| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rplot.c,v 1.2 2003/07/21 22:30:18 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Plotting routines for meta-files to raster files
| 6 |
| 7 |
| 8 |
| 9 |
#include "meta.h"
| 10 |
#include "plot.h"
| 11 |
#include "rast.h"
| 12 |
| 13 |
| 14 |
int minwidth = 0;
| 15 |
| 16 |
static PLIST inqueue = {NULL, NULL};
| 17 |
| 18 |
static PRIMITIVE nextp;
| 19 |
| 20 |
static void initplot(void);
| 21 |
static void doglobal(PRIMITIVE *g);
| 22 |
static void plotblock(FILE *infp);
| 23 |
static void doprim(PRIMITIVE *p);
| 24 |
| 25 |
static void paintline(int x, int y, int run, int rise, int hrad, int vrad,
| 26 |
int lpat, long run2, long rise2, int n);
| 27 |
static void tfill(PRIMITIVE *p);
| 28 |
static void fill(int attrib, int xmin, int ymin, int xmax, int ymax);
| 29 |
| 30 |
| 31 |
void
| 32 |
plot( /* plot meta-file */
| 33 |
FILE *infp
| 34 |
| 35 |
| 36 |
do {
| 37 |
readp(&nextp, infp);
| 38 |
initplot();
| 39 |
while (inqueue.ptop != NULL || isprim(nextp.com))
| 40 |
plotblock(infp);
| 41 |
doglobal(&nextp);
| 42 |
fargs(&nextp);
| 43 |
} while (nextp.com != PEOF);
| 44 |
| 45 |
| 46 |
| 47 |
void
| 48 |
initplot(void) /* initialize this plot */
| 49 |
| 50 |
int i;
| 51 |
| 52 |
thispage();
| 53 |
/* allocate block */
| 54 |
if (outblock.xright <= 0) {
| 55 |
for (i = 0; i < NUMSCANS; i++)
| 56 |
if ((outblock.cols[i] = (unsigned char *)malloc(dxsize)) == NULL)
| 57 |
error(SYSTEM, "out of memory in initplot");
| 58 |
| 59 |
outblock.xleft = 0;
| 60 |
outblock.xright = dxsize-1;
| 61 |
if (ydown) {
| 62 |
outblock.ytop = dysize+NUMSCANS-1;
| 63 |
outblock.ybot = dysize;
| 64 |
} else {
| 65 |
outblock.ytop = -1;
| 66 |
outblock.ybot = -NUMSCANS;
| 67 |
| 68 |
| 69 |
| 70 |
| 71 |
| 72 |
void
| 73 |
doglobal( /* execute a global command */
| 74 |
PRIMITIVE *g
| 75 |
| 76 |
| 77 |
switch (g->com) {
| 78 |
| 79 |
case PEOF:
| 80 |
break;
| 81 |
| 82 |
case PEOP:
| 83 |
if (g->arg0 & 0200) /* advance page */
| 84 |
nextpage();
| 85 |
else
| 86 |
error(USER, "illegal continue direction in doglobal");
| 87 |
break;
| 88 |
| 89 |
case PSET:
| 90 |
set(g->arg0, g->args);
| 91 |
break;
| 92 |
| 93 |
case PUNSET:
| 94 |
unset(g->arg0);
| 95 |
break;
| 96 |
| 97 |
case PRESET:
| 98 |
reset(g->arg0);
| 99 |
break;
| 100 |
| 101 |
default:
| 102 |
sprintf(errmsg, "unknown command '%c' in doglobal", g->com);
| 103 |
error(WARNING, errmsg);
| 104 |
break;
| 105 |
| 106 |
| 107 |
| 108 |
| 109 |
| 110 |
void
| 111 |
plotblock( /* plot next block */
