /* output a string within a box */ - -int a0; -int xmn, ymn, xmx, ymx; -char *s; - +extern void +boxstring( /* output a string within a box */ + int a0, + int xmn, + int ymn, + int xmx, + int ymx, + char *s +) { int start; long size;
