1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rplot.c,v 1.3 2003/11/15 02:13:37 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Plotting routines for meta-files to raster files |
6 |
7 |
8 |
9 |
#include "meta.h" |
10 |
#include "plot.h" |
11 |
#include "rast.h" |
12 |
13 |
14 |
int minwidth = 0; |
15 |
16 |
static PLIST inqueue = {NULL, NULL}; |
17 |
18 |
static PRIMITIVE nextp; |
19 |
20 |
static void initplot(void); |
21 |
static void doglobal(PRIMITIVE *g); |
22 |
static void plotblock(FILE *infp); |
23 |
static void doprim(PRIMITIVE *p); |
24 |
25 |
static void paintline(int x, int y, int run, int rise, int hrad, int vrad, |
26 |
int lpat, long run2, long rise2, int n); |
27 |
static void tfill(PRIMITIVE *p); |
28 |
static void fill(int attrib, int xmin, int ymin, int xmax, int ymax); |
29 |
30 |
31 |
void |
32 |
plot( /* plot meta-file */ |
33 |
FILE *infp |
34 |
35 |
36 |
do { |
37 |
readp(&nextp, infp); |
38 |
initplot(); |
39 |
while (inqueue.ptop != NULL || isprim(nextp.com)) |
40 |
plotblock(infp); |
41 |
doglobal(&nextp); |
42 |
fargs(&nextp); |
43 |
} while (nextp.com != PEOF); |
44 |
45 |
46 |
47 |
void |
48 |
initplot(void) /* initialize this plot */ |
49 |
50 |
int i; |
51 |
52 |
thispage(); |
53 |
/* allocate block */ |
54 |
if (outblock.xright <= 0) { |
55 |
for (i = 0; i < NUMSCANS; i++) |
56 |
if ((outblock.cols[i] = (unsigned char *)malloc(dxsiz)) == NULL) |
57 |
error(SYSTEM, "out of memory in initplot"); |
58 |
59 |
outblock.xleft = 0; |
60 |
outblock.xright = dxsiz-1; |
61 |
if (ydown) { |
62 |
outblock.ytop = dysiz+NUMSCANS-1; |
63 |
outblock.ybot = dysiz; |
64 |
} else { |
65 |
outblock.ytop = -1; |
66 |
outblock.ybot = -NUMSCANS; |
67 |
68 |
69 |
70 |
71 |
72 |
void |
73 |
doglobal( /* execute a global command */ |
74 |
PRIMITIVE *g |
75 |
76 |
77 |
switch (g->com) { |
78 |
79 |
case PEOF: |
80 |
break; |
81 |
82 |
case PEOP: |
83 |
if (g->arg0 & 0200) /* advance page */ |
84 |
nextpage(); |
85 |
else |
86 |
error(USER, "illegal continue direction in doglobal"); |
87 |
break; |
88 |
89 |
case PSET: |
90 |
set(g->arg0, g->args); |
91 |
break; |
92 |
93 |
case PUNSET: |
94 |
unset(g->arg0); |
95 |
break; |
96 |
97 |
case PRESET: |
98 |
reset(g->arg0); |
99 |
break; |
100 |
101 |
default: |
102 |
sprintf(errmsg, "unknown command '%c' in doglobal", g->com); |
103 |
error(WARNING, errmsg); |
104 |
break; |
105 |
106 |
107 |
108 |
109 |
110 |
void |
111 |
plotblock( /* plot next block */ |
112 |
FILE *infp |
113 |
114 |
115 |
PLIST lastinq; |
116 |
register PRIMITIVE *p; |
117 |
118 |
/* clear block */ |
119 |
nextblock(); |
120 |
/* plot from queue */ |
121 |
lastinq.ptop = inqueue.ptop; |
122 |
lastinq.pbot = inqueue.pbot; |
123 |
inqueue.ptop = inqueue.pbot = NULL; |
124 |
while ((p = pop(&lastinq)) != NULL) { |
125 |
doprim(p); |
126 |
pfree(p); |
127 |
128 |
/* plot from file */ |
129 |
while (isprim(nextp.com) && inthis(&nextp)) { |
130 |
doprim(&nextp); |
131 |
fargs(&nextp); |
132 |
133 |
134 |
/* print out block */ |
135 |
outputblock(); |
136 |
137 |
138 |
139 |
140 |
141 |
extern void |
142 |
nextblock(void) /* prepare next block */ |
143 |
144 |
register int i, n; |
145 |
register unsigned char *colp; |
146 |
/* clear block */ |
147 |
for (i = 0; i < NUMSCANS; i++) { |
148 |