| 112 |
FILE *infp
| 113 |
| 114 |
| 115 |
PLIST lastinq;
| 116 |
register PRIMITIVE *p;
| 117 |
| 118 |
/* clear block */
| 119 |
nextblock();
| 120 |
/* plot from queue */
| 121 |
lastinq.ptop = inqueue.ptop;
| 122 |
lastinq.pbot = inqueue.pbot;
| 123 |
inqueue.ptop = inqueue.pbot = NULL;
| 124 |
while ((p = pop(&lastinq)) != NULL) {
| 125 |
doprim(p);
| 126 |
pfree(p);
| 127 |
| 128 |
/* plot from file */
| 129 |
while (isprim(nextp.com) && inthis(&nextp)) {
| 130 |
doprim(&nextp);
| 131 |
fargs(&nextp);
| 132 |
| 133 |
| 134 |
/* print out block */
| 135 |
outputblock();
| 136 |
| 137 |
| 138 |
| 139 |
| 140 |
| 141 |
extern void
| 142 |
nextblock(void) /* prepare next block */
| 143 |
| 144 |
register int i, n;
| 145 |
register unsigned char *colp;
| 146 |
/* clear block */
| 147 |
for (i = 0; i < NUMSCANS; i++) {
| 148 |
colp = outblock.cols[i];
| 149 |
n = dxsize;
| 150 |
while (n--)
| 151 |
*colp++ = IWHT<<3 | IWHT;
| 152 |
| 153 |
/* advance */
| 154 |
if (ydown) {
| 155 |
outblock.ytop -= NUMSCANS;
| 156 |
outblock.ybot -= NUMSCANS;
| 157 |
} else {
| 158 |
outblock.ytop += NUMSCANS;
| 159 |
outblock.ybot += NUMSCANS;
| 160 |
| 161 |
return;
| 162 |
| 163 |
| 164 |
| 165 |
void
| 166 |
outputblock(void) /* output block to printer */
| 167 |
| 168 |
register int i, n;
| 169 |
| 170 |
| 171 |
for (i = 0; i < NUMSCANS; i++) { /* overlay blocks */
| 172 |
| 173 |
n = outblock.xright - outblock.xleft + 1;
| 174 |
colp = outblock.cols[i] + outblock.xleft;
| 175 |
while (n--) {
| 176 |
*colp = *colp>>3 & *colp;
| 177 |
colp++;
| 178 |
| 179 |
| 180 |
printblock(); /* print block */
| 181 |
| 182 |
| 183 |
| 184 |
void
| 185 |
doprim( /* plot primitive */
| 186 |
| 187 |
| 188 |
| 189 |
register PRIMITIVE *newp;
| 190 |
| 191 |
switch (p->com) {
| 192 |
| 193 |
case PLSEG:
| 194 |
plotlseg(p);
| 195 |
break;
| 196 |
| 197 |
case PRFILL:
| 198 |
fill((p->arg0&0103) | (pati[(p->arg0>>2)&03]<<2),
| 199 |
CONV(p->xy[XMN],dxsize),CONV(p->xy[YMN],dysize),
| 200 |
CONV(p->xy[XMX],dxsize)+(p->arg0&0100?-1:0),
| 201 |
CONV(p->xy[YMX],dysize)+(p->arg0&0100?-1:0));
| 202 |
break;
| 203 |
| 204 |
case PTFILL:
| 205 |
tfill(p);
| 206 |
break;
| 207 |
| 208 |
default:
| 209 |
sprintf(errmsg, "unknown command '%c' in doprim", p->com);
| 210 |
| 211 |
return;
| 212 |
| 213 |
| 214 |
if (innext(p)) { /* save for next time */
| 215 |
if ((newp = palloc()) == NULL)
| 216 |
error(SYSTEM, "memory limit exceeded in doprim");
| 217 |
mcopy((char *)newp, (char *)p, sizeof(PRIMITIVE));
| 218 |
