root/radiance/ray/src/meta/span.h
Revision: 1.3
Committed: Fri Nov 5 03:31:37 2004 UTC (20 years, 7 months ago) by greg
State: FILE REMOVED
1 /* RCSid: $Id: span.h,v 1.2 2003/07/14 22:24:00 schorsch Exp $ */
2 /*
3 * Structures for line segment output to dot matrix printers
4 */
5 #ifndef _RAD_SPAN_H_
6 #define _RAD_SPAN_H_
7
8 #ifdef __cplusplus
9 extern "C" {
10 #endif
11
12
13 #define MAXSPAN 5120 /* maximum span size in bytes */
14
15 struct span { /* line of printer output */
16 int xleft, xright, ybot, ytop;
17 char cols[MAXSPAN];
18 char tcols[MAXSPAN];
19 };
20
21
22
23
24 extern int linwidt, linhite, /* line size */
25 nrows; /* # of rows */
26
27 extern int minwidth; /* minimum line width */
28
29 extern struct span outspan; /* output span */
30
31 extern int spanmin, spanmax; /* current span dimensions */
32
33 #ifdef __cplusplus
34 }
35 #endif
36 #endif /* _RAD_SPAN_H_ */
37
