root/radiance/ray/src/meta/plotout.c
Revision: 1.5
Committed: Fri Nov 5 17:51:16 2004 UTC (20 years, 6 months ago) by greg
State: FILE REMOVED
Error occurred while calculating annotation data.
Removed plotout and lib4014 it depends on
2 static const char RCSid[] = "$Id: plotout.c,v 1.4 2003/11/15 02:13:37 schorsch Exp $";
5 * Program to send meta-files to plot(3X) drivers
6 *
7 * cc -o plotout plotout.c mfio.o syscalls.o misc.o -lplot
8 *
9 * Plot drivers
10 */
11
12
13 #ifdef FORTEK
14 #define XCOM "pexpand +vOCIsm -rtpSUR %s"
15 #else
16 #define XCOM "pexpand +vOCIs -rtpSUR %s"
17 #endif
18
19
20 #include <fcntl.h>
21
22 #include "rtprocess.h"
23 #include "meta.h"
24 #include "plot.h"
25 #include "lib4014/lib4014.h"
26
27
28 char *progname;
29
30 static short newpage = TRUE;
31
32 static int curx = -1, /* current position */
33 cury = -1;
34
35 static short curmod = -1; /* current line drawing mode */
36
37 static char lmode[4][16] = {"solid", "shortdashed",
38 "dotted", "dotdashed"};
39
40 static PRIMITIVE nextp;
41
42 static void doglobal(PRIMITIVE *g);
43 static void doprim(register PRIMITIVE *p);
44
45
46 int
47 main(
48 int argc,
49 char **argv
50 )
51 {
52 FILE *fp;
53 char comargs[200], command[300];
54 short condonly = FALSE, conditioned = FALSE;
55
56 progname = *argv++;
57 argc--;
58
59 while (argc && **argv == '-') {
60 switch (*(*argv+1)) {
61 case 'c':
62 condonly = TRUE;
63 break;
64 case 'r':
65 conditioned = TRUE;
66 break;
67 default:
68 error(WARNING, "unknown option");
69 break;
70 }
71 argv++;
72 argc--;
73 }
74
75 if (conditioned)
76 if (argc)
77 while (argc) {
78 fp = efopen(*argv, "r");
79 plot(fp);
80 fclose(fp);
81 argv++;
82 argc--;
83 }
84 else
85 plot(stdin);
86 else {
87 comargs[0] = '\0';
88 while (argc) {
89 strcat(comargs, " ");
90 strcat(comargs, *argv);
91 argv++;
92 argc--;
93 }
94 sprintf(command, XCOM, comargs);
95 if (condonly)
96 return(system(command));
97 else {
98 if ((fp = popen(command, "r")) == NULL)
99 error(SYSTEM, "cannot execute input filter");
100 plot(fp);
101 pclose(fp);
102 }
103 }
104
105 return(0);
106 }
107
108
109
110 void
111 plot( /* plot meta-file */
112 FILE *infp
113 )
114 {
115
116 openpl();
117 space(0, 0, XYSIZE, XYSIZE);
118
119 do {
120 readp(&nextp, infp);
121 while (isprim(nextp.com)) {
122 doprim(&nextp);
123 fargs(&nextp);
124 readp(&nextp, infp);
125 }
126 doglobal(&nextp);
127 fargs(&nextp);
128 } while (nextp.com != PEOF);
129
130 closepl();
131
132 }
133
134
135
136 void
137 doglobal( /* execute a global command */
138 PRIMITIVE *g
139 )
140 {
141 int tty;
142 char c;
143
144 switch (g->com) {
145
146 case PEOF:
147 break;
148
149 case PDRAW:
150 fflush(stdout);
151 break;
152
153 case PEOP:
154 newpage = TRUE;
155 if (!isatty(fileno(stdout)))
156 break;
157 /* fall through */
158
159 case PPAUS:
160 fflush(stdout);
161 tty = open(TTY, O_RDWR);
162 if (g->args != NULL) {
163 write(tty, g->args, strlen(g->args));
164 write(tty, " - (hit return to continue)", 27);
165 } else
166 write(tty, "\007", 1);
167 do {
168 c = '\n';
169 read(tty, &c, 1);
170 } while (c != '\n' && c != '\r');
171 close(tty);
172 break;
173
174 default:
175 sprintf(errmsg, "unknown command '%c' in doglobal", g->com);
176 error(WARNING, errmsg);
177 break;
178 }
179
180 }
181
182
183
184 void
185 doprim( /* plot primitive */
186 register PRIMITIVE *p
187 )
188 {
189
190 if (newpage) {
191 erase();
192 newpage = FALSE;
193 }
194
195 switch (p->com) {
196
197 case PLSEG:
198 plotlseg(p);
199 break;
200
201 case PMSTR:
202 printstr(p);
203 break;
204
205 default:
206 sprintf(errmsg, "unknown command '%c' in doprim", p->com);
207 error(WARNING, errmsg);
208 return;
209 }
210
211 }
212
213
214
215 void
216 printstr( /* output a string */
217 register PRIMITIVE *p
218 )
219 {
220
221 move(p->xy[XMN], p->xy[YMX]);
222 label(p->args);
223 curx = -1;
224 cury = -1;
225
226 }
227
228
229 void
230 plotlseg( /* plot a line segment */
231 register PRIMITIVE *p
232 )
233 {
234 static short right = FALSE;
235 int y1, y2;
236 short lm = (p->arg0 >> 4) & 03;
237
238 if (p->arg0 & 0100) {
239 y1 = p->xy[YMX];
240 y2 = p->xy[YMN];
241 } else {
242 y1 = p->xy[YMN];
243 y2 = p->xy[YMX];
244 }
245
246 if (lm != curmod) {
247 linemod(lmode[lm]);
248 curmod = lm;
249 }
250
251 if (p->xy[XMN] == curx && y1 == cury) {
252 cont(p->xy[XMX], y2);
253 curx = p->xy[XMX];
254 cury = y2;
255 } else if (p->xy[XMX] == curx && y2 == cury) {
256 cont(p->xy[XMN], y1);
257 curx = p->xy[XMN];
258 cury = y1;
259 } else if ((right = !right)) {
260 line(p->xy[XMN], y1, p->xy[XMX], y2);
261 curx = p->xy[XMX];
262 cury = y2;
263 } else {
264 line(p->xy[XMX], y2, p->xy[XMN], y1);
265 curx = p->xy[XMN];
266 cury = y1;
267 }
268 }