newp->args = savestr(p->args);
| 219 |
add(newp, &inqueue);
| 220 |
| 221 |
| 222 |
| 223 |
| 224 |
void
| 225 |
plotlseg( /* plot a line segment */
| 226 |
| 227 |
| 228 |
| 229 |
register int ti;
| 230 |
long run2 = 0L, rise2 = 0L;
| 231 |
int x, y, run, rise, xstop, ystop, hrad, vrad, lpat, n;
| 232 |
| 233 |
/* compute line pattern */
| 234 |
lpat = (p->arg0 >> 2) & 014;
| 235 |
if (p->arg0 & 0100 && lpat != 0)
| 236 |
lpat += 014;
| 237 |
lpat |= p->arg0 & 03;
| 238 |
| 239 |
ti = (p->arg0 >> 2) & 03; /* compute line radius */
| 240 |
ti = WIDTH(ti) / 2;
| 241 |
hrad = CONV(ti, dxsize);
| 242 |
vrad = CONV(ti, dysize);
| 243 |
if (hrad < minwidth)
| 244 |
hrad = minwidth;
| 245 |
if (vrad < minwidth)
| 246 |
vrad = minwidth;
| 247 |
| 248 |
x = CONV(p->xy[XMX], dxsize); /* start at top */
| 249 |
y = CONV(p->xy[YMX], dysize);
| 250 |
run = CONV(p->xy[XMN], dxsize) - x;
| 251 |
rise = CONV(p->xy[YMN], dysize) - y;
| 252 |
| 253 |
if (p->arg0 & 0100) /* slope < 0; reverse x */
| 254 |
x -= (run = -run);
| 255 |
| 256 |
xstop = x + run; /* compute end point */
| 257 |
ystop = y + rise;
| 258 |
| 259 |
if ((ti = outblock.ytop+vrad+1-y) < 0) { /* adjust to top of block */
| 260 |
run2 = rise2 = (long)ti*run;
| 261 |
x += rise2/rise;
| 262 |
y += ti;
| 263 |
| 264 |
| 265 |
if ((ti = outblock.ybot-vrad-1-ystop) > 0) { /* adjust to bottom of block */
| 266 |
xstop += (long)ti*run/rise;
| 267 |
ystop += ti;
| 268 |
| 269 |
| 270 |
if (abs(run) > -rise)
| 271 |
n = abs(xstop - x);
| 272 |
else
| 273 |
n = y - ystop;
| 274 |
| 275 |
paintline(x, y, run, rise, hrad, vrad, lpat, run2, rise2, n);
| 276 |
| 277 |
| 278 |
| 279 |
| 280 |
| 281 |
| 282 |
* This routine paints a line with calls to fill(). The line can
| 283 |
* start and end at arbitrary points on a longer line segment.
| 284 |
| 285 |
void
| 286 |
paintline(
| 287 |
register int x,
| 288 |
register int y,
| 289 |
int run,
| 290 |
int rise,
| 291 |
int hrad,
| 292 |
int vrad,
| 293 |
int lpat,
| 294 |
long run2,
| 295 |
long rise2,
| 296 |
int n
| 297 |
| 298 |
| 299 |
int xstep, ystep;
| 300 |
| 301 |
if (run >= 0)
| 302 |
xstep = 1;
| 303 |
else {
| 304 |
xstep = -1;
| 305 |
run = -run;
| 306 |
| 307 |
if (rise >= 0)
| 308 |
ystep = 1;
| 309 |
else {
| 310 |
ystep = -1;
| 311 |
rise = -rise;
| 312 |
| 313 |
if (n < 0)
| 314 |
n = max(run, rise);
| 315 |
| 316 |
if (run > rise)
| 317 |
while (n >= 0)
| 318 |
if (run2 >= rise2) {
| 319 |
fill(lpat, x-hrad, y-vrad, x+hrad, y+vrad);
| 320 |
n--;
| 321 |
x += xstep;
| 322 |
rise2 += rise;
