--- ray/src/meta/plotin.c 2003/02/22 02:07:26 1.1 +++ ray/src/meta/plotin.c 2003/11/15 02:13:37 1.2 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: plotin.c,v 1.1 2003/02/22 02:07:26 greg Exp $"; +static const char RCSid[] = "$Id: plotin.c,v 1.2 2003/11/15 02:13:37 schorsch Exp $"; #endif /* * Program to convert plot(5) files to metafiles @@ -9,9 +9,11 @@ static const char RCSid[] = "$Id: plotin.c,v 1.1 2003/ * 5/20/85 */ +#include + #include "meta.h" +#include "plot.h" - #define getsi(f, m) ICONV(geti(f)-(m), size) @@ -26,13 +28,28 @@ static int curx = -1, /* current position */ static short curmod = 0; /* current line drawing mode */ +static void convert(FILE *infp); +static int geti(FILE *fp); +static int quadr(int x, int y, int xp, int yp); +static void step(int d); +static void linemod(char s[]); +static void erase(void); +static void space(int xmn, int ymn, int xmx, int ymx); +static void move(int x, int y); +static void cont(int x, int y); +static void line(int x0, int y0, int x1, int y1); +static void label(register char *s); +static void point(int x, int y); +static void arc(int x, int y, int x0, int y0, int x1, int y1); +static void circle(int x, int y, int r); -main(argc, argv) -int argc; -char **argv; - +int +main( + int argc, + char **argv +) { FILE *fp; @@ -63,16 +80,15 @@ char **argv; pglob(PEOF, 0200, NULL); return(0); - } +} - -convert(infp) /* convert to meta-file */ - -FILE *infp; - +void +convert( /* convert to meta-file */ + FILE *infp +) { char *fgets(), sbuf[BUFSIZ]; int command; @@ -146,10 +162,9 @@ FILE *infp; int -geti(fp) /* get two-byte integer from file */ - -register FILE *fp; - +geti( /* get two-byte integer from file */ + register FILE *fp +) { register int i; @@ -165,81 +180,86 @@ register FILE *fp; - -move(x, y) /* move to new position */ - -register int x, y; - +void +move( /* move to new position */ + register int x, + register int y +) { - curx = x; cury = y; - } - -cont(x, y) /* draw line to point */ - -register int x, y; - +void +cont( /* draw line to point */ + register int x, + register int y +) { - plseg(curmod, curx, cury, x, y); curx = x; cury = y; - } - -point(x, y) /* draw a point */ - -register int x, y; - +void +point( /* draw a point */ + register int x, + register int y +) { - plseg(0, x, y, x, y); curx = x; cury = y; - } - -line(x0, y0, x1, y1) /* draw a line segment */ - -int x0, y0, x1, y1; - +void +line( /* draw a line segment */ + int x0, + int y0, + int x1, + int y1 +) { - move(x0, y0); cont(x1, y1); - } - -label(s) /* print a label */ - -register char *s; - +void +label( /* print a label */ + register char *s +) { - pprim(PMSTR, 0, curx, cury, curx, cury, s); - } - static int del = 100; -static step(d){ + +void +step( + int d +) +{ del = d; } -arc(x,y,x0,y0,x1,y1){ + +void +arc( + int x, + int y, + int x0, + int y0, + int x1, + int y1 +) +{ double pc; double sqrt(); int flg,m,xc,yc,xs,ys,qs,qf; @@ -330,7 +350,15 @@ arc(x,y,x0,y0,x1,y1){ } } } -quadr(x,y,xp,yp){ + +int +quadr( + int x, + int y, + int xp, + int yp +) +{ if(x < xp) if(y <= yp)return(1); else return(4); @@ -342,33 +370,30 @@ quadr(x,y,xp,yp){ } - -circle(x,y,r){ +void +circle( + int x, + int y, + int r +) +{ arc(x,y,x+r,y,x+r,y); } - -erase() /* erase plot */ - +void +erase(void) /* erase plot */ { - pglob(PEOP, 0200, NULL); - } - - - - -linemod(s) /* set line mode according to s */ - -char s[]; - +void +linemod( /* set line mode according to s */ + char s[] +) { - switch (s[2]) { case 'l': /* solid */ curmod = 0; @@ -386,23 +411,21 @@ char s[]; error(WARNING, "unknown line mode in linemod"); break; } - } - - -space(xmn, ymn, xmx, ymx) /* change space */ - -int xmn, ymn, xmx, ymx; - +void +space( /* change space */ + int xmn, + int ymn, + int xmx, + int ymx +) { - if (xmn >= xmx || ymn >= ymx) error(USER, "illegal space specification in space"); xmin = xmn; ymin = ymn; size = min(xmx-xmn, ymx-ymn); - }