colp = outblock.cols[i]; |
149 |
n = dxsiz; |
150 |
while (n--) |
151 |
*colp++ = IWHT<<3 | IWHT; |
152 |
153 |
/* advance */ |
154 |
if (ydown) { |
155 |
outblock.ytop -= NUMSCANS; |
156 |
outblock.ybot -= NUMSCANS; |
157 |
} else { |
158 |
outblock.ytop += NUMSCANS; |
159 |
outblock.ybot += NUMSCANS; |
160 |
161 |
return; |
162 |
163 |
164 |
165 |
void |
166 |
outputblock(void) /* output block to printer */ |
167 |
168 |
169 |
170 |
171 |
for (i = 0; i < NUMSCANS; i++) { /* overlay blocks */ |
172 |
173 |
n = outblock.xright - outblock.xleft + 1; |
174 |
colp = outblock.cols[i] + outblock.xleft; |
175 |
while (n--) { |
176 |
*colp = *colp>>3 & *colp; |
177 |
colp++; |
178 |
179 |
180 |
printblock(); /* print block */ |
181 |
182 |
183 |
184 |
void |
185 |
doprim( /* plot primitive */ |
186 |
register PRIMITIVE *p |
187 |
188 |
189 |
register PRIMITIVE *newp; |
190 |
191 |
switch (p->com) { |
192 |
193 |
case PLSEG: |
194 |
plotlseg(p); |
195 |
break; |
196 |
197 |
case PRFILL: |
198 |
fill((p->arg0&0103) | (pati[(p->arg0>>2)&03]<<2), |
199 |
CONV(p->xy[XMN],dxsiz),CONV(p->xy[YMN],dysiz), |
200 |
CONV(p->xy[XMX],dxsiz)+(p->arg0&0100?-1:0), |
201 |
CONV(p->xy[YMX],dysiz)+(p->arg0&0100?-1:0)); |
202 |
break; |
203 |
204 |
case PTFILL: |
205 |
tfill(p); |
206 |
break; |
207 |
208 |
default: |
209 |
sprintf(errmsg, "unknown command '%c' in doprim", p->com); |
210 |
211 |
return; |
212 |
213 |
214 |
if (innext(p)) { /* save for next time */ |
215 |
if ((newp = palloc()) == NULL) |
216 |
error(SYSTEM, "memory limit exceeded in doprim"); |
217 |
mcopy((char *)newp, (char *)p, sizeof(PRIMITIVE)); |
218 |
newp->args = savestr(p->args); |
219 |
add(newp, &inqueue); |
220 |
221 |
222 |
223 |
224 |
void |
225 |
plotlseg( /* plot a line segment */ |
226 |
227 |
228 |
229 |
register int ti; |
230 |
long run2 = 0L, rise2 = 0L; |
231 |
int x, y, run, rise, xstop, ystop, hrad, vrad, lpat, n; |
232 |
233 |
/* compute line pattern */ |
234 |
lpat = (p->arg0 >> 2) & 014; |
235 |
if (p->arg0 & 0100 && lpat != 0) |
236 |
lpat += 014; |
237 |
lpat |= p->arg0 & 03; |
238 |
239 |
ti = (p->arg0 >> 2) & 03; /* compute line radius */ |
240 |
ti = WIDTH(ti) / 2; |
241 |
hrad = CONV(ti, dxsiz); |
242 |
vrad = CONV(ti, dysiz); |
243 |
if (hrad < minwidth) |
244 |
hrad = minwidth; |
245 |
if (vrad < minwidth) |
246 |
vrad = minwidth; |
247 |
248 |
x = CONV(p->xy[XMX], dxsiz); /* start at top */ |
249 |
y = CONV(p->xy[YMX], dysiz); |
250 |
run = CONV(p->xy[XMN], dxsiz) - x; |
251 |
rise = CONV(p->xy[YMN], dysiz) - y; |
252 |
253 |
if (p->arg0 & 0100) /* slope < 0; reverse x */ |
254 |
x -= (run = -run); |
255 |
256 |
xstop = x + run; /* compute end point */ |
257 |
ystop = y + rise; |
258 |
259 |
if ((ti = outblock.ytop+vrad+1-y) < 0) { /* adjust to top of block */ |
260 |
run2 = rise2 = (long)ti*run; |
261 |
x += rise2/rise; |
262 |
y += ti; |
263 |
264 |
265 |
if ((ti = outblock.ybot-vrad-1-ystop) > 0) { /* adjust to bottom of block */ |
266 |
xstop += (long)ti*run/rise; |
267 |
ystop += ti; |
268 |
269 |
270 |
if (abs(run) > -rise) |
271 |
n = abs(xstop - x); |
272 |
else |
273 |
n = y - ystop; |
274 |
275 |
paintline(x, y, run, rise, hrad, vrad, lpat, run2, rise2, n); |
276 |
277 |
278 |
279 |
280 |
281 |
282 |
* This routine paints a line with calls to fill(). The line can |