| 323 |
} else {
| 324 |
y += ystep;
| 325 |
run2 += run;
| 326 |
| 327 |
else
| 328 |
while (n >= 0)
| 329 |
if (rise2 >= run2) {
| 330 |
| 331 |
n--;
| 332 |
y += ystep;
| 333 |
run2 += run;
| 334 |
} else {
| 335 |
x += xstep;
| 336 |
rise2 += rise;
| 337 |
| 338 |
| 339 |
| 340 |
| 341 |
| 342 |
void
| 343 |
tfill( /* fill a triangle */
| 344 |
| 345 |
| 346 |
| 347 |
register int x, txmin, txmax;
| 348 |
int xmn, ymn, tpat;
| 349 |
long xsz, ysz;
| 350 |
| 351 |
xmn = CONV(p->xy[XMN], dxsize);
| 352 |
xsz = CONV(p->xy[XMX], dxsize) - xmn;
| 353 |
ymn = CONV(p->xy[YMN], dysize);
| 354 |
ysz = CONV(p->xy[YMX], dysize) - ymn;
| 355 |
if (xsz <= 0 || ysz <= 0)
| 356 |
return;
| 357 |
txmin = (outblock.ybot - ymn)*xsz/ysz;
| 358 |
txmax = (outblock.ytop - ymn)*xsz/ysz;
| 359 |
if (p->arg0 & 020) { /* up or down */
| 360 |
x = txmin;
| 361 |
txmin = xsz - txmax;
| 362 |
txmax = xsz - x;
| 363 |
| 364 |
txmin += xmn;
| 365 |
txmax += xmn;
| 366 |
txmin = max(txmin, xmn);
| 367 |
txmax = min(txmax, xmn + (int)xsz - 1);
| 368 |
tpat = (p->arg0&0103) | (pati[(p->arg0>>2)&03]<<2);
| 369 |
| 370 |
if (p->arg0 & 040) { /* left or down */
| 371 |
fill(tpat, xmn, ymn, txmin - 1, ymn + (int)ysz - 1);
| 372 |
for (x = txmin; x <= txmax; x++)
| 373 |
if (p->arg0 & 020) /* down */
| 374 |
fill(tpat, x, ymn, x, (int)(ysz-(x-xmn)*ysz/xsz) + ymn - 1);
| 375 |
else /* left */
| 376 |
fill(tpat, x, (int)((x-xmn)*ysz/xsz) + ymn, x, ymn + (int)ysz - 1);
| 377 |
} else { /* right or up */
| 378 |
| 379 |
if (p->arg0 & 020) /* up */
| 380 |
fill(tpat, x, (int)(ysz-(x-xmn)*ysz/xsz) + ymn, x, ymn + (int)ysz - 1);
| 381 |
else /* right */
| 382 |
fill(tpat, x, ymn, x, (int)((x-xmn)*ysz/xsz) + ymn - 1);
| 383 |
fill(tpat, txmax + 1, ymn, xmn + (int)xsz - 1, ymn + (int)ysz - 1);
| 384 |
| 385 |
| 386 |
| 387 |
| 388 |
| 389 |
void
| 390 |
fill( /* fill rectangle with attribute */
| 391 |
register int attrib,
| 392 |
int xmin,
| 393 |
int ymin,
| 394 |
int xmax,
| 395 |
int ymax
| 396 |
| 397 |
| 398 |
register int i, j;
| 399 |
| 400 |
xmin = max(xmin, outblock.xleft);
| 401 |
ymin = max(ymin, outblock.ybot);
| 402 |
xmax = min(xmax, outblock.xright);
| 403 |
ymax = min(ymax, outblock.ytop);
| 404 |
| 405 |
for (j = ymin; j <= ymax; j++)
| 406 |
for (i = xmin; i <= xmax; i++)
| 407 |
if (pattern[(attrib&074)>>2]
| 408 |
[(j>>3)%(PATSIZE>>3)][i%PATSIZE] & 1<<(j&07)) {
| 409 |
| 410 |
if (attrib & 0100) {
| 411 |
pixtog(i,j,attrib&03);
| 412 |
} else {
| 413 |
pixmix(i,j,attrib&03);
| 414 |
| 415 |
| 416 |
| 417 |
