root/Development/ray/src/meta/plotin.c
Revision: 1.2
Committed: Sat Nov 15 02:13:37 2003 UTC (22 years ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, HEAD
Changes since 1.1: +104 -81 lines
Error occurred while calculating annotation data.
Continued ANSIfication, and reduced other compile warnings.
2 static const char RCSid[] = "$Id: plotin.c,v 1.1 2003/02/22 02:07:26 greg Exp $";
5 * Program to convert plot(5) files to metafiles
6 *
7 * cc -o plotin plotin.c primout.o mfio.o syscalls.o misc.o -lm
8 *
9 * 5/20/85
10 */
11
12 #include <string.h>
13
14 #include "meta.h"
15 #include "plot.h"
16
17 #define getsi(f, m) ICONV(geti(f)-(m), size)
18
19
20
21 char *progname;
22
23 static int xmin = 0, ymin = 0, /* current space settings */
24 size = XYSIZE;
25
26 static int curx = -1, /* current position */
27 cury = -1;
28
29 static short curmod = 0; /* current line drawing mode */
30
31 static void convert(FILE *infp);
32 static int geti(FILE *fp);
33 static int quadr(int x, int y, int xp, int yp);
34 static void step(int d);
35
36 static void linemod(char s[]);
37 static void erase(void);
38 static void space(int xmn, int ymn, int xmx, int ymx);
39 static void move(int x, int y);
40 static void cont(int x, int y);
41 static void line(int x0, int y0, int x1, int y1);
42 static void label(register char *s);
43 static void point(int x, int y);
44 static void arc(int x, int y, int x0, int y0, int x1, int y1);
45 static void circle(int x, int y, int r);
46
47
48 int
49 main(
50 int argc,
51 char **argv
52 )
53 {
54 FILE *fp;
55
56 progname = *argv++;
57 argc--;
58
59 while (argc && **argv == '-') {
60 switch (*(*argv+1)) {
61 default:
62 error(WARNING, "unknown option");
63 break;
64 }
65 argv++;
66 argc--;
67 }
68
69 if (argc)
70 while (argc) {
71 fp = efopen(*argv, "r");
72 convert(fp);
73 fclose(fp);
74 argv++;
75 argc--;
76 }
77 else
78 convert(stdin);
79
80 pglob(PEOF, 0200, NULL);
81
82 return(0);
83 }
84
85
86
87
88 void
89 convert( /* convert to meta-file */
90 FILE *infp
91 )
92 {
93 char *fgets(), sbuf[BUFSIZ];
94 int command;
95 int a1, a2, a3, a4, a5, a6;
96
97 while ((command = getc(infp)) != EOF)
98 switch (command) {
99 case 'm':
100 a1 = getsi(infp, xmin);
101 a2 = getsi(infp, ymin);
102 move(a1, a2);
103 break;
104 case 'n':
105 a1 = getsi(infp, xmin);
106 a2 = getsi(infp, ymin);
107 cont(a1, a2);
108 break;
109 case 'p':
110 a1 = getsi(infp, xmin);
111 a2 = getsi(infp, ymin);
112 point(a1, a2);
113 break;
114 case 'l':
115 a1 = getsi(infp, xmin);
116 a2 = getsi(infp, ymin);
117 a3 = getsi(infp, xmin);
118 a4 = getsi(infp, ymin);
119 line(a1, a2, a3, a4);
120 break;
121 case 't':
122 fgets(sbuf, sizeof(sbuf), infp);
123 sbuf[strlen(sbuf)-1] = '\0';
124 label(sbuf);
125 break;
126 case 'a':
127 a1 = getsi(infp, xmin);
128 a2 = getsi(infp, ymin);
129 a3 = getsi(infp, xmin);
130 a4 = getsi(infp, ymin);
131 a5 = getsi(infp, xmin);
132 a6 = getsi(infp, ymin);
133 arc(a1, a2, a3, a4, a5, a6);
134 break;
135 case 'c':
136 a1 = getsi(infp, xmin);
137 a2 = getsi(infp, ymin);
138 a3 = getsi(infp, 0);
139 circle(a1, a2, a3);
140 break;
141 case 'e':
142 erase();
143 break;
144 case 'f':
145 fgets(sbuf, sizeof(sbuf), infp);
146 linemod(sbuf);
147 break;
148 case 's':
149 a1 = geti(infp);
150 a2 = geti(infp);
151 a3 = geti(infp);
152 a4 = geti(infp);
153 space(a1, a2, a3, a4);
154 break;
155 default:
156 error(USER, "unknown command in convert");
157 break;
158 }
159 }
160
161
162
163
164 int
165 geti( /* get two-byte integer from file */
166 register FILE *fp
167 )
168 {
169 register int i;
170
171 i = getc(fp);
172 i |= getc(fp) << 8;
173 if (i & 0100000)
174 i |= ~0177777; /* manual sign extend */
175 if (feof(fp))
176 error(USER, "unexpected end of file in geti");
177
178 return(i);
179 }
180
181
182
183 void