283 |
* start and end at arbitrary points on a longer line segment. |
284 |
285 |
void |
286 |
paintline( |
287 |
register int x, |
288 |
register int y, |
289 |
int run, |
290 |
int rise, |
291 |
int hrad, |
292 |
int vrad, |
293 |
int lpat, |
294 |
long run2, |
295 |
long rise2, |
296 |
int n |
297 |
298 |
299 |
int xstep, ystep; |
300 |
301 |
if (run >= 0) |
302 |
xstep = 1; |
303 |
else { |
304 |
xstep = -1; |
305 |
run = -run; |
306 |
307 |
if (rise >= 0) |
308 |
ystep = 1; |
309 |
else { |
310 |
ystep = -1; |
311 |
rise = -rise; |
312 |
313 |
if (n < 0) |
314 |
n = max(run, rise); |
315 |
316 |
if (run > rise) |
317 |
while (n >= 0) |
318 |
if (run2 >= rise2) { |
319 |
fill(lpat, x-hrad, y-vrad, x+hrad, y+vrad); |
320 |
n--; |
321 |
x += xstep; |
322 |
rise2 += rise; |
323 |
} else { |
324 |
y += ystep; |
325 |
run2 += run; |
326 |
327 |
else |
328 |
while (n >= 0) |
329 |
if (rise2 >= run2) { |
330 |
331 |
n--; |
332 |
y += ystep; |
333 |
run2 += run; |
334 |
} else { |
335 |
x += xstep; |
336 |
rise2 += rise; |
337 |
338 |
339 |
340 |
341 |
342 |
void |
343 |
tfill( /* fill a triangle */ |
344 |
345 |
346 |
347 |
register int x, txmin, txmax; |
348 |
int xmn, ymn, tpat; |
349 |
long xsz, ysz; |
350 |
351 |
xmn = CONV(p->xy[XMN], dxsiz); |
352 |
xsz = CONV(p->xy[XMX], dxsiz) - xmn; |
353 |
ymn = CONV(p->xy[YMN], dysiz); |
354 |
ysz = CONV(p->xy[YMX], dysiz) - ymn; |
355 |
if (xsz <= 0 || ysz <= 0) |
356 |
return; |
357 |
txmin = (outblock.ybot - ymn)*xsz/ysz; |
358 |
txmax = (outblock.ytop - ymn)*xsz/ysz; |
359 |
if (p->arg0 & 020) { /* up or down */ |
360 |
x = txmin; |
361 |
txmin = xsz - txmax; |
362 |
txmax = xsz - x; |
363 |
364 |
txmin += xmn; |
365 |
txmax += xmn; |
366 |
txmin = max(txmin, xmn); |
367 |
txmax = min(txmax, xmn + (int)xsz - 1); |
368 |
tpat = (p->arg0&0103) | (pati[(p->arg0>>2)&03]<<2); |
369 |
370 |
if (p->arg0 & 040) { /* left or down */ |
371 |
fill(tpat, xmn, ymn, txmin - 1, ymn + (int)ysz - 1); |
372 |
for (x = txmin; x <= txmax; x++) |
373 |
if (p->arg0 & 020) /* down */ |
374 |
fill(tpat, x, ymn, x, (int)(ysz-(x-xmn)*ysz/xsz) + ymn - 1); |
375 |
else /* left */ |
376 |
fill(tpat, x, (int)((x-xmn)*ysz/xsz) + ymn, x, ymn + (int)ysz - 1); |
377 |
} else { /* right or up */ |
378 |
379 |
if (p->arg0 & 020) /* up */ |
380 |
fill(tpat, x, (int)(ysz-(x-xmn)*ysz/xsz) + ymn, x, ymn + (int)ysz - 1); |
381 |
else /* right */ |
382 |
fill(tpat, x, ymn, x, (int)((x-xmn)*ysz/xsz) + ymn - 1); |
383 |
fill(tpat, txmax + 1, ymn, xmn + (int)xsz - 1, ymn + (int)ysz - 1); |
384 |
385 |
386 |
387 |
388 |
389 |
void |
390 |
fill( /* fill rectangle with attribute */ |
391 |
register int attrib, |
392 |
int xmin, |
393 |
int ymin, |
394 |
int xmax, |
395 |
int ymax |
396 |
397 |
398 |
register int i, j; |
399 |
400 |
xmin = max(xmin, outblock.xleft); |
401 |
ymin = max(ymin, outblock.ybot); |
402 |
xmax = min(xmax, outblock.xright); |
403 |
ymax = min(ymax, outblock.ytop); |
404 |
405 |
for (j = ymin; j <= ymax; j++) |
406 |
for (i = xmin; i <= xmax; i++) |
407 |
if (pattern[(attrib&074)>>2] |
408 |
[(j>>3)%(PATSIZE>>3)][i%PATSIZE] & 1<<(j&07)) { |
409 |
410 |
if (attrib & 0100) { |
411 |
pixtog(i,j,attrib&03); |
412 |
} else { |
413 |
pixmix(i,j,attrib&03); |
414 |
415 |
416 |
417 |