184 move( /* move to new position */
185 register int x,
186 register int y
187 )
188 {
189 curx = x;
190 cury = y;
191 }
192
193
194
195 void
196 cont( /* draw line to point */
197 register int x,
198 register int y
199 )
200 {
201 plseg(curmod, curx, cury, x, y);
202 curx = x;
203 cury = y;
204 }
205
206
207 void
208 point( /* draw a point */
209 register int x,
210 register int y
211 )
212 {
213 plseg(0, x, y, x, y);
214 curx = x;
215 cury = y;
216 }
217
218
219
220 void
221 line( /* draw a line segment */
222 int x0,
223 int y0,
224 int x1,
225 int y1
226 )
227 {
228 move(x0, y0);
229 cont(x1, y1);
230 }
231
232
233 void
234 label( /* print a label */
235 register char *s
236 )
237 {
238 pprim(PMSTR, 0, curx, cury, curx, cury, s);
239 }
240
241
242
243 static int del = 100;
244
245 void
246 step(
247 int d
248 )
249 {
250 del = d;
251 }
252
253 void
254 arc(
255 int x,
256 int y,
257 int x0,
258 int y0,
259 int x1,
260 int y1
261 )
262 {
263 double pc;
264 double sqrt();
265 int flg,m,xc,yc,xs,ys,qs,qf;
266 float dx,dy,r;
267 char use;
268 dx = x-x0;
269 dy = y-y0;
270 r = dx*dx+dy*dy;
271 pc = r;
272 pc = sqrt(pc);
273 flg = pc/4;
274 if(flg == 0)step(1);
275 else if(flg < del)step(flg);
276 xc = xs = x0;
277 yc = ys = y0;
278 move(xs,ys);
279 if(x0 == x1 && y0 == y1)flg=0;
280 else flg=1;
281 qs = quadr(x,y,x0,y0);
282 qf = quadr(x,y,x1,y1);
283 if(abs(x-x1) < abs(y-y1)){
284 use = 'x';
285 if(qs == 2 || qs ==3)m = -1;
286 else m=1;
287 }
288 else {
289 use = 'y';
290 if(qs > 2)m= -1;
291 else m= 1;
292 }
293 while(1){
294 switch(use){
295 case 'x':
296 if(qs == 2 || qs == 3)yc -= del;
297 else yc += del;
298 dy = yc-y;
299 pc = r-dy*dy;
300 xc = m*sqrt(pc)+x;
301 if((x < xs && x >= xc) || ( x > xs && x <= xc) ||
302 (y < ys && y >= yc) || ( y > ys && y <= yc) )
303 {
304 if(++qs > 4)qs=1;
305 if(qs == 2 || qs == 3)m= -1;
306 else m=1;
307 flg=1;
308 }
309 cont(xc,yc);
310 xs = xc;
311 ys = yc;
312 if(qs == qf && flg == 1)
313 switch(qf){
314 case 3:
315 case 4:
316 if(xs >= x1)return;
317 continue;
318 case 1:
319 case 2:
320 if(xs <= x1)return;
321 }
322 continue;
323 case 'y':
324 if(qs > 2)xc += del;
325 else xc -= del;
326 dx = xc-x;
327 pc = r-dx*dx;
328 yc = m*sqrt(pc)+y;
329 if((x < xs && x >= xc) || ( x > xs && x <= xc ) ||
330 (y < ys && y >= yc) || (y > ys && y <= yc) )
331 {
332 if(++qs > 4)qs=1;
333 if(qs > 2)m = -1;
334 else m = 1;
335 flg=1;
336 }
337 cont(xc,yc);
338 xs = xc;
339 ys = yc;
340 if(qs == qf && flg == 1)
341 switch(qs){
342 case 1:
343 case 4:
344 if(ys >= y1)return;
345 continue;
346 case 2:
347 case 3:
348 if(ys <= y1)return;
349 }
350 }
351 }
352 }
353
354 int
355 quadr(
356 int x,
357 int y,
358 int xp,
359 int yp
360 )
361 {
362 if(x < xp)
363 if(y <= yp)return(1);
364 else return(4);
365 else if(x > xp)
366 if(y < yp)return(2);
367 else return(3);
368 else if(y < yp)return(2);
369 else return(4);
370 }
371
372
373 void
374 circle(
375 int x,
376 int y,
377 int r
378 )
379 {
380 arc(x,y,x+r,y,x+r,y);
381 }
382
383
384
385 void
386 erase(void) /* erase plot */
387 {
388 pglob(PEOP, 0200, NULL);
389 }
390
391
392 void
393 linemod( /* set line mode according to s */
394 char s[]
395 )
396 {
397 switch (s[2]) {
398 case 'l': /* solid */
399 curmod = 0;
400 break;
401 case 't': /* dotted */
402 curmod = 1;
403 break;
404 case 'n': /* long dashed */
405 curmod = 2;
406 break;
407 case 'o': /* short dashed (dot dashed) */
408 curmod = 3;
409 break;
410 default:
411 error(WARNING, "unknown line mode in linemod");
412 break;
413 }
414 }
415
416
417 void
418 space( /* change space */
419 int xmn,
420 int ymn,
421 int xmx,
422 int ymx
423 )
424 {
425 if (xmn >= xmx || ymn >= ymx)
426 error(USER, "illegal space specification in space");
427
428 xmin = xmn;
429 ymin = ymn;
430 size = min(xmx-xmn, ymx-ymn);
431 }
